all this is in the tool box, my wife just gave me this same GPS for Christmas
Ok turn it on, touch the "Wrench" symbol, in the next screen there is another "Wrench" symbol touch that, in the next screen touch the gear symbol marked "System" in the next window it will say "Key Board layout" touch that the next screen shows "ABCDE" AND "QWERTY" select Qwerty and then touch OK. any other questions call me 925-577-7157
As far as the voice goes inb the same window as the System select the "LIP" symbolt in the next window u will see "VOICE" select tha and then select this setting "American English-Samantha (TTS)" this will enable the voice that speaks road names and streets.
Your display will only show ice or off. There is no temperature settings.Now when I give the directions to put it into clean make sure the green led above the symbols is on steady. If you hold down the on/off key and hit the light key 3 times then release the on/off key last.(give a 1/2 second delay from releasing on/off key. It should go to CL. If led lights dont comeon then let me know.
The F24 error show that the sensor in the ice maker is out of normal ranges. The usual fix is to replace the sensor in the ice maker. Also worth checking it to see is the water to the ice maker has frozen up in the value (switch the fridge off for a day). If the error still exists after that you will need to replace the ice maker sensor. You have a 2 year warranty on these parts so the fix should be free.
