Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Craftsman mower with 20hp B&S Intek won't start/run
I have a Craftsman riding mower with 20hp B&S Intek engine. A few days ago, I made 3 or 4 passes (10 mins.) mowing when engine "bogged down", sputtered and popped, coughed out black smoke and quit. Now, engine will turn over and try to fire, but won't run - just "pops".
I have checked flow through the fuel filter - it's OK. I have removed and cleaned spark plug, as well as cranking with plug out to check spark. Also tried spraying starting fluid into carb - engine started and ran for few seconds, so it's getting spark.
One sidenote: the throttle linkage doesn't look to me like it's operating correctly; when you push the throttle handle up (to fast or choke), the cable slides normally, but nothing actually moves the throttle lever on the carb.
Engine ran fine before this. What else should I check?
Thanks,
Robby R.
    New Friend:
  • 32 Answers
Sounds like you have gone through all the rights steps. if you can fire on starting fluid you have a fuel problem in carb. most likely picked up some dirt into your jet inside you bowl area. take carb off and shoot carb cleaner through all orifices real good and try again. there are plenty of movies on youtube on how to clean a carb on riding mowers. hope this helps.
Posted on Dec 13, 2013
  • 1,305 Answers
That throttle cable issue sounds like it may be the culprit. the cable housing (the outer casing for the wire throttle cable) may not be anchored correctly. Which may be allowing you to move the throttle without any change at the butterfly control on the carb. make sure the cable housing is anchored at both ends.. by the throttle control and at the carb area.. That may be your problem... hope it is that simple...
K
Posted on Jul 23, 2009
Craftsman ys4500
pull the fuel hose and check for fuel flow to the carby
check all safety micro swiitches
Mar 31, 2017 | Garden
Why won'y my 20hp Craftsman Yard Machine riding mower start?
when changing the belt you might have knocked off a wire to a safety switch
Apr 17, 2012 | Yard Machines Garden
B&S 20hp craftsman 46" dls3500
When you cleaned the carb did you clean out the metering jet with a needle and blow out. It only takes a tiny spec of dirt to raise hell with these small carbs.
May 29, 2011 | Craftsman 42" Briggs Stratton 20 hp Gas...
I have a craftsman Dlt 3000 riding mower with a 20hp kohler v twin . engine starts and runs for 5 seconds and shuts off
no model # on my DLT3000. Replaced rear fender a few years ago where the model # used to be. I can't get the right parts w/o model #. It was by my dad sometime between '04 and '07. It's red w/42" cut, 20hp koler pro motor.
Sep 18, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Briggs 20HP Intek sputters under load
reset the valves to specifications by gaping them all to .008 thousands The vibration will continuely make the gap wider causing this problem to get worst. Gap the valves is recommeded every other year
Jun 14, 2010 | Briggs & Stratton Briggs Stratton Intek V...
What engines will fit craftsman dyt 4000 (18.5 blew w/ 290 hours)
Hi there
The only thing you have to do is have the size (diameter) and lenght (from cranckcase to end of shaft) of the shaft you have on your b&s and just go to your local Honda dealer , give them your shaft size and they should be able to give you all the options for a brand new motor . I really believe you can get a Honda 20hp model GXV620 or a 24hp model GXV670 that will replace your B & S motor .
Hope this help .
Sep 01, 2009 | Garden
Have to hold chocke out to keep it running
sounds like the needle and seat is dirty within the carb
Aug 11, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Intek engine runs poorly under load and when warm
if you have a ohv ajust valves and you might have to rebuild carb.
Jul 18, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
1,012 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
