Question about Nokia 7610
3110c when i open my message my phone restart
  • 3 Answers
Got this from the net, maybe it helps:
The Problem with Nokia 3110c – Switching off and automatically restartingThis is what happens. Nokia 3110 hangs, gets switched off andrestarts randomly. More often, it restarts around 3 times or so andthen gets switched off.
Possible Causes and SolutionsCause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500KB, so as to keep things running smoothly on your phone and preventNokia 3110c from restarting.
Cause 2 – Changing Themes – Some people havereported that the phone restarts automatically when they try changingdisplay themes on the phone.
Solution – Don’t get your phone loaded with toomany themes downloaded from the internet or atleast, don’t switchthemes frequently. These themes, mind you, also load up things intoyour already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB datacable (or) Updating Music Library – A few people have reported thattheir Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but considerconverting all your MP3 music files to WMA and then store them on thememory card. Some users suggested this.
Disclaimer – Follow the suggested solutions at your own risk. The author is not responsible for any damage caused to your phone.
UPDATE:IT LOOKS LIKE A FIRMWARE UPDATE COULD FIX SUCH NOKIA 3110CRESTARTING PROBLEMS – RESOLVE YOUR ISSUES RIGHT NOW BY UPDATING YOURNOKIA 3110C FIRMWARE – CLICK HERE TO KNOW HOW YOU CAN UPDATE YOUR NOKIA PHONE FIRMWARE
Posted on Jul 23, 2009
2 Suggested Answers
Peer mohamed
  • 210 Answers
SOURCE: A message sign appears on
Please update your phones software
1) download the nokia software updater from the nokia website
2) install it on your computer
3)connect your phone with your computer then click on the update option now your problme will be solved
Posted on Jun 15, 2011
My nokia 3110c phone opening inbox to restart phone.........thats problem.......
my nokia 3110c phone opening inbox to restart phone.........thats problem.......
Oct 19, 2012 | Nokia 3110 Cellular Phone
I use nokia 3110c. When starting music player it shows
You did not mention the error message but it seems that it was "no music files found".Here let give you the solution,first download and install Oxycube to your pc.Open the Oxycube interface and at the same time connect your phone via USB by selecting PC suite.After your phone is connected properly selec the C Drive of your phone which will be shown at the bottom of the Oxycube interface.Select the folder name "Hidden folder" and again there you'll see db music .....delete all the files with the pre-fix of db .Remove USB Restart or Restore your phone and open the music.If there is no other software problem this trick will perfectly work.But if possible before you Restart your phone scan the mmc or use mmc of less than 1GB.because according to Nokia 3110c supports only 512 mb of mmc.However,if this trick doesn't work the only solution is to flash the phone, so if you want to do it Click here1 ...and the flash file of 3110c file is here.Good luck thanks for visiting fixya
Feb 28, 2012 | Nokia Lands Phones
My n3110c keeps restarting everytime i open the inbox.what would i do? I've tried to delete the message by folders but doesn't work.I've done the codes to format but just the same.please...
First of all try to delete by opening 'Message'>>Delete Message>>delete by folders etc.... If the problem still persist Click here1 or contact mobile repairing shop.Here is your 3110c file.Good luck Thanks for visiting fixya.
Aug 01, 2011 | Nokia 3110 Cellular Phone
A message sign appears on my nokia 3110c and when i open message inbox it restarts plz help me out..
Jun 15, 2011 | Nokia 3110 Cellular Phone
My mobile handset model is nokia 3110c.Its getting restarted frequently.I kept the mobile switched off and removed the battery too for some minutes.then switched on the mobile after a while without memory...
Firstly try to download this http://www.driversdown.com/drivers/Nokia-Phoenix-Service-Software_92760.shtml
Secondly download
3110c files And install it in your PC..Disconnect all usb devices.
Now connect the phone with usb data cable without power on the phone to PC.Open Nokia pheonix...Click to "FILE" and select "open product" Choose 3110c rm237.Next Click to "Flashing" and then open "FPS-8C FLASH " after opening this just click to "Close" button and again click to "Flashing" select "FIRMWARE UPDATE" NOW you can select the firmware version as well as the product code at the top right whch is showing a small browse window.Remember if the product code of the particular is not there just select the highest one.
After loading ..Click to "Dead phone" and again press to "REFURBISH"
Wait until a message shows that "PRESS POWER BUTTON" Press it and wait until the phone automatically switch on.
Good luck.......
Sep 26, 2010 | Nokia 3110 Cellular Phone
When i open the received files, the mobile does restart my mobile is 3110c
Possible that the received message contains some malware. So first of all delete the files, can be media or games that might make the program shut down and further damage the phone.
Sep 13, 2010 | Nokia 3110 Cellular Phone
Hang and restart
how to be format nokia 3110c
Jun 29, 2009 | Nokia 3110 Cellular Phone
Automatic restarting problem with Nokia 3110c mobile phone
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 - Phone Memory Full - Nokia 3110c mobile phone has got 9MB of internal memory.
Solution - Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 - Changing Themes - Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution - Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 - Memory Cards - Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution - Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 - Transferring data via Blueooth / USB data cable (or) Updating Music Library - A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution - Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 - MP3 files
Solution - This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Feb 12, 2009 | Nokia 3110 Cellular Phone
Nokia 7610 Logo
550 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
