Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
There is ice in the icemaker but it doesn't advance to the outlet - don't think the coil thing is moving. Also I can't get the front panel of the ice maker off - where you push the tab.
  • 3 more comments
  • edavis1 Jul 23, 2009
    yesterday when i was able to get the assembly front cover off I removed all the ice. of course then there was no ice to see if it worked. today no ice came out and now I can't get the cover off to get at the assembly. I push tab and pull - nothing. I pried the tab off but still couldn't release the cover so put tab back on. so i don't really know if there is ice being made at this point. i don't hear the coil thing turning to move ice along. briefly hear a sound like it will but then nothing. the water dispenser is working fine.
    I will try these things tomorrow if i can get the cover off. can't do a thing with it on. any ideas on that?
    it was difficult to open and also shut the first time. i think that pushing on the tab is supposed to release a latch that holds the front cover on.
    I can't try the suggestions until i can get the front cover off.
    it sounds like it is going to start to run and then immediately stops. i have been thinking that is the problem and would order a new one except first i have to get that front cover off. i suppose i could pry it off and break it. is replacing the assembly fairly straightforward?
    Top Expert:
  • Maytag Master
  • 75,822 Answers
The drive mechanism for the auger that brings the ice out is defective. do u hear the motor run?
Posted on Jul 23, 2009
  • yadayada
    yadayada Jul 23, 2009
    Ii have no diagrams of your particular fridge, don't start prying, if you break a panel the job becomes very expensive very fast, have a repair person install the new auger motor, you might also want to look at www.repairclinic.com for more info on your model.
  • 13,433 Answers
There might be some ice cubes blocking it from working, try melting the whole ice maker system and try again ones its cleared of any ice - blockages.
  • Ekse Jul 23, 2009
    well, these are not what I specialize in.you may want to get another expert if this is not helpful:
    her is some general advice on the topic
    There's no iceIf your ice maker has stopped producing ice completely, check these, in this order:
  • It
    may be turned off. Look for the wire along the right side of the ice
    maker that looks a bit like a coat hanger. If the wire is in the raised
    position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In
    either case, the ice maker should begin producing ice again. Also make
    sure that the temperature is 8 degrees Fahrenheit or lower. If the
    freezer is too warm, the ice maker won't cycle properly.
  • The
    ice maker fill tube may be blocked with ice. If so, melt the blockage
    using a hair dryer-but be careful to not melt any plastic parts! Also
    replace the water shut-off valve or water-inlet valve, or both, if
    necessary.
  • The ice maker head assembly may have broken
    parts. Look to see if the gears are broken. Check to see if the small
    plastic arms that rest against the ice rake are broken. If the ice
    maker head assembly is modular and you've found broken parts, you can
    just replace it.
  • Ekse Jul 23, 2009
    no idea. since you where already able to open it up yesterday, what changed? should open up the same way as before.
    Water stop dispening from ref door outlet
    NOTE: This
    is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
    But the solution is in here generically, if you read and study the solutions very,very carefully.
    Check Temp inside freezer. It has to be down to about 10 or 15 degrees
    This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
    The ref. temp should be about 33-35
    The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
    The higher the number you turn it up to is the coldest
    The icemaker is 110v
    See if water is in icemaker.
    Pour water in Ice Maker and wait to see if it ejects.
    If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
    attaches to water line out of wall)
    If it doesn't eject then it is a faulty Ice Maker.
    If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
    I would check the fan in the freezer. Listen to see if it is running
    It moves air to the ref from the freezer
    Then check to see if freezer control is turned WARMER, which makes the Ref. colder
    Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
    the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
    Also this might be a common Defrost problem, Ice
    is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
    Take out back panel of freezer to check for ice buildup. The coils should be clean.
    There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
    Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
    Also check fan undernearh Ref in the rear
    Clean condenser coils underneath
    WATER SPLASHING IN FREEZER AT ICEMAKER
    THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
    AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
    OR BECOME CLOGGED WITH ICE.
    REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
    RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
    TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
    OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
    If you still have trouble GO HERE:
    hhttp://www.applianceaid.com/procedures.htm
    I'm including my article on Refrigerator Repair for your help and convenience.;
    Please click or copy and paste into browser for Article
    http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
    Thanks for using fixya
    Leo Ponder
    imufo2
    PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
    Sep 26, 2011 | GE Profile 23.1 Cu. Ft. Side-by-Side...
    Ice maker doesn/t work
    NOTE: This
    Leo Ponder
    imufo2
    Sep 18, 2011 | Refrigerators
    First icemaker stopped making ice. repairman replaced whole icemaker. Still didn't work. now whole frig doesn't work. Motor is on but no cold air to both sides
    NOTE: This
    First I would check the fan in the freezer. Listen to see if it is running
    Leo Ponder
    imufo2
    Sep 09, 2011 | KitchenAid Superba KSRG25FK Side by Side...
    Ice maker doesn't drop ice
    NOTE: This
    http://www.applianceaid.com/procedures.html
    I'm
    Leo Ponder
    imufo2
    Sep 06, 2011 | Frigidaire GS26HSZDW Side by Side...
    I have a KitchenAid Superba side by side made in 1998. We haven't used the ice maker in many years as it has been a "second" refrigerator without water supply. Now it's hooked up to water...
    NOTE: This
    I'm
    Leo Ponder
    imufo2
    Aug 28, 2011 | KitchenAid Refrigerators
    Kitchenaid superba kscs25fkss01- Icemaker is makiing ice but I hear a rhythmic clicking sound now and again. I think the sound is coming fron the white icemaker unit inside the frezer. It is still making...
    NOTE: This
    I'm
    Leo Ponder
    imufo2
    Aug 20, 2011 | KitchenAid Superba Architect KSCS25INSS...
    Water to ice maker works well. no discharge at drinking water outlet.
    NOTE: This
    I'm
    Leo Ponder
    imufo2
    Aug 19, 2011 | KitchenAid (KSRD22FKST) Side by Side...
    The icemaker, the front wheel in the motor part keeps trying to turn but can't. We just replaced the whole icemaker within five years.
    NOTE: This
    I'm
    Leo Ponder
    imufo2
    Aug 17, 2011 | Refrigerators
    The Cold Water outlet does not work. When you push the outlet lever back no water come out.
    NOTE: This
    I'm
    Leo Ponder
    imufo2
    Aug 14, 2011 | Roper RS22AQXKQ Side by Side Refrigerator
    Why is the ice maker not droping ice / Mod. ET1FTTXKQ00 / Type C21TFA01 Whirlpool 08-01
    Take a 4 inch piece of 14 gauge insulated wire and strip 1 inch of insulation off each end. Bend the wire into a U shape.Remove the plastic cover from the front of the icemaker. Insert the bare ends into the terminals marked T and H on the face of the icemaker. The wheel should move and dispense the ice into the bucket. If it does not move and drop the ice replace the icemaker.
    Aug 30, 2009 | Whirlpool Refrigerators
    Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
    47 people viewed this question
    Top Maytag Refrigerators Experts
    Bailey's...
    Bailey's...
    isaac johny
    isaac johny
    Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
