Question about Philips Magnavox 20MC4304 20 in. TV/VCR/DVD Combo
Magnavox TV/DVD/VCR combo keeps turning off
You turn it on, something in the vcr makes a bunch of clicking noises and then the tv turns off. Apparently there are some safety censors? Is there anyway to bypass this? No one uses vhs anymore so I can care less about it.
So after calling a tv repair guy and listening to him tell me about how it is probably something to do with the transistor and it will cost me about 150 dollars to fix ( which I could buy a new tv for that price since it is only a 19 inch) I decided to look online at this issue of turning off after 5-10 seconds. I read about it being an issue with the VCR sensor, so I don't know about it being some LED that you have to replace because I just messed around with a VHS and moving the little white bar thingy on the right just inside the door for the VHS around a bit, and Voila it started working right again. I think maybe my son tripped something by sticking things in there and whatever I touched fixed it. So my advice is to just stick a VHS in and take it back out a few times and play with a few things inside and to the right. It didn't take long for it to work for me.
Posted on Feb 18, 2010
  • zooqueen
    zooqueen Nov 26, 2014
    Thank you! It is 11-25-14. Needed to use this old Magnavox DVD/VCR combo. Turned off after 5 sec. It's crazy! I read your post & did just what you said. We stuck things in (didn't know what we were doing) AND IT WORKED! This old TV still has life left! It just keeps showing "REWIND", "STOP" & "EJECT"....I can live with that! You are BRILLIANT! I like your repair style - I could do it! Thank you so very much! Blessings!
I had the same exact problem. My tv would turn off after about 5 seconds. I solved my problem by putting a vcr tape into the vcr. I don't know how long this is going to last but it worked.
Posted on Sep 30, 2009
The keeping a vcr in the player worked for us for 3 years. As of this week, it just eats the tape and turns off. Next ideas?
Posted on Nov 21, 2009
    Problem Solver:
  • 16 Answers
The problem is simple and the solution easier your problem is a burned out LED on the vcr mechanism its the one on the right if your looking at the front of the vcr I dont know the part number cause it varies between models but I used to work for phillips and it is a very common problem any vcr tech would know that.
Posted on Jan 03, 2010
So my advice is to just stick a VHS in and take it back out a few times and play with a few things inside and to the right. It didn't take long for it to work for me. this is correct, it took me less than 5 minutes thank you
Posted on Nov 10, 2014
Yes, that is all you have to do - just stick a vhs tape in that u don't care to use again, and just leave it in all the time. The tv and dvd will work without a problem. I have been using my tv like this for 2 years now. Only a problem occassionally - if I accidentally hit the wrong button and the vhs tape pops out...lol...then it is a matter of timing - being able to turn on the tv, pop in the vhs tape, and switch to the tv w/o the tape popping out, before it times out and shuts off again....other than that!!!....perfect!!
Posted on Nov 23, 2011
Most likely it is a bad mode switch which is common in Philips TVs. Have a tech bypass it & disconnect the connections to the VCR but leave it in so the IRs will put the VCR section into limbo. This has worked for me. Who uses VCRs anyway?
Posted on Apr 01, 2010
  • belviabrown Nov 30, 2010
    Old people that can't aford new ones
  • Mermaid1110 Dec 12, 2010
    My Magnavox was also doing this. It would turn off when I'd put a tape in the vcr side of the tv. Well after reading many comments online, and being thoroughly confused, b/c honestly I have NO experience dealing with tv components, I put a tape in, and there is a white "thing" right inside the door on the right hand side. I just pushed it in (lightly-not too much pressure) while the tape was in and I pushed play. Then I let up on the white part and the tape came on! I'm really excited about this b/c it's been broken for months. Hopefully it will continue working and not be a one-time thing. Also, I hope that this can maybe help someone else in this dilemma.
    Genius:
  • Philips Master
  • 1,550 Answers
Check the motor charge belt on the vcr when it goes a little loosen make that problem if you can change it
Posted on Jul 23, 2009
Loud static noise without warning
The audio may be randomly disconnecting or something. I know that when my TV has no signal coming in, that it makes a bunch of loud static.
Jun 04, 2010 | Tatung V20KQDX 20.1 in. LCD Television
TV will not turn on
Hi, If the clicking noise is metallic, could be a relay switching on/off. What's curious is that once powered on by remote, apparently the clicking doesn't affect the TV, meaning it continuously work. The relay is suppose to turn on or off a function of the TV and apparently it is trying to but there is not such effect since the TV, as I understand from your post, works. The relay can be for the degaussing coil, power supply, over voltage protection. Since this involve a little diagnosis of the electronics, soldering and probably a minor component replacement, an on-site service/repair man would be your best bet. Even if it were a nuisance/minor repair, you can at least get the clicking noise out. Other than you get to get a checkup of the TV and diagnosis of what caused/started the clicking sound in the first place. Hope this be of help/idea. Post back how things are or should you need further information. Good luck and kind regards.
Aug 27, 2007 | Zenith C30W46 30" TV
VCR making noise and won't take tapes
THE VCR SECTION WILL NEED LUBICATING INSIDE THE TV WOULD OF DRIED THIS OUT DUE TO THE HEAT FROM THE TV OVER TIME.THERE IS A LOT OF MOVING PARTS IN A VCR A MUST ALL WORK TOGETHER.
Apr 24, 2010 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Makes repeated popping/clicking noise when plugged in. like the sound it makes when first turned on.
sounds like the power supply is oscillating or the safety circuits are shutting the supply down and the restart circuits are starting things up again. Either way, you need to have this TV inspected by a professional repairer. The power supply is capable of supplying several hundreds of volts, more then enough to give you a nasty shock or KILL YOU !!!! The safety circuits are there to shut the tv down if something goes wrong, which can include dangerous levels of x-rays and other electromagnetic radiation, a faulty flyback transformer or EHT transformer can cause a fire.. So please, have it checked by a qualified tech..
Dec 25, 2009 | JVC AV-36D303 36" TV
VCR/Cable TV Connection
I guess you are using the cable TV feed looped through the VCR to the TV set.
Make sure you did not confuse the in and out loop of the VCR.
In the VCR menu, or on the remote there is usually a button called TV/VCR (Video). Make sure it is in the TV mode to watch the cable. In the VCR (Video) mode, the TV must be on the VCR's designated channel to watch the VCR, and the VCR tuner is used to watch the cable channels.
Jerry G.
May 24, 2008 | Televison & Video
TV SHUTS OFF BY ITSELF
there is a infra red emmiting diode inside that has failed. this is the diode just under the prism inside the unit. replace that and re-time the mode switch. the unit is not made by philips but by funai so no support can be given to you from philips. I've repaired close to 60 of these with the same problem you have.
Feb 20, 2008 | Philips Magnavox DVD/VCR Dual Player
VCR repeatedly tries to play and eject when tape deck is empty
the tape carriage is probably stuck, or something stuck inside blocking the tape sensor.
feed a tape in and see if it does it "with" the tape too
hope this helps
Jan 08, 2008 | Sylvania 6313CB 13 in. TV/VCR Combo
Sylvania combo tv/vcr turns self off
Same exact problem with my Sylvania combo.
Sep 25, 2007 | Sylvania 6319CE 19 in. TV/VCR Combo
Philips Magnavox 20MC4304 20 in. TV/VCR/DVD Combo Logo
6,160 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
