SOURCE: Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
SOURCE: kitchen aid open door sensor alarm keeps going off door is closed
Open door and turn power off then on twice. Then press the Overtemp reset.
SOURCE: 1989 300e. The anti theft alarm went off while
This is the problem due to your anti theft alarm system. You have not mentioned which brand of anti-theft alarm system you have? Anyhow, most of the systems have a reset switch inside the kit, open the kit and on the main board, u will find the reset button, press that and hold for 5 sec, the system will be reset. Otherwise, there are 2 or 3 fuses with the wiring of kit, remove those fuses and ur engine will wake up but the anti-theft system wont work then, hope this will solve the problem
SOURCE: VW Beetle Alarm goes off for no apparent reason
the sensitivity on the alarm itself is too high, or there is something around the car that is interfering with the frequencies that are sent / received by the alarm itself, like other car alarms, power lines (mine actually did it when i parked under a power line) or the alarm unit itself is malfunctioning.
make sure that nothing is around to the (other cars with alarms) or look up under your dash, above your pedals (might have to take the trim plate off) and / or turn the sensitivity knob (flat-head screw driver, or just a simple protruding knob) down. make sure the battery in the remote is good too. if it stil ldoes it after this, then your remote needs to be reprogrammed.
SOURCE: I have an Armitron 40/8125 watch. I try to set the
You need to press button A to enter the time setting mode and then press C.
If you have lost your instructions, you can get instructions from the Amitron web site.
Copy
"www.armitron.com/watch_instructions.asp" into your search engine and
you will see a list of illustrations of watches and associated
instructions.
Choose
the one that looks like yours and download the PDF file.
