Akai Plasma TV has flashing / pulsating artifacts for all inputs
This started just the other day, after I've had the tv for about a year, purchased used. As soon as it turns on, the screen starts pulsating, bright-dim-bright-dim, as it scans for an input source. After it finds and begins showing that input, the pulsating/flashing takes the form of artifact pixels - big splotches of color - in the picture. The color and the intensity of this splotchiness depends on what is being desplayed. Bright colors tend to flash more. I've uploaded a video of the problem to youtube here:
http://www.youtube.com/watch?v=A0BDUdvD4OU
I'm curious which component is likely at fault and if you think replacement of that component is needed, or if I just need to repair a connection.
Thanks for any help you can offer!
  • 1 more comment
  • remywokeup Jul 29, 2009
    Thanks for getting back to me. As I understand it, you've recommended a couple things:
    1.) Life a fuse on the zsus board and measure some voltages.
    -------- Would this be something I could do myself? I've taken the TV apart before to fix the vertical bar issue. How would I go about this?
    2.) Replace the zsus board and see if that solves the problem.
    -------- The cheapest board I could find was $75. If this does not solve the problem, I would then need a new screen which is definitely out of the question (I would just buy a new TV). So my question is how likely do you think it is that replacing the zsus will solve the problem? This will be helpful in deciding if I want to spend $75 on a "maybe" solution.
    Thanks again.
  • remywokeup Aug 03, 2009
    Thanks!
    Are the xsus, ysus and zsus 3 separate components? Any one of these could be the problem?
    What signs could I look for to help me figure out which of the three is the problem?
  • remywokeup Aug 11, 2009
    Thanks for the thorough explanation.
  • 19,396 Answers
A plasma TV need to be supplied continuously with power that gets then distributed to all rows and columns of the plasma panel, so to generate and maintain the picture.
In your case the voltage applied to the plasma panel is dropping, and this is causing the flash effect, with colour stains caused by plasma cells being supplied erratically.
In the best case the problem can be caused by a bad sustain board.
A bad PSU or Buffer board, or a bad chip on one of the cables connecting to plasma panel can cause loss of power to display, and you get the same effect.
The sustain boards is the most common, in that case you fix the problem replacing the Sus boards with Ysus Xsus kit.
Replacing the Ysus Xsus (or Zsus) with a kit is not a difficult operation. Sus kits are commonly available on Ebay, or from online sellers.
Testing the Sus board to ensure they are the fault is more difficult, and you will need an oscilloscope to perform the complete test.
If this comment had been helpful, then please do no not forget to leave feedback.
Thanks.
G.
Posted on Jul 29, 2009
    Brigadier General:
  • 4,090 Answers
Generally when a tube begins to flash it's on the way out. a tempory fix is to increase the brightness ,However this drives the tube harder and reduces the kife span even more.Twelve months is a very short time for a tube to start exhibiting this behaviour, I suppose it is also out of itsw warranty period too? Akai unfortunately are not a particularly good brand as they are made by several companies parts under the Akai logo.
If you get this repaired it would be expesive, you might want to consider dropping it and claiming insurance, to get a replacement.
Posted on Aug 03, 2009
  • 11,896 Answers
Ok I would say that your panel is suspect and can be checked by a tv tech.There is a procedure by lifting a fuse on the zsus board and measuring voltages. The first thing I would try is replacing the zsus and then checking picture. I hope you are covered by a service contract because the panel will cost as much as the tv.
Posted on Jul 27, 2009
My lg plasma really flickers but it does this randomly. Sometimes it will happen all the time other days not at all. I have tried sorting the cables and unplugged etc. it is 10 years old but just wanted...
I suspect its a component (Capacitor) aging and eventually would need to be replaced. How do you have it connected? Is there a cable box or Direct TV receiver that you use to display TV Channels? If 10 years old does it even have an HDMI input? Should be very happy you got 10 years of life out of this Plasma. My thoughts is that it would take more to repair this than to purchase a new LCD or LCD/LED thinner TV. Plasma does have the best color but the LCD and LED TV's are much lighter/take less energy and are much brighter. Good luck.
Dec 10, 2014 | LG 42PX4DR 42 in. Plasma TV
I need to know what input & output connections are available on the Akai PDP4290 Plasma TV?
This was the cheapest Akai in its day. No Tuner, No Speakers, must use a surround sound or regular stereo amp for sound.
It also has the standard A/V input also.
Best to use a HD Box and RGB cables for best picture.
Dec 04, 2010 | Akai PDP4290 42 in. EDTV-Ready Plasma...
I have A three year old AKAI 42 inch plasma tv---PDP4273M1---Mostly used as PC monitor. It was working just fine when I turned it off. When turned back on the next day, the on indicator light came on and...
Check to see what input setting the tv is on. It could still be looking for a signal from the pc input connection and no pc is hooked up thus getting no signal. Have the device you are trying to display on the tv connected and turned on and cycle through the inputs on the tv until you get a signal.
Sep 07, 2010 | Akai PDP-4216M 42 in. Plasma Television
AKAI PLASMA TV. MOEL AKI PDP4273M
Does it perhaps say no HDMI...instead of HTMI?
If so it means that it is not detecting anything from the HDMI input. Make sure that you have the cables properly connected and that you are on the correct TV input.
If thats not the case, try using component cables instead of HDMI and see if it works that way.
Jun 03, 2009 | Televison & Video
WD-52525 screen is jumping all around with wavy horizontal lines etc.
Good Day;
Keep talking to the factory, it is their product. Best Buy won't replace unless it is deemed not repairable and/or terms of the contract. You purchased the extra warranty because you most have felt that the TV might break down. Well, it did, now use the contract to repair your TV.
Good Luck, big IRISH.
Sep 29, 2008 | Mitsubishi WD-52525 52" Rear Projection...
No picture ; no sound
the red blinking light usually has a pattern that gives you a code to the possible problem.
Maybe you have a bad power supply board. You have to open the panel and do a few tests on the power supply's outputs to be sure.
It produces a variety of voltages for different parts of the tv ie. the plasma display panel and the audio system. The components supplying power to the audio system may have failed a year ago and recently the pdp.
plasma tv's are expensive to repair, most of the time you can get a better tv for the same price. You can reduce that cost by learning and troubleshooting it yourself.
Feb 23, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Authorized Repair Centers for Akai Flat Panel TV
My 42 inch Akai is about 6 months old,, and is showing green where black should be..
BUt there is help for you all.. Call Verizon, sign up for their "Expert Care" program. it's $10.00 a month, and active after the third month.
with a $75.00 deductable. THey will fix or Replace (give you choice of three alternate models/brands).
Free services under this plan are adjustments, and One FREE remote per year!.
i recomend you sign up for this program, and after 90 days. call for service. They more than likely will replace your TV's.
This is what they did with mine..
ALSO.
it doesn't matter how old your TV is, the plan is applicable to all TV's in your household. So one plan, one monthly payment of $10.00, covers all the TV's you own!!
Dec 09, 2007 | Televison & Video
Akai Plasma TV's screen suddenly went blank -model PDP4294
Same thing for me. TV just turned off one day and won't come back on. LED flashes red. Someone said it's because a cooling fan went out. If I can't find someone to fix it I'll take it apart and tinker myself. 32" with dvd built in was barely over a year old.
Nov 04, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
No picture or sound
Add av input or change input settings
Oct 24, 2007 | Akai PDP4225M 42 in. Plasma Television
Akai model pdp4249g
Hello drifter,The design of the tv enables the auto search to detect any input signal you have selected. It could be TV (off air, video signals etc) so just switch on whatever inputs to the akai plasma befote you switch the Akai plasma on and let it do the work for you. just relax and watch the tv. recap 1. switch on the input eg video deck, DVD, VCD, or satellite dish. 2. switch on your AKAI PLASMA and 3. wait for the akai to search for your input signals. TRy this simple procedure and if it doesnt work just post back the message. The DON
Jun 15, 2007 | Akai PDP-4249G 42 in. EDTV-Ready Plasma...
Televison & Video Logo
248 people viewed this question
Top Televison & Video Experts
Electro Med Services...
