Question about KitchenAid KSM150PS Artisan Series Stand Mixer
Mixer attachment I can't get my porcelian mixer attachment off. I used to be able to pull up and twist and it would easily come off? Seems stuck.
  • 5 more comments
  • Anonymous Dec 08, 2007
    I absolutely cannot get my paddle attachment off my mixer. We've tried everything, including WD-40. I don't know what to do!!!!! Help!!! We've been using the mixer with the paddle still on, and then cleaning the paddle. The button will not push in and the attachment will not slide up or down. Nothing works. Will I have to replace the mixer?
  • Anonymous Feb 11, 2008
    Same problem -- I used to be able to push the paddle up and twist it to get it off, but now it won't move at all when I try to push it up.
    The advice given is NOT helpful at all: if the paddle cannot be pushed up, it cannot be twisted. The pin is in the way. It's definitely not a case of "stupid woman, you're just not turning it far enough." >:(
  • Loov Mar 21, 2008
    same problem - we have to soak the attachment to clean it.
    It doesn't come off
  • calga Mar 23, 2008
    This is happening to me too - any ideas? It doesn't push up at all. I only used this 10 times at the most - what can I do??
  • kittenpants Jul 26, 2008
    I also can not get my porcelein beater to push up and out. ; ( it doesn't budge an inch, even when tapping w/ a hammer wrapped in a towel.
  • Anonymous Nov 26, 2008
    KitchanAid Artisan mixer, beater won't release
  • Anonymous Nov 29, 2008
    I thought maybe it was b/c mine was old (more than 5 years) - I will try the oil, but doubt it will work.
    Problem Solver:
  • 5 Answers
Make sure attachment is turned full counter clockwise to release point give a good tug if doesnt work try a light tapping with a rubber hammer or lobster wooden hammer
Posted on Nov 20, 2007
I had the same problem and I put veg oil on the top of beater and wrap the beater with a hot towel. I then lightly tapped the bottom of the beater until it moved up enough, then I tapped the side. Finally I tapped the top and it came off.
Posted on Mar 24, 2008
,first time user and the bowl is stuck in new artisian mixer. what do i do
Apply WD40, with the pinpoint sprayer straw attached, all around base and twist in the proper direction as hard as you can! (We had to wrap the bowl in that shelf liner rubbery mat stuff to get a good hold on the bowl since the handle came right off as we were initially working on the problem!) This worked for us. Hope that after 236 days DMLiss might have found another solution??!!<3+
Apr 11, 2012 | KitchenAid KSM150PS Artisan Series Stand...
I cannot remove the mixer attachment from the mixer. It will not move, or twist to the side to release.
Use a small amount of vegetable oil to lubricate the beater shaft and
the beater. Slightly tap the beater up and sideways with a rubber mallet
until you can move the beater easily along the shaft.
Jul 31, 2011 | KitchenAid Artisan KSM150PSAQ Stand Mixer
One of my blades is stuck and I can't engage the release
Make sure your Beater can slip in and out of the Beater Shaft
easily. Do not force the beater onto the Shaft if the shaft is bent.
If it cannot be removed easily by hand, use a soft rubber mallet
(not a steel hammer) to slightly tap the beater so it can be moved
up and down the shaft or from side to side. Then you can easily
turn the beater left and remove it from the shaft.
From Kitchenaid Manual:
To Attach Flat Beater, Wire Whip, or Dough Hook
1. Turn speed control to OFF.
2. Unplug stand mixer or disconnect power.
3. Tilt motor head back.
4. Slip beater onto beater shaft and press upward
as far as possible.
5. Turn beater to right, hooking beater over pin on shaft.
6. Plug into a grounded 3 prong outlet.
To Remove Flat Beater, Wire Whip or Dough Hook
4. Press beater upward as far as possible and turn left.
5. Pull beater from beater shaft
Jul 19, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Whisk attachment is stuck on mixer.
I took a small crowbar, and put the curved end up inside the whisk, and hammered the other end lightly. After about 20 taps, the peg was lined up with the sideways opening so I could twist it off. When I got it off, it looked like there was either flour inside the part where the whisk attaches, or some light corrosion was going on. Either way, I'm going to put a little grease in there so it doesn't happen again.
Mar 09, 2010 | Food Mixers
I cannot remove the attachment on the kitchenaid mixer. I used the paddle and now I'm not able to remove it.
Hello. I can assist you. I also have this mixer and I can tell you from experience. You have to lift it up about 1/4 inch and then twist it a small amount and pull it down and out. You can not hurt it so don't worry about using some force when you do this. Good luck with it.
Nov 16, 2009 | KitchenAid KSM150PS Artisan Series Stand...
My 325 Watt Artisan mixer's adapter won't come off? How do I get it unstuck?
To remove the mixer attachment I belive you must press up on the attachment to lock the inside gear into place. Once it is locked into position you can now twist to the left to remove the attachment. once removed you can pull the shaft back down to unlock the gear.Hope this helps.
Nov 15, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Blender attachment stuck on
As far as locking the gearhead, no, at least not without taking the planetary off of the mixer shaft. You would have to take the chrome ring loose by prying down gently, and there is a pin holding the planetary to the shaft, a punch would need to be used to drive it out, then you should be able to work it off the shaft and make the whole planetary easier to work on. The only other thing you could do would be to use a penetrant spray, wd-40 or something similar, let it settle into the attachment area, and try some more, sometimes it just takes time, and repeated application to free up.
Dec 26, 2008 | KitchenAid K45SS Classic Stand Mixer
Can't remove beater from mixer...
I took the advice from:
I put a wash cloth in a pot of boiling water and used tongs to wrap it around the beater shaft while the mixer was resting on its side. When the wash cloth was not too hot to touch, I put it back in the boiling water and did it again. I was then able to easily remove the beater.
Nov 28, 2008 | KitchenAid KITCHEN AID 5 Quart Artisan...
Bistro Staned Mixer;Mixing bowl is stuck(?) to base
You have to twist the bowl anti-clockwise to release it from the base. Twist clockwise to lock it when using the beaters.
Nov 23, 2008 | Wolfgang Puck Stand Mixer
Flat blade stuck on KA stand mixer
Using one of the bowls, filled it with hot water up to the shaft and where the paddle is hooked up. Using a cotton cloth, wrap it around the paddle and shaft, let it soak for 30 to 40 min. After 30 min, twist the paddle back and forth to loosen up whatever got stuck inside the shaft and paddle. Put a little of mineral oil so that the paddle will be easily remove and it will just slide out from the shaft.
Jul 04, 2008 | Food Mixers
KitchenAid KSM150PS Artisan Series Stand Mixer Logo
894 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
