SOURCE: When I add a group mailing list BCC only one name is sent. Any ideas How to fix it. Thanks
You did not properly set up the mailing list with the names you wanted. Redo the exercise.
1) Click New in the upper left corner to write an email.
On the new page, click in the blank box beside To: and type the email address of the person you're writing to. Add addresses in the Cc: field if you want to send a copy of your email to anyone else. Others receiving this email will be able to see anyone listed in the Cc: line.
2) Inside Subject: give your email a title-then write whatever you want to in the message window. That's the big box below.
Sending is the easy part. Once you're done writing (and attaching photos or files if you want... see below), just click Send.
Here are some tips that can help you in the future:
3) Open your Address Book in a sub-window
Clicking To:, Cc: or Bcc: (see below) opens your Address Book in a sub-window, from which you can select recipients. Click Insert Checked Contacts when you're done.
4) Multiple Recipients:
Send your email to more than one person. Add additional email addresses after To: and separate them with commas (e.g., [email protected], [email protected], etc.). If you will be emailing this group again, you might want to create a category for them. That way, in the future you can send to the group in one click!
5) Bcc:
If you want to send a copy of your email to someone, and not let anyone else see that they're getting a copy, click Show Bcc above the To: line. Bcc is "blind carbon copy. Bcc: recipients are invisible to the To: and Cc: recipients of the email, as well as to each other. For example, if you send an email to [email protected] with a Bcc: to [email protected], you will see himself as the message's only recipient. You will also get the email, and she will see that you addressed and sent the email To: You as well.
Check spelling:
While composing and email, you can check the spelling in your email. Just click the Spelling button at the top of the page. If you want to localize your spell check to a specific language, click the arrow next to the Spelling button and select the appropriate language from the drop down menu.
Misspelled words are underlined in red. To view a list of suggested corrections for any misspelled words just click it!
Attach Photos and Files:
Click Attach at the top of the page. In the window that opens, click Browse to find and select the file you want. When you've got it, click Open. Repeat these steps to attach more files, and when you're finished, click Attach Files.
