Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Ice Maker Overfills With Water
New Whirlpool ice maker overflows when water fills the ice tray. How do i adjust the water flow for the fill tray? Refrigerator is lever.
    Problem Solver:
  • 15 Answers
Ice maker has adjustment on right side of power head. If ice maker is inside on upper left, you can remove white cover from it and the adjusting screw in on right. Turning counter-clockwise will decrease fill by 1/2 to 3/4 of ounce. Sounds like a small amount, but ice make only uses 4 ounces per fill. If this does not fix, try replacing fill valve. If ice maker ice bin is in the freezer door, you have to remove cover to ice maker in the top of freezer. Ice maker is screwed into top of freezer and need to be removed to take off cover to adjuster screw. same procedure for reducing water flow time as above.
Posted on Jul 24, 2009
I have a 10 year old, at least Kenmore ice maker overflowing into the ice chest. No obvious adjuster.
Can you locate the Kenmore Model Number? It will look like this=> 321.654987 What I think is the dual water control valve is leaking once it turns off. Here below is a ice a ice maker repair clip on You-Tube where he shows a slug of ice filling the ice maker fill tube. In most cases replacing the water control valve will stop the continued water flow to the ice maker once the ice maker fills. I will be here to answer any questions you have Thanks Sea Breeze
Apr 15, 2013 | Refrigerators
Ice maker
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
other ice maker related issues and solutions:---
Ice maker dispensing ice with black or white plastic pieces in ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-ice-with-black-or.html
After replacing ice maker assembly, ice is not getting made?
http://alltypesofpartsreplacing.blogspot.com/2011/10/after-replacing-ice-maker-assembly-ice.html
Ice maker is leaking water and causing the ice to freeze?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-leaking-water-and-causing.html
Ice maker is noisy and not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-noisy-and-not-making-ice.html
Refrigerator ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/refrigerator-ice-maker-stopped-making.html
Ice maker leaks water into ice bin causing a glob of ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaks-water-into-ice-bin.html
Amana Refrigerator leaking water from ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/amana-refrigerator-leaking-water-from.html
Ice maker leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaking.html
Ice maker is dumping the ice cubes out before frozen solid.
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-dumping-ice-cubes-out.html
Water overflowing ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflowing-ice-maker.html
Ice cube is getting stuck up hard in ice maker
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-cube-is-getting-stuck-up-hard-in.html
Icemaker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/icemaker-quit-working.html
Quit making ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/quit-making-ice.html
Water leaking into ice tray, frozen glob of ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-leaking-into-ice-tray-frozen-glob.html
Not making ice, and water leaking in freezer?
http://alltypesofpartsreplacing.blogspot.com/2011/10/not-making-ice-and-water-leaking-in.html
The ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice_20.html
Ice maker not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-making-ice.html
Ice maker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-quit-working.html
Ice maker dispensing black pieces of plastic in the ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-black-pieces-of.html
Replaced Ice maker but its still not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/replaced-ice-maker-but-its-still-not.html
Ice maker leaked creating an ice block?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaked-creating-ice-block.html
Ice tray leaked?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-tray-leaked.html
Ice maker stopped functioning?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-functioning.html
Ice maker stop working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stop-working.html
Ice maker failed
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-failed.html
Old ice maker stopped working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-stopped-working.html
Old ice maker started leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-started-leaking.html
Ice maker not working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-working.html
Ice maker overfills and cause water to flow into ice dispenser and freezes?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-overfills-and-cause-water-to.html
Ice maker didn't make ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-didnt-make-ice.html
Ice maker was leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking.html
Ice maker was leaking after it filled up with water?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking-after-it-filled.html
These will help.
Thanks,.
Dec 21, 2012 | LG LFX25976ST - 3-Door French Door...
Water over flowing when filling ice tray
If the water is contionusly flowing it will create a big mess of frozen water in and below ice maker. This is most times cause by a leaking=> D7827204 Water Inlet Valve
If the water just fills a little too much the amount can be adjusted as described in the Whirlpool Ice Maker Troubleshooting PDF I will be here should you have additonal questions, Thanks Sea Breeze
May 03, 2012 | Amana Refrigerators
Large mass of ice cubes frozen together in tray, most likely from leaky ice maker. Can this be fixed without purchasing a new ice maker.
have you checked it when it's filling to see if it's overflowing or the heater on the ice maker might not be shutting off and melting some of the cubes but you have to check,also it could be the water valve,see if there's an adjustment on the ice maker,look in your book,some of them have an adjustment,try to adjust it so less water is coming into the ice maker but to answer your question you might need a new ice maker or a water valve,the only way to tell is to watch it when it fills to see what's happening,you can pop off the cover to the ice maker and jump it out with a piece of wire,in the bottom right hand corner you'll see two holes close together,t and h stick the jumper wire in those two holes and the ice maker will start up,watch it until it fills,if it overflows try the screw to let less water into it,if that doesn't work then it's gonna be the water valve letting to much water come into the valve
Feb 11, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a Model ET18ZAK with icemaker. The ice
There is an adjustment on the side of the IM face to set fill time. Either that or partially close the saddle valve to cut back on the water flow.
Eric
Oct 17, 2009 | Whirlpool Refrigerators
Brand new ice maker, water fill to tray will not shut off
The new ice maker should tell the dual water valve on rear of refrigerator to turn on if the tray makes a complete cycle. So the new ice maker is defective or the water valve on back is stuck open that leads up to the ice maker. Unplug the wires to the water control valve on back of the refrigerator and then turn the ice maker on. If the water continues to flow I recommend replacing the water valve. If the water stops coming to the ice maker I recommend returning the new ice maker. You only need to unplug the side of the water control valve leading to the ice make. I also recommend a pre-filter for the incoming water before the water control valve. Makes the water and ice better and keeps trash from damaging the water control valve. Let me know your results or if you need more assistance, Thanks, Sea Breeze
Jul 14, 2009 | Whirlpool ET8WTKXK Top Freezer...
Ice maker over fill, water keeps running
If water keeps running to the ice maker all the time even when it doesn't call for water , the water valve for the ice maker is leaking(located in the back of the refrigerator,bottoom right),but if overflow only when it calls for water(no more than 7 seconds) the problem is in the ice maker control board, you can replace it but it will cost almost as a new ice maker.
Apr 14, 2009 | Refrigerators
Ice maker water overflow
ITS BEST THAT YOU GET A TECHNICIAN TO SOLVE THIS FOR YOU AS ADJUSTING THE WATER FLOW ON THE ICE MAKER CAN BE A BIT TRICKY.GOOD LUCK.MOHAMED
Sep 02, 2008 | Whirlpool ED2FHEXN Side by Side...
Water doesnt stop after ice tray is filled
there is a micro switch in the ice maker motor module that shuts power off to the ice-maker water valve when the ice maker is full but i rarely see them go bad this is the easy way to deal with it pull the unit out unplug both the valves and turn the water on a sec if its running in the ice maker with the valves are unplugged then replace the valves if its not replace the ice-maker motor module
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Ice maker # S10626636 water level adjustment
IF THE ICE MAKER IS OVERFLOWING, THE ADJUSTMENT SCREW WON'T HELP. ON MODULAR ICE MAKERS, THE BIG
WHITE GEAR ON THE FRONT BEHIND THE COVER HAS CIRCUIT TRACES ON ITS BACKSIDE THAT WILL ARC, BURNING THE PLASTIC GEAR, BRIDGING THE FILL CIRCUIT WITH ANOTHER TRACE, MORE THAN DOUBLING THE FILL TIME. THE MODULE NEEDS TO BE REPLACED. (GEAR IS NOT AVAILABLE BY ITSELF).THE MODULE IS THE SQUARE PLASTIC ASSEMBLY MOUNTED TO THE FRONT OF THE ICE MAKER WITH THREE SCREWS. INCLUDES THE MOTOR.
Mar 27, 2008 | Kenmore 53552 / 53554 / 53559
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
1,183 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
