Question about Mitsubishi Heating & Cooling
Splash problem switch is on
My window aircon is having splash problem. I did not use the air con for several months(neraly 5 months). When I start with remote control(batteries are fine) it is not starting. When I set drain slash button off and switch on the emergency run button, its running.
Model: MWK-07CV-R2 (Mitsubhishi Electric. Tiara).
Can you lpease let me know how to troubleshoot this so that i can run with remote control.
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: mitsubishi aircon, model MWK-07CV, when
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals for all of the Mitsubishi line. The manual include both troubleshooting and installation.
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
Posted on Sep 09, 2010
I have a split-type aircon (brand: LG) with remote control.It has power and display when i put on batteries. but the aircon unit does not respond to the remote control. what do i do to fix this?...
Lift the front cover of the air con, on the right hand side there is a button or a hole which has a button inside which you can press which is for manual starting of the air con. If this works, then you will know the remote is faulty, if it still doesn't work, check that the isolator switch for the air con hasn't been turned off. There will be 9Or should be) a switch outside next to the air con outdoor unit to switch power on / off to the air con. If not, there should be switch inside the meter box at the front of the house. Make sure they are switched on.
Apr 06, 2016 | LG LSC121PMA Split System Air Conditioner
My 2005 Audi A4 engine have idling problem when aircon is on
Sounds like the compressor is failing or seized (for the air con). This would put extra pressure on the system. It could be another fault with the air con system like the solenoids not opening up to allow the flow of gas in the system.
Feb 01, 2013 | 2005 Audi A4
Air Conditioning not working properly
My wife once mistakenly topped off the tank with diesel instead of gas. Same symptoms. Gas also goes bad when it sits in a tank for several months without a stabilizer. Try adding a fuel stabilizer and filling the tank with high-octane premium gas.
Apr 29, 2012 | Cars & Trucks
My mazda 6 v6 2004 smell oil when starting ventilation
The smell is typical of older Mazda aircon.
Purchase an aircon cleaning spray which is discharged into the aircon system by selecting recirc , cloing the windows for 5 minutes . This cleanses the system which is probably contaminated with bacteria.
Recharging your air con will help as well. The smell is due to evaporate condensed water mixed with sludge and bacteria .
Sep 20, 2011 | 2004 Mazda 6
My air-con is not as cold as before. I tried to lower the temperature, but when i try setting the temperature to 18 degrees, the remote just shows 18 degrees for like 5 seconds before going back to 31...
These is because you have not service your air-con for a long time. The cooling fins are clotted with dirt & dusts accumulated for a long period of time, and the water vapour caught between the cooling fins turn into ice when you set lower the temperture for the air-con. Moreover cool air from the blower/fan cannot pass thru', the cooling fins to regulate the cool air into your room.
You have to get the professionals to do a service on your air-con.
Hope it clarify your predicaments.
Jun 15, 2011 | Sanyo Heating & Cooling
Hi i need to know what size window air con for a room 30sq meters cooling onjy and what model
Hello there.. :) your room 30 sq. meters needs 2 - 2hp window type aircon as computed. But you can consider the purpose of putting up the aircon and how many occupants will stay.. :0
For the model:
NATIONAL, 2HP, Model CW-1808VPH 2HP LG Window Type Aircon Manual 2HP Koppel Aircon w/ remote model: KWR-18R1
or check the internet for other models that you want.. :)
Feb 03, 2011 | Heating & Cooling
Jaguar xk8 air con light flashes then turns off but air con is on
this is most often caused by a slightly low charge of refridgerent, as the engine heats the system the gas expands and the light goes out.
Apr 08, 2009 | 1999 Jaguar XK8
KELVINATOR AIR CON
More than likely it is the remote sensor in the indoor unit. Then again I presume that it is the correct remote control. Sometimes a remote for one aircon may not communicate with another aircon even if they are the same brand.
Jan 24, 2009 | Heating & Cooling
Bmw 318i air con switch
the light should be on when air con is working. only works when the blower is on ,ie heater blower switch on=air con light lit up = aircon working.
Oct 16, 2008 | 1997 BMW 318
I have a Ford BA Falcon but the heater does not work can you help
You'll most likely find your Air mix shaft has snapped - very common in the BA's and Territorys. Part only costs roughly $40, however the whole dash needs to come out so you can insert the new shaft. Less commonly it could be the HIM box
Aug 03, 2008 | Heating & Cooling
Heating & Cooling Logo
725 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
