Question about RTO New Yamaha Inverter Ef2400is / Yamaha Generator Ef2400 / Perfect For Camping, Emergency Home Use, Construction Sites And More!
Lost of spark after running for short time.
Genarator will loose its spark after it runs for a short time , if I shot it off it will not start , but if I place a new plug into it , then it will start first pull. I bypassed the kill switch , and the oil level safety switch. I had the coil tested @ local dealership in 2 places. I have ran the gen in the dark looking for possible wire grounding problems. Also changed the plug cap , and new plugs . What I have noticed is that if you leave the old plugs out to cool , they will be able to be reused to start the engine later. I am currently going to reset the valves , they seem to be out of adjustment .006 th. this problem has me stumped. Hope you can give me some input! Thanks T.R
    Sergeant:
  • 202 Answers
Are u using the spark plugs that the manufacturer recommends. I can suggest you one thing, you can test the coil when it is cold and it tests okay resistance values okay, but sometime when it is hot the coil shorts, and I have seen this happened check values when the coil is hot. Check resistance for the primary and secondary coil windings and record when coil is cold and when coil is hot
Posted on Jul 24, 2009
I have 1996 isuzu rodeo , drives. looses power, dies and back fires like a shot gun,
back first to tail pipe end, not air cleaner, right.
back fire to tail
is caused by 2 reaons.
engine runs rich as a pig, and air leaks to the exhuaust.
fuel + air and flame + bam.
sounds to me you lost cam timing
i cant help you more , as you never stated what engine is in the car.
called ENGINE OPTIONS< day 1.
and the story is lacking
start backup and .does....... what/???? runs prefectly???? or ????
Aug 25, 2014 | 1996 Isuzu Rodeo
Gentron pro2 6000p has no spark
With small engines, ignition is magneto. Four things can cause a lack of spark: (1) Faulty plug - try a new plug; (2) Bad, shorting, or disconnected spark plug wire - check for high voltage from ignition coil; (3) Bad ignition coil - check for low voltage at the coil input wires; (4) Magneto failure - the pickup coils next to the flywheel may be shorted, loose, or disconnected, OR the magnets on the flywheel may have lost their field or come out. I would troubleshoot this problem by checking and eliminating each of these possibilities in the above order. If all of the first three check out good; I'd have a mechanic check the magneto because this requires at least partial disassembly of the motor.
Nov 17, 2012 | Gentron 6000 Watt Propane Generator with...
2002 sportster lost spark to plugs
Hi Anonymous, the CKP sensor needs compression to send correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in head. If still not getting spark the usual suspects are:
1. Fouled spark plugs.
2. Battery voltage below 8.7 volts, loose or broken battery cables especially ground cable to frame.
3. Loose connection at ignition coil or plug between ignition sensor and module.
4. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
5. Faulty ignition coil or ignition / electronic module
6. Failed CKP, CMP, MAP or BAS sensor.
7. Faulty ignition switch.
8. Security alarm failing to disarm.
For a prime suspect please visit the website below and good luck.
Harley Davidson Sportster error codes and how to access them
Sep 07, 2012 | 2000 Harley Davidson XL 1200 C Sportster...
My bike juststopped-as if out of fuel.good spark,fuel getting through,good compression.any ideas please?
Engines have certain things to do in order to run. They need fuel, compression, spark and with correct ignition and valve timing. Sometimes when you think your getting fuel your not. A quick way to see if you are lacking fuel to the cylinder is a shot of starting fluid in the air cleaner but just a quick shot. Give it a kick and see if it starts and runs for a short time untill the fluid is consumed. Is the fuel old? Did this bike just come out of storage for the winter? Did someone or something build a nest in the exhaust system?
Apr 19, 2011 | 2002 Aprilia RX 125
A/C is Sutting down my honda eu3000is genarator
Check voltage output of generator at both times to see if different.
Aug 27, 2009 | Coleman Mach III Air Conditioner
Will not start on with out a push. I need help please!!!
electrics are draining it take it too auto electrician you may have bad circuitry
Jul 20, 2009 | Harley Davidson XL 1200 C Sportster Custom...
Genarator runs short period of time & shut down
What type of motorhome & generator is it. Some generators will shut down (basically run out of gas) at 1/4-1/2 tank in motorhome as a feature, to allow you enough gas to get to a station, in case you forget. The fitting for fuel from tank, for generator is placed that way in tank. Is that not the case? Make sure you have at least 1/2 or more fuel in tank of motorhome just to be sure, as we found many that were supposed to be set about 1/4 tank, but were closer to half tank on motorhome.
Jul 20, 2009 | Electrical Supplies
RTO New Yamaha Inverter Ef2400is / Yamaha Generator Ef2400 / Perfect For Camping, Emergency Home Use, Construction Sites And More! Logo
236 people viewed this question
Top RTO Electrical Supplies Experts
Ottoniel
Tom Chichester
Gene Haynes
Are you a RTO Electrical Supply Expert? Answer questions, earn points and help others
