Question about Boating
Need to install the prop but doesnt seem to fit, i didnt see it come off so unsure if i am doing it right will neeed full detail on parts and assembly to make sure all correct parts were sent with the unit its a 1969 55 hp evinrude
  • 677 Answers
Mate.If the motor was rebuilt and maybe the prop had a new bush put in it,it could be the wrong spline was put in the prop hub.Or wrong diameter.Without more info,this is a guess.hope this helps
Posted on Jul 23, 2009
Okay there's hoses for the parking brake, how do they cconnect? Do I need to buy some type of connector? Everything under there is rusted.
The flexible hydraulic brake hoses are for your primary brakes both front and rear. The brake hoses are manufactured with metal fittings on both ends ready for fitting as shown in these examples.
Toyota Brake Hose Parts for Wholesale Pricing
If you are unsure of what you are doing (as it seems you are unsure) you should not be working on your cars brakes but have a competent professional do the essential brake work..
Nov 24, 2015 | 1989 Toyota Camry
I took the cover off to see if my prop. was jammed, but nothing. When I spin it manually it's hard to turn & snaps quickly to where it started.
you have put this in spa and pools catagory but it would be as an outboard question
re-ask the question in the right catagory with full details of make ,model and prop mount procedure and any other details like gear selection problems ,noise etc
Aug 28, 2015 | Pool & Spa
Cannot remove a constant speed prop from a lycoming engine
What sort of Prop do you have and what engine model is it fitted to?
Jan 25, 2014 | Sport & Outdoor - Others
Danby mini fridge model dcr054w has stopped working the thing in the back is extremly hot and the fridge no longer gets cold, i turn the knob and i hear a click but the fridge doesnt actually turn on. the...
This is a problem with the 'Motor Run Capacitor'
What you suggest is exactly what happens when this part fails.
Unplug - and look carefully around the connections to the compressor - there should be a cylinder with 2 connections on it. Read what value it says (like 250V 50pf) - and order a replacement from a parts store.
Fit it any way round - it doesnt matter.
plug back in and should work 100%
Cost about - $5
Dec 27, 2010 | Microwave Ovens
Mercury outboard problem
If you have a spare prop try it. The prophub of your current prop may have a bad Rubber bushing. There are some OMC units which have a 2 piece design that still has the Rubber bushing but the prop is a separate piece and the inner hub is sold separately.
Most Mercs have the Rubber hub as part of the prop. The Rubber hub in any case is taking the place of a shearpin. The Rubber starts to slip or crumble and then you can't go anymore. Sometimes the damage is visible but only sometimes.
For the 1 piece system the Hub needs to have a new Rubber bushing installed at a Prop shop. With luck, the prop is your only problem.
Aug 02, 2010 | Boating
Ive got an angle iron to fit but unsure how to install in it.im taking the window out and putting french doors in the solder bricks on top of window are lose hence the iron im just unsure how to fit it
The horizontal part fits into the side bricks--you need to remove mortar to allow it to slide in. The upper bricks need to be reset on top of the iron in fresh mortar. Hope you bought a heavy piece of iron to span the distance and support any weight above.
Oct 24, 2009 | Saws
Bugaboo Cameleon Fitting a replacement brake shoe
take it to www.buggypitstop.co.uk they will be able to repair it for you and they sell new or second hand spare parts.
Mar 05, 2009 | Bugaboo Cameleon Jogger
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
