SOURCE: Zig Zag Skip Stitch
your machine might have a problem with the rotary hook, it might need to get timed by a professional.
SOURCE: upside down stitching
Sounds like the needle alignment is out.
This website has some instructions on how to properly set it up and also has manuals too.
http://welcome.solutions.brother.com/bsc/public/us/ca/en/faq/faq_list.html?reg=us&c=ca&lang=en&prod=hf_cs8072eus&Cat=53
SOURCE: only does zig zag stitches, no straight stitches,
make sure the pattern selector is set for straight stitch first. If it is set correct then the machine may be "stuck" is zig zag mode. May need to be de greased and then re lubricated.
SOURCE: shark 384 - how can i get a straight stitch?
with the Shark Euro-Pro X machine, you need to bring the stitch width to zero it's the nob on top of the machine the manual states not to use it wider then 3 with the double needle cause it can break the needle. but either stitch selection "A" or "S" will give straight stitching with width at zero.
SOURCE: Singer Athena 2000 won't zig zag
Did you switch the metal plate to one of the ones that won't allow left/right movement by any chance?
If the wrong plate it in -The machine somehow figures out that the plate won't allow the needle to move in the left/right directions and only does a straight stitch or funky other stitches.
