Question about Memorex Televison & Video
Where can I purchase the laser and drive motor assembly for a 8.4 inch memorx dvd player and what will cost be??
  • 601 Answers
Hi...
You can get it from Ebay. It should not cost you more than $25 for both.
Thanks
Smith
Posted on Jul 23, 2009
Would it be like a new player,to have the laser lens replaced.How good are they after thatAre they like new.Mine is in like new shape now.Thanks for your time.
depends on the brand/model. Most dvd players do not get just the laser replaced anymore. You actually replace the laser/sled motor/turntable motor assembly.
Apr 07, 2015 | Televison & Video
Dvd player makes dvd's freeze
The problem is in the laser pickup assembly, the stepper rail motor that has attached worm gear cracks or flattens out causing the laser pickup to jam and the picture to freeze, in order to fix this the whole assembly most be replaced, but this would not be cost effective to do so, far cheaper to replace player.
Jul 07, 2012 | Coby DVD-218 DVD Player
Sony 9 inch portably dvd player freezes up
The problem is in the laser pickup assembly, to be more specific the laser pickup is moved by the stepper motor which in turn drives a worm gear and one or two cogwheels, sometimes a crack or a flat spot develope in the linkage causing laser to freeze.
Apr 19, 2012 | Sony DVPFX970 9 in Portable DVD Player
Put dvd in it says no disc or disc error
The problem is caused by the laser pickup assembly, the laser cannot read the disc because the pladder motor is not turning. The only option is to replace the assembly, not cost effective to repair, cheaper to buy a new replacement.
Mar 14, 2012 | Sanyo DRW-1000 DVD Recorder/VCR
Displays no disk , on dvd
The problem is the laser pickup assembly, overtime the laser lens becomes weaker, the other situation that I run into is a defective pladder motor that the dvd sits on. The only solution is try and clean the laser lens with a Q-Tip and rubbing alcohol "along shot" but sometimes it brings it back to life. If all else fails! the assembly will need to be replaced, "very costly" or replace combo unit, "cheaper"
Jan 12, 2011 | Apex Digital ADV3800 DVD Player/VCR
Sony 5 changer dvd player won't work. displayed code 31
Hi:
This may be caused by one or two causes. The laser pickup assembly is bad or the most common failure for DVD and CD players is the spindle motor. This motors bushings fails over time and does not spin the disc at the right speed so the unit times out. You can repair the by purchasing what sony calles the Mech Assembly it comes with new laser and stepper motor as well as the Spindle motor.
Mar 14, 2010 | Sony DVP-NC600 Multi-disc DVD Player
My dvd palyer shows NO DISC for any disc i want to play.
the laser is probably no good or the tiny motor that spins the disc is no good.there is a clamper assembly that goes in the hole in the disc.turn it and see if it spins freely.there is a bronze bushing on the top of the motor driving it ,and a small drop of light oil on the bearing will make it work again if it is gummed up..if the motor does not get the disc speed from 250 to 600rpm,fast,the laser does generate the proper info and the computer says error.yes the motors can be replaced,but the cost is as much as a new one
Jul 03, 2009 | Philips DVP642 DVD Player
I want purchase philips portable dvd player lens. i am at city-Jalandhar , State-Punjab ,INDIA modal name:- PET706/05 Portable DVD Player with Screen
You must take the assembly out of the player and locate the part number. Then try using the search engines with the part number plugged in to the search to find a parts distributor or dealer that carries the part. The part number is the key to finding the part. You may have to purchase the whole drive assembly with the motor and and laser combined. I hope this information helps you with your problem.
Mar 28, 2009 | Philips PET710 Portable DVD Player
Sony DVP-NC600 Multi-disc DVD Player No Disc Error
The only other thing I can suggest, having repaired many Sony CD/DVD players, is to get a can of compressed air and try to blow any dust out from the laser assembly. Since you've already cleaned the lens (the most common problem), you also might have dust down inside the assembly. Try blowing with the air nozzle down inside, around the gap between the lens and the cover surrounding it. Do it from at least a couple of inches away, if the air is too powerful you can damage the wiring inside the assembly.
If this fails to correct the problem, your laser output may have diminished over time and the only repair is to install a new laser assembly. The cost of this part will most likely not be worth it to you since the unit is quite old now.
Mar 02, 2009 | Sony DVP-NC600 Multi-disc DVD Player
I need a motor assembly for a philips dvd player
i used to repair dvd and cd players, the motor wont spin until the laser focuses on the disc, so you could have a faulty laser. also the mechanism sometimes comes as a complete assembly. which will cost more than anew unit
Mar 27, 2007 | Philips DVP5140 DVD Player
Televison & Video Logo
19 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Radames Pagan
Radames Pagan
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
