Question about Magellan RoadMate 1412 Car GPS Receiver
Are new batteries available?I opened unit and battery wires pulled out of connector.
    President:
  • 2,976 Answers
There are many websites with hard to find batteries. Most are a lot cheaper than Radio Shack.
Posted on Jul 23, 2009
How to replace battery in the Schiller AT-2 light EKG machine
The battery in the Schiller AT2 is as 12 volt 2.2 AH battery commonly available from R&d batteries, there part number is 5515. To replace it requires disasemble of the unit. Note that you should never disasemble this unit while it is plugged in. Also there are several cable that attach teh top housing to the PC board, and if you are not dillagent about not pulling these vcables apart while disasembling the unit, you can do expensive damage. Bearing that in mind, I would proceed as follows:Turn the unit upside down on top of a towed or other soft surcace to prevent scratching the soft plastic of the upper housing. around the perimeter of the case you will see several screws, i think 8 if i remember correctly. Repmove them and place them in a cup or other container. Grip the top and bottem cases together firmly and flip teh unit back upright. GENTLY lift up the top housing, and VERY CAREFULLY slide it about 3 or so inches to the left. This will expose the battery. just lift it out and replace it with the new one.Take care to reconnect the wires in the same position as teh original battery. Mis wiring the battery will cost you hundreds of dollars. The wires connect via slide on spade connectors. grip them by the connector itself(not the wire going into it) and gently rock it side to side while pulling, it will eventually come off the battery terminal. Resemble the unit in the reverse order. Plug the unit in and fully check it prior to re-installing the screws in the bottom of the unit in case you pulled a cable loose. As an alternative, you can detach the cables from the pc board and place the top cover to the side while replacing the battery, but be VERY careful with the cables. I recommend that you have a qualified individual preform this replacement for you. the cove being removed exposes high voltage, and also presents the risk of expensive damage to your unit.
Mar 22, 2011 | Schiller Welch Allyn Cardiovit At 2...
Tip
Error 161, 163
Errors 161, 192, 163.
All three of these errors are connected to the back up
battery.
To resolve this problem:
1. open memory flap on base of laptop (small philips
screwdriver required)
2. find the small connector with 1 black & 1 red wire
coming from it.
3. disconnect above connector and gently pull the
Red&black wires. The backup battery should just pull out
from under the casing.
4. get replacement battery. Either
a. call IBM spares (07900 247 490 in UK) and ask for FRU:
02K6502. UK price is about £8 + £15 delivery + VAT.
b. if comfortable with soldering iron: Carefully open the
packaging on the backup battery using a sharp knife.
Remove the solder tags from the battery (these are spot
welded so need to be cut/broken off). Buy a new CR2025
battery from any computer shop, jeweler, or camera shop.
Using electrical tape, insulate all round edge of battery
(see the one just removed). Solder the leads onto the new
battery - note polarity. Red wire to +, black wire to -.
Using more insulating tape, wrap battery so that all
exposed metal is covered.
5. put new battery into laptop (reverse steps 1-3)
6. start up computer, error 192 has gone, but still shows
161, 163. Select OK.
7. reset date & time, and OK
8. when screen shows 'O / I' restart laptop using on/off
switch at side.
on Mar 08, 2010 | Computers & Internet
New battery wont keep charge,new starter,starter selonid. could it be stator?
Asuming you have checked that the battery itself is holding its charge, neither the starter and or solenoide will have any affect on the charging of the battery, run a drop test on the Battery, even a new one could be faulty,
Next i would locate the regulator rectifier, this converts Ac from the alternator, into DC to charge the battery, here i would pay particular attention to the wire connector block, open the block and check inside for corrosion, also the wires on the outer of the block should be inspeted for corrosion which when oxidised turns green, check each connector and in turn pull on the wire to check for its condition,
Next i would visualy inspect the alternator for condition, you will find 3 yellow wires ie 3faze
Feb 28, 2011 | 2004 Honda VTX 1300 Retro
Battery won't charge, how do i take battery out of the THE PRIDE SONIC MOBILITY SCOOTER
Remove the seat by depressing a lever on the right side of the chair and pulling upward. there is a boot that covers the shaft of the seat rest. remove the boot and check for a pin with a ring on it. Once this is gone remove the shroud and you will find the batteries. Remove them with care and do a cursory check of all connectors. Some units have a 30 amp fuse on series with the batteries. Make sure the fuses aren't causing your trouble. Be certain to replace the batteries with the right polarity (positive to positive, etc...) Hope this helps.
Dec 27, 2010 | Pride Mobility Products Pride Mobility...
Error 161 & 163 on ibm aptiva 2168-m62
try this one:
battery.
coming from it.
switch at side.
Mar 05, 2010 | Computers & Internet
Battery
The new battery goes in the back of the Altec Lansing imt702. Remove the two screws on the lower back of the unit. The battery is connected via a clip connector. Simply press on the raised end of the clip, and pull off the other end of the connector. The battery is a Lithium-Ion 18650, 3.7V, at least 1800mAh. If you can get a battery with a higher-rated mAh, this will give you longer run times. It might be difficult to find a matching power connector on end of a new battery though. The unit will still run with the battery removed, but of course, will not power without the AC adapter connected to a wall outlet. If your unit has problems, continuously asking to Reset itself, or display+buttons flash (with volume increasing +1 for each blink), this indicates a charging problem. The battery needs to be replaced or removed immediately. You can reset the power manually by holding down the metal clip at the back of the unit for a minute, or just closing the leg/stand to see if this works. To reset unit's factory settings: hold down power & radio << channel buttons for 7 secs, press Power when asked to Reset?, Region=1 for US stations, & press Power again to set Region. Note that the battery is being drained even if the unit is off, so keep the AC connected; completely draining a well-used Li-Ion battery may shorten the rest of its battery life. Remove the battery from the unit if not in use for long periods.
  • Open in Google Docs Viewer
  • Open link in new tab
  • Open link in new window
  • Download file
  • Copy link address
Feb 22, 2010 | Altec Lansing Inmotion-IM600...
Westech 5000 battery low and i can't figure out how to fix it
There are 2 posibilities for having a low battery. 1) Your main backup battery for the control panel is low, or 2) You have wireless transmitters in your system that use small batteries and need to be replaced. To replace the control panel's battery look for a large metal box which is the control panel. These panels are normally located either in the basement or a 1st floor closet. Open the panel if you have a key. If you do not have a key take a pry bar and pop the box so it opens. Inside you will find an electronic motherboard with a black & red wire which is plugged into the battery. Grab a hold of the connector at the battery and wiggle/pull until the wire/connector disengages. Do the same for the other wire. Take the battery to a battery warehouse store and have them match it up. Be sure when reconnecting the new battery to plug the black wire/connector into the balck marked side of the battey and red to red. If you have a wireless system you will need to pull apart one of the transmitters & see the type of battery used. Replace all the batteries at the same time. They will last normally 3-5 years. The control panel's battery will last about 5 years.
Aug 25, 2009 | Home Security
Starting ibm thinkpad
Errors 161 and 163 mean the time and date are not set in the CMOS. This typically means the CMOS backup battery is dead / going dead.
Mar 05, 2009 | IBM ThinkPad T21 Notebook
Unit "froze" Is there a reset?
I had a similar problem with a MX-3000 2 years ago. The unit would continually freeze. I think it was a problem with the first few units. Since then I've bought a new one and had no problems. Then this weekend, it froze for the first time (the battery is not holding a charge so I think that led to the problem).
If you open the back cover, there is a silver button just above where the battery plugs into the remote. Pushing that button should perform a reset. As an alternative, you can remove the battery at the connector. It is recommended that you use the button and not the connector. It is in there tight on my unit and pulling on the wires can cause a break.
Gary
http://twitter.com/GaryHuff
Dec 16, 2008 | Universal Remote Control MX-3000 LCD...
BATTERY
There are available battery at radioshack or bestbuy. Check some of your local electronic stores.
Jul 21, 2007 | RCA Lyra RD2765 MP3 Player
Magellan RoadMate 1412 Car GPS Receiver Logo
172 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
