Question about Polaris 380 In Ground Pool Cleaner
Atv keeps back firing
My atv keeps back firing when i turn it offcan anyone help???
  • david filippelli Jul 24, 2009
    i just replaced it? but the sponge on the filter is pretty thick you think that could be it??
  • 305 Answers
Sounds like the fuel mixture is too rich, check for a clogged air filter
Posted on Jul 23, 2009
  • jim galbraith
    jim galbraith Jul 24, 2009
    yes it could be, they are pretty sensitive when it comes to the fuel mixtyre
  • 114 Answers
It could be the a/f mixture or fuel starvation. Try to check the fuel filter than re adjust the a/f screw.
Atv windshield
Posted on Apr 03, 2013
I turned off the motor and went back to start it and there was no fire to the plug what could it be 2006 suzuki 4x4 atv.
if turn over no spark check battery,plug , plug wire , wiring and cdi if no turn over check battery , fuse,switch,cut out switch
Jun 22, 2017 | ATVs
How to Adjust idle circuit? Why does it start, but does not keep running.
2 stroke or 4? if 2 stroke definitely jetted wrong choking makes it rich tells me your main jet is too lean (smaller hole) you need to pull carb check jets for plugage clean jets write down numbers check dealer for correct jet size for your elevation if 4 stroke back fire thru carb indicates timing is off or bad intake valves or cam lobe worn
Oct 03, 2016 | ATVs
2005 Ranger 500. Why won't it crank?
JF. Timing out, valve adjustment.
Check the attached links,Manuals and guides, Good luck with your Bike
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
ATV TROUBLESHOOTING AND MAINTENANCE
ATV Service and Repair Manuals
http://www.carlsalter.com/motorcycle-manuals.asp
Jan 08, 2016 | Polaris ATV
We have a 1999 commodore vt sedan an we just put new battery an alternator in it last week an the battery light just came on an now it wont go offcan anyone help please
The battery is charged by the alternator which has computer (PCM)controlled voltage regulation, this makes for a much more precise engine and stable voltage for the engine management system.
Mar 25, 2014 | 1998 Holden VT Commodore
I can't get my kfx 700 to idle by itself. I have to push the throttle to keep it on but when I let go the throttle it turns off. The atv was not used for several months. I clean the carb before I could...
easiest thing to do is adjust your nut on your throttle wire since its thumb its right there one your thumb caseing that covers your cable loosen outer nut a couple of turns then back center out 3 or 4 turns fire up adjust as needed
Jun 07, 2011 | kawasaki Jet SportX 50 SR Motorcycles
Atv back fire
when to turn it off, the spark plugs stop instantly but the fuel is still sucked into the combustion chamber. your idle might be adjusted too high. try using a higher octane fuel
Jul 23, 2009 | 1971 Aermacchi Sprint 350
MY MOTOROLA SLVR WONT TURN ON
Maybe your battery needs to be charged. If you tried that, then the battery is probably dead and you have to buy a new one. Maybe the battery is old too.
Dec 30, 2008 | Cell Phones
Polaris 380 In Ground Pool Cleaner Logo
110 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
