Question about Altec Lansing VS3251 Speaker
Woofer not working
There is no sound at all from my creative woofer. All other five speakers work. What can be wrong with the woofer ?
  • 108 Answers
If you can open the cabinet of your woofer box please check all the wires connected to the woofer and use a multimeter to check the continuity of woofer coil.If shows no continuity replace the woofer
Posted on Jul 23, 2009
The woofer doesnot work and the horn is working but not as usual
First you need to verify that there is nothing wrong with your amplifier. Simply swap speakers around and see if the fault follows the faulty speaker or stays on that channel. If the speaker is at fault I would hazard a guess and say, that the woofer has burnt out and is now a high resistance. This would then increase the total impedance of the speaker circuit and make the horn speaker sound the way you described. This can be verified with an ohm meter. Total impedance should be about 4 to 8 ohms. The only real remedy is to replace the faulty speaker woofer. Sorry
Mar 07, 2015 | JBL EON 15-G2 Powered DJ Speaker With EQ...
My Intex 6500 Watts Home Theatre's woofer is not producing its original sound. However, my five speakers connected to the Woofer and doing well and when I put it on 5.1 channel, all the five speakers are...
The sub is basically an amp in itself. So if you have no sound the main amp inside it has failed. If you can fix it yourself go for the part first that has a heat sink on it.
Nov 11, 2017 | Audio Players & Recorders
MX6050D Subwoofer Issues
Hello, welcome to Fixya!
Fault is either from the main system or the sub-woofer itself.
You need to test both unit in order to detect which of the two is giving the fault, so that you can concentrate on the faulty unit.
Test the woofer with a AA battery or any other battery. Put your ears close to the woofer and observe if you will hear any sound. If the woofer makes sound, then it means the woofer is working, but if it doesn't make sound, then it means the woofer is defective. Or you can disconnect one of the working speakers and connect the woofer to that part. If there is no sound, then obviously, the woofer is defective.
If the woofer seem to be working, then the unit needs to be tested also.
Connect one of the working speakers to the sub-woofer's section of the main unit. If the speaker doesn't bring out sound, check the system's menu settings, check the volume and make sure the sub-woofer volume is raised to the highest level and not on mute. ( Note that most Theater systems has separate volumes for each speakers). If the volume is raised to the highest level and there is still not sound from the woofer part, then it means the woofer channel has burnt. It could be a fuse or a defective channel. At this point, I think you need help from a repairman.
I hope the above is clear.
Regards.
Nov 17, 2011 | Audio Players & Recorders
I have creative inspire T6100 5.1. my working window is widow 7 in my pc. In sound test all the speaker are working but when i play songs then the center woofer & 2 rear woofer not working. they dont...
You may have to enable the additional speakers by entering the Creative software, which should have come with your sound card. On my system I left click on the Creative volume panel and the choose console launcher. After entering the Console Launcher you can change the speaker setup.
Feb 27, 2011 | Creative Labs Sound Blaster Live! 5.1...
My creative speakers woofer is damege plz repair woofer.
sir I am using 2.1 creative inspire speakers system, at present no sound is coming in the speakers or woofer, what is the problem.
power is on and after connecting the speakers to woofer from pc no sound is coming. what is the problem. please help me. thanks rajanna
Jun 01, 2010 | Creative Labs Inspire 6600 Computer...
Creative SBS A 500's woofer, rear right is not giving sound.
A weak conection inside speaker or other conections.
Aug 20, 2009 | Audio Players & Recorders
Creative woofer prob.
no software for that creative. change the amplifier IC inside woofer which is the out put of all speakers.
Jun 10, 2009 | Creative Labs Speaker SBS330 2.1 Channel...
Sound problem with Creature II Woofer.
just increase subwoofer level located at the front. If it doesn't work then replace your woofer if it is in warranty period because it migth be due to internal electronic components failure.
Jun 17, 2008 | JBL CREATURE II Computer Speakers
No sound from woofer
You have to set one of the audio ports as sound and not Mic
May 16, 2008 | Altec Lansing VS3251 Speaker
Center & sub-woofer problem
The outputs may have died if this is the case you will need to get them fixed by a proffesional
Mar 15, 2007 | Creative Labs Inspire 5200 Computer...
Altec Lansing VS3251 Speaker Logo
699 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
