When I put the timer on spin cycle the machine will pump the water out and then gives a F 50 code. It will not spin out. Even with nothing in the tub.
  • 2 more comments
  • t58scouter Jul 23, 2009
    This problem with the F 50 code is on a Whirlpool Cabrio washing machine. Model wtw6300swo.
    I have a WHIRLPOOL CABRIO
    I have a WHIRLPOOL CABRIO washer that will not spin, even when I put the timer on spin cycle. It will pump out but not spin. Even with an empty tub.
    We will see.
  • 601 Answers
HI..
Hope this is Maytag washing machine.F 50 is a control issue and needs to be replaced
3 screws in back of control panel pull top forward control is on the right part #w10189966 its about $160 to $190 easy to change.
Thanks
Smith
Posted on Jul 23, 2009
Affinity washer wont work on a normal cycle only delicate
looks like the windings on motor are burnt out , motor has different winding for different cycles
Mar 20, 2012 | Frigidaire Affinity ATF7000E Front Load...
Hello I have a Maytag Washer Model A512 The machine goes through a regular cycle OK - However, it DOES drains the water out during the rinse cycle, but does NOT drain the water out during the spin...
The timer will always advance to the next program if the machine does not fully drain. There is ALWAYS a spin when draining the water out, there is only one pump and one motor. The waterlogged laundry maybe telling the timer that there is still water in the tub. Put the machine on "Spin" and cheat the lid switch into thinking that the lid is closed. Use a clothes peg or wide ended screwdriver and see if there really is a spin....
Apr 07, 2017 | Maytag Neptune MAH5500B Front Load Washer
No error codes-washes but does not spin- water stuck in bottom
If your machine is a FAV6800A to FAV9800A here is the Service Manual.
If you lift the washer lid and rotate the wash basket CCW which is the Spin Cycle direction will it turn with very little resistance? It should not rotate CW.
With no error codes I would go to Service Mode page 14 of the Service Manual and read the current recorded Daig codes and write them down then clear the list.
Now start a Spin Only cycle with no clothes in the wash basket let it in that mode for about 5 minutes. Hit the off button to end the Spin Onlly cycle then check the Diag code block and see if an error event was logged if so please let us know.
If there is no error code generation by the Control Board in the Diag code blocks I would suspect a Control Board issue with your no Spin issue..
Without a known good Control Board and Motor Controller to swap out and no error code generation by the Control Board this would be a hard problem to troubleshoot.
The Control Board is under warranty for 5 yrs you could try Maytag Customer Service the number is in the SM and see if they will send you one even if the warranty is up…..Rich
Feb 06, 2010 | Maytag Neptune FAV6800AW Top Load Washer
HELP!! Washer machine wont work. Doesnt drain or spin. Clicks to drain and spin but nothing happens, the timer still counts down as if everything is fine.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
If the machine starts, fills and goes through its' agitate cycle fine, the problem is likely not in the motor or transmission.
This type of washer uses a reversible motor. When turning one way, the machine agitates the clothes.
When the timer gets to the spin cycle, the motor reverses, drives the pump (directly from the motor) for a period of time and then goes into spin cycle.
This appears then that is is either the connection to the motor itself or the timer.
The timer is driven by a separate motor on the control panel so if the contacts for the spin cycle are worn, the timer will move but the motor won't turn on.
Sep 09, 2009 | Washing Machines
Won't advance to spin cycle from drain cycle
install new timer....thumbs up...
VE6GAR 73 88 99
Aug 10, 2009 | Washing Machines
CROSLEY CAH4205AWJ FRONT LOADER WASHER
I know it's been a while since you posted this, but I thought I'd put an "answer" in here in case someone else stumbles across this post when trying to figure out what is wrong with their washer.
I'm not sure how to put it in service mode, but the problem is likely with your water pump. This pump pulls all of the water out of your machine before it goes into spin mode. If the pump doesn't engage then the washer won't spin. You likely need a new pump. They usually cost around $50 and are pretty easy to install. But if you have standing water in your machine, then you are going to have a mess when you pull the hose off to disconnect the pump. I'd suggest having a shop vac handy to **** up all the water as it comes pouring out of the Tub to Pump Hose. A towel isn't going to cut it. You're going to have lots of water that you don't want all over your floor.
Feb 22, 2009 | Crosley Washing Machines
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Won't pump out water at the end of wash or rinse cycle.
I don't know this model at all, but hada similar set of syptoms on an electrolux .....
Just a thought, but have you checked the pump chanber is not impeded by a stray hairgrip, or bit of wire?
The fact it doesn't pump when it should, but allows water to pass when the centrifugal force of a spin cycle builds up, would indicate that maybe its the pump that either has a jammed impeller, or a blown motor (or fuse).
Feb 15, 2009 | Kenmore 23822 Top Load Washer
Frigidaire LTF2940ES Hums
sounds like something is stuck in drain pump
washer will not go into high spin untill water is pumped out
Jul 20, 2008 | Frigidaire GLTF2940ES Front Load Washer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
