Question about Apple iPhone Smartphone
Iphone won't take a charge
IT shows 10% then shuts off. I;ve tried USB car charger and computer Could it be something in the phone
  • Apple Master
  • 377 Answers
  • Wen your charging the phone make sure you charge it fr 4 hrs because my iphone normally charge slow.
  • when your using usb for charging it will really take a coupe of hours the most is 5 hrs.
  • just chrge it 6 hrs and I can assure you it will power on.
Posted on Jul 23, 2009
My iphone won't charge up at all i put it on
hi there.
Follow these steps:
  1. Remove any debris from the charging port on the bottom of your device.
  2. Restart your iOS device.
  3. Try a different USB cable or charger.
  4. Make sure that you have the latest version of iOS.
  5. Contact Apple Support to set up service.
If your iPhone, iPad, or iPod touch won't charge - Apple Support
Why my iPhone is not charging?
2: Change the Wall Outlet or USB Port Plugged Into. The next most common reason aniPhone won't charge is because of where it's actually plugged into. Sometimes the wall outlet itself isn't working or the light switch is turned off, so if you're using a wall charger then change the outlet.20 Feb 2016
iPhone Won't Charge? Here's Why iPhone Isn't Charging & How to Fix It
How do you clean the charging port on iPhone?
To be safe, back up your iPhone or iPad to your computer or the cloud. Power it off, and with a normal toothpick, gently remove the lint. You will be amazed how much can get stuck in the port. Connect the charger and see if it works.16 Dec 2014
Use a toothpick to clean out your iPhone - CNET
https://www.cnet.com/how-to/use-a-toothpick-to-clean-out-your-iphone/
How do I charge my phone if my charger port is broken?All you need to do is shut down your device, remove the battery if possible and use something small, such as a toothpick, to 'lever up' the little tab inside the USB port on your smartphone or tablet. Do so very carefully and gently, then reinsert your battery and plug it in again.16 Jul 2016How to fix a phone that won't charge properly - AndroidPIThttps://www.androidpit.com/how-to-fix-a-phone-that-won-t-chargeSearch for: How do I charge my phone if my charger port is broken?
or try this link.
iphone won charge up Google Search
Nov 19, 2017 | Cell Phones
Tip
How do you fix your phone if it wont charge? ...
or this.
  1. Turn the phone off.
  2. Remove the battery.
  3. Wait 10 seconds.
  4. Plug in the charger.
  5. Insert the battery.
  6. Turn on the phone.
How to fix phone that won charge properly AndroidPIT
SOLVED Why won my Samsung Galaxy II charge Samsung Galaxy II
How to fix phone that wont charge
How to fix Samsung Galaxy S6 that not charging Troubleshooting Guide
Why is my Samsung charger not working Google Search
on Dec 12, 2017 | Samsung Cell Phones
Tip
Ipod not charging when i connect it to the usb port. or iphone.
If an alert says that your accessory isn't supported or certified. These alerts can appear for a few reasons: Your iOS device might have a dirty or damaged charging port, your charging accessory is defective, damaged, or non Apple-certified, or your USB charger isn't designed to charge devices
If your iPhone iPad or iPod touch won charge
How to Fix an iPad iPhone or iPod Touch That Won Charge Anymore
Help My iPad Won Charge
Help My iPod Battery Won Charge
ipod do not charging when connect it to the usb port Google Search
on Dec 06, 2017 | Computers & Internet
I have had my iphone less than a week- i did not expect it to have problems so soon. .... i have iphone 2g my battery ran out now it wont recharge or turn back on? .... but it doesn't turn on, it...
If your iPhone's battery runs very far down, the iPhone won't turn on. That's because it's using its remaining battery life to preserve your data and settings.So, your iPhone could be refusing to turn on because its battery doesn't have enough juice. In that case, plug your iPhone into a wall charger or into your computer (plug it directly into the computer; some USB ports on keyboards don't have enough power to charge iPhones). Let it sit for 10-20 minutes. If it was low on battery and needed a charge, when it's got enough juice to power the screen, it will turn on and show you its charging status, starting with the red battery icon.During this process, you may also want to make sure there's no lint packed into your cable or the iPhone's dock connector. This isn't a hugely common problem, but a lot of pocket lint could interfere with the iPhone getting a charge.
Jun 28, 2011 | BoxWave Corporation Apple iPhone 2G...
Iphone starts up for 5 seconds then shuts off and wont charge
what charger are you using?
if usb
try wall charger as usb wont charge when in restore mode unless the phone is on
Nov 17, 2009 | Apple iPhone Smartphone
Sometimes my Iphone will not charge when i connect it to the wall charger. I just bought my iphone a couple of months ago.
If your iPhone is not charging when you plug it into a wall charger or into you computer's usb port, this is a usb connectivity issue and the connection just needs to be reset. All that needs to be done is plug the iPhone's cable into the phone but don't plug into the computer yet. Hold the phone's select button (the round button with the square) down for about 30 seconds or until the apple appears on the screen. your phone will reload and reset the connection and the computer should recognize the device. Allow the phone to charge for at least 30 minutes before unplugging.
Oct 21, 2009 | Apple iPhone Smartphone
My iphone 2g only shows the apple for 10 seconds then shuts down
Try restoring it...here's how...
  1. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  2. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  3. Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
    Note: If you see the message "Charging... Please Wait" , let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
  4. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  5. When you see "Connect to iTunes" on the screen, you can release the Home button andiTuneswill display the recovery mode message:
    If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
After this you'll need to jailbreak it too....
Sep 04, 2009 | Apple iPhone Smartphone
Iphone won't charge and now won't work
I left my phone charging for a few hours and it appeared not to be charging as the battery icon was staying at 10% of charge. I was confused because it had the charging icon in the upper right hand corner. If your phone is doing something similar i simply powered the phone down and turned it back on. The charge went from 10% to 100% on the display. This is what worked for me hope this helps.
Jan 22, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
148 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
