Question about McCulloch 26cc Gas Blower Mcb3208
Fuel lines, McCulloch, Eager ****** 2014 with Zama M1-M7
Easy question for lots of folks, I suppose... I hope.
During my effort to replace deteriorated fuel lines, I was distracted for several days, and I've forgotten which carb port is which. Where does the line from the fuel tank (with filter on the end) go? And the other carb port (must be return or priming maybe??), what line goes there? Finally, what is the fuel line routing for the primer? Thanks very much. Feel like an idiot at this point.
    Scholar:
  • 173 Answers
Hey there, I'm not familiar with this particular tool, but, there is a good chance, that if you cut the fuel lines of an accurate length, mock up the replacement of the carb, and that should help you figure out, what goes where:)
Bon chance!
Posted on Jul 23, 2009
Need to know carb mixture
fuel mixture for 2 stroke' s is 20:1
100ml of oil in 5L of fuel
Mar 13, 2015 | Oregon McCulloch 12" Chain Saw Repl. Chain...
My McCulloch Eager ****** 2014 chainsaw will start and run for 3-4 seconds then shuts off. What steps should I take to fix this problem.
1. Drain fuel tank - use new gas/oil
2. Replace the "In-tank" fuel filter and possibly the 1/8" fuel line also. This can be bought at any lawn mower repair shop or Home Depot.
3. If problem persists - remove carburetor and clean all passages. There might be a small screen that needs to be cleaned. If you dont tear any gaskets - they can be used again. Just make sure nuts and screws are tight
4. You may need to adjust the High & Low mixture screws by removing their plastic anti-tampering covers - the high speed jet is usually marked "H".
5. Make sure air filter is clean
6. Remove exhaust assembly and clean screen and exhaust port if 1-5 does not work
May 02, 2011 | McCulloch Garden
Looking for engine parts for an old mcculloch eager ****** weed eater. where can i find them? need to buy a new fuel tank and fuel lines
I assume you mean edger, not eager.
You must have the model number to find anything. You can go to the Mcculloch web site.
http://www.mcculloch.info/node1092.aspx
Here is an example of a parts list for one of their edgers maybe you're lucky and this is the one you need.
http://weborder.husqvarna.com/order_static/doc/MIPL/MIPL1994/MIPL1994_mtt2380g.pdf
Jul 25, 2010 | Garden
I need to replace fuel lines and rebuild carb on
Try this for the manual: http://lawnandgarden.manualsonline.com/search.html?q=+mcculloch+corporation+mcculloch+corporation&s=gg314159
If that doesn't help:
Fuel Line Instillation: The longest, and sometimes smaller in diameter of the two fuel lines, goes fromthe carburetor to the bottom of the tank. Leave enough slack in thisline so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
Theotherfuel line goes from the primer bulb to just inside the tank,(about an inch). Make sure that you get the right size fuel lines. Theplastic coupling goes on the end of this line, inside the tank. Thiskeeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at anangle. They will feed much easier into the holes. You can than cut themoff square, once you know that you have enough to work with.
Carburetor Rebuild: Check the fuel lines for cracks/breaks. If they are o.k., then:
You willneed to disassemble the carburetor and spray with carb.cleaner. Make surethe small screen is free of debris. (Should be able to see daylightthrough it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
Just let me know.
Jim
Nov 30, 2009 | McCulloch Garden
Eager ****** not so eager when it warms up!
If the chain locks up it may be to tight. Try loosening the chain and see if the same problem happens.
Jun 20, 2009 | Garden
McCulloch Chain Saw Manual
Found all the mcculloch manuals you could ever want on mcculloch product information site. Its run by mcculloch an you put the product weather chainsaw or strimmer whatever an the type in the next collum an press download then print it off all very easy. My manual was in german so made up i found stumbled on this.
Jan 14, 2008 | McCulloch MC1275 Steam Vacuum
McCulloch 26cc Gas Blower Mcb3208 Logo
949 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
