Freezers Logo
Mike kramer Posted on Feb 28, 2017
I just bought a small silver king undercounter freezer… I took it's casters off and set it on my counter… It only got 25° all night… what could be the problem?
My brand new arctic king chest freezer the black one i just got wont come on when i plug it in i let it sit all day and night
It it turned on at the temperature dial? If it is, contact the seller.
This is from another manual, but typical. Notice it mentions the 'OFF' setting.
A storage basket is provided for the organization of odd-shaped items. To reach other packages in the freezer, just slide the basket to one side, or lift it out.
1 The first time you turn the freezer on, adjust the temperature control to the setting you want and run for two to three hours before putting food in. 2 After it is fully cooled, adjust the temperature control to the setting that best suits your needs. Settings include MIN, MAX, and OFF.
Model numbers are useful in such questions. It looks like you have Arctic King ARC070S0ARBB 7 cu ft Chest Freezer, Black
Brand: Arctic King.
Apr 18, 2021 • Freezers
My freezer was running a lot I guess the over load tripand stop working.replaced overload and relay and my gauges indicate high back pressure any ideas how to fix it
High back pressure is generally a sign that the evaporator coil is clogged with debries or the fan isn't working I suggest checking this first.
Silver king skp4812 stopped working
Are you getting any noise at all from the back of the system. It sounds like it could be a bad t'stat or relay. This would stop it from working right away.
1helpful
Fridge keeps on running and getting colder and colder
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Freezer keeps tripping breaker
Possible that it is draining a larger current and so it trips the breaker. Check if the capacitor to the motor is faulty, replace if you find it on test to consume more current and low charge.
Also the motor can be checked , the wiring to the freezer specially the GROUND connection as any leak can also trip the circuit.
Our under the counter freezer will not cool below 28 degrees. What are your thoughts?
Hi.
Try doing a defrost. If the freezer works after defrost, then it was the defrost system. If the freezer has auto defrost (evaporator comprising thermostat, timer, fan and heater), then the problem may restart after few days. In that case the problem is one of the parts comprised in the evaporator.
If the freezer does not cool after defrost, then temperature control (depending on model) may be responsible. Compressor and gas leak usually result in no cooling at all.
Regards.
Ginko.
New freezer but loud and cycles every 25 minutes
check that the door seals are a good fit all round,sounds like an air leak.....
What does front breathing mean?
"Front Breathing" usually means the refrigerator has a fan forced cooling system (condenser fan) that gets it cool air (and usually exhausts the warm air) via a front vent. The vent is usually located on the bottom or top.
Top Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Freezer Expert? Answer questions, earn points and help others
