Question about Dell XPS M1530 Laptop
Error code 2000-0146 in device Hard Drive 1
Will not boot from CD, will not boot in safe mode. So i cannot rollback with system restore. Will not boot using the "Last known good configuration" option in the boot menu. Always blue-screens at startup. Need help. Some think it's a virus and some think it is a hard drive error. If possible i need to know how to wipe the computer using bios or a form to where the operating system does not have to load. A walkthrough for that would be nice. Service warranty on the computer ran out and dell won't help at all without charging. It's a Dell Inspiron 1525 Notebook. If anymore information is needed or might be helpful, please let me know.
Thank you.
I just had this same problem a few weeks ago. This error code means you have a bad sector in your hard drive which is cheap and easy to fix. You just need to unscrew the bottom screws holding your hard drive in and place the old cover on the new hard drive you buy. Screw that new one in and reload your programs. Your computer will be as good as knew after that. Look on your invoice to get the hard drive specs so you can buy a new one or just enter your service tag on the dell site and check out the specs of the ones they offer for upgrade.
Posted on Jul 31, 2009
  • 120 Answers
First you have to do is the remove your RAM,, clean with air soft cleaner. You need also to remove the keyboard in order to remove the dust beside on your CPU. You have a hardware problem, that need to be maintenance, that why you have a blue screen. Or otherwise your MB is not working at all.
Posted on Jul 23, 2009
Failure to boot
Hard Drive Issue.
Error Code Biohd3 issues can arise from a variety of computer errors usually originating from corrupt or missing registry files.
Other contributing factors could be ActiveX errors or malicious software such as malware and spyware.
These types of problems are the consequence of not properly maintaining your system.
If left unchecked these problems can result in critical system errors, freezes, and even a total system failure.
BIOHD-3 means the diagnostic program has encountered errors with the hard drive attached to port 3.
It appears that your hard drive is bad.
If you can get your PC to boot up then do so and get your data backup to external media if you already haven't done so.
You will need to use your HP recovery disks when you install the replacement hard drive.
If you don't have a set of the HP recovery disks then you will need to order a set from HP.
or
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Reboot the computerAs the computer is booting repeatadly press the F8 key as the computer is booting
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select the safe mode option
then run your antivirus if still cant get rid of the virus restart again
Use the up and down arrow keys to move the highlight to your choice.
select safe mode with networking download anti malware and microsoft security essentials
http://www.microsoft.com/en-us/download/virus-malware.aspx?q=virus
anti virus and malware
http://windows.microsoft.com/en-US/windows/products/security-essentialsonce you have your computer running or you could do this in safe mode
Press windows button and in the search type msconfig go to startup tab and uncheck those you dont want to start.
Scroll to the bottom toolbar bottom of screen right click you can select task manager applications also processes you will see whats running on your computer and ticking over you might still have a virus
If you see something running that you does not need to be running select end now then you might you might uninstall that particular program
and some unnecessary programs
you should also check leads from motherboard to hard drive for secure dust free connections
Click start control panel administrative tools computer management disk management right Click on your drive select properties click tools you should see click check now
click start tick in both boxes this will schedule to on restart
do not have any input while chkdsk utility is in progress any might damage your computer
also you might download and use this registry cleaner it is totally free to use
http://download.cnet.com/ccleaner/
then defragment your hard drive
adding more ram is the best way of speeding up a computer
If you're not sure if a module is right for your system use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules
You should always ask for a guarantee on compatability before purchasing any ram and buy working pairs if possible.
you might have to many programs running at the same timeputting to much strain on the CPU
Try uninstalling a few unnecessary programs.
this should speed up your computer
or you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System
Configuration utility Installation restore points that occur before you install a program or a service
you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly.This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
Dec 06, 2013 | HP PAVILION DV4000 SERIES 100GB HARD DRIVE...
Everytime i boot my Toshiba Satellite L305D i get a message on a the black screen before windows startup saying "windows has encountered a problem communicating with a device connected to your...
If you have external USB and/or CD disconnect them and try again. Otherwise it could be a fault hard rive - try to boot from an emergency CD (hopefully you created one when you installed Windows).
May 11, 2011 | Computers & Internet
Windows\system32\config\system file missing or corrupt
you will get this error once an important file or files on your pc had been deleted or infected by virus. you need to scan your pc and perform a registry scan.
Apr 16, 2011 | Computers & Internet
My Dell Inspiron 6000 won't boot up. It keeps
Hi:
The DST error code 1000-1046 is definitely a failing hard drive. ..I am not sure why your laptop is not recognizing a CD in the drive, but you should go into your BIOS settings, and in boot sequence, make sure that the CD drive is the first boot device. If you can't boot from a CD, you are not going to get very far with installing a new hard drive...
May 02, 2010 | Dell Inspiron 6000 Notebook
XP wont boot and i cant boot from the restore disk. I get error code 1000-0146 when i run the DST Short test
That error code sounds like the Hard Drive is failing or has failed. Can you boot into Safe Mode? Hit F8 as you power up and choose Safe Mode with Command Prompt. If you can, enter chkdsk /r at a command prompt (the black window you'll see). You say you can't boot from the restore disk - why not? Are you booting to the green Dell Windows XP disc that shipped with the computer? Check the boot order in Setup (the BIOS) and make sure it looks to the CD drive first before trying to boot to the hard drive. SpinRite is a good utility for fixing these things, but not free, and involves booting to CD. http://www.grc.com/cs/prepurch.htm
Hope this helps!
Mar 08, 2010 | Dell Latitude D610 Laptop Computer -...
Reinstalling
Hard drive has bad sectors on it which is why its giving you that message even though you can go thru the restore. Normally going thru the system cd and then the recovery cd should bring you into windows with the device drivers installed.
Dec 10, 2009 | Acer Aspire 5520-5156 Laptop
Lenovo X60 Laptop blue screen error wont boot up
Try to go into safe mode by pressing F8 as soon as you turn on the laptop.
If you get into safe mode then go into system restore and choose a date when the laptop was working properly. Let it rollback to that date and reboot the computer and let it go and see if it goes back into windows.
If you get a blue screen even when trying to go into windows then the operating system is corrupted and you'll need to do a factory restore on the laptop, meaning the hard drive would have to be wiped out and the operating system put back onto the hard drive.
Aug 27, 2009 | Lenovo ThinkPad X60 Notebook
I have the dreaded ''blue screen of death'' but can use my safe mode for networking. help????
What operating system are you running?
Most blue screens are caused by a hardware issue. If your happy to do so, strip your PC down to the bare basics. Remove all RAM apart from one module, and PCI cards except graphics and remove mouse and keyboard.
If it now boots up OK, you know one of the things have disconnected was causing the problem! Plug each one in one by one. Also, you can try Fixing the master boot record, or booting from your Windows CD and using the repair functions
Jul 07, 2009 | Computers & Internet
After I started downloadingwinXP updates my screen went black,then what I keep seing is this blue screen whit the following message STOP: 0x0000007B(0xF7A55640, 0xC0000034, 0x00000000,0x00000000) is there...
What you are seeing is a reference to an address in Memory. if you keep seeing the same hex code you may have a bad memory module installed. You can test by creating a boot disc with memTest86
Before doing that though what were you downloading/installing? Was it a driver? if so try rebooting the machine then pressing F8 to go to safe mode>boot...go to device manager>find the device you updated>double-click go to driver tab>try to rollback to the previous driver then reboot.
you may also want to try a system restore to a previous time. Just click NO once you sign into safe mode to bring up that prompt
Jun 11, 2009 | Compaq Presario 700 470024-192 Notebook
Blue Screen c000021a
Next step is remove hard drive and see if it is recognized in another computer. The Hard Drive could just be bad, but you need to rule out the motherboard drive controllers that could also be bad. Also try a known good drive in your system.
Char S.
May 27, 2009 | Dell Vostro 1510 Laptop Computer PC...
Dell XPS M1530 Laptop Logo
2,747 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
