Question about Westinghouse 22" Widescreen LCD Flat Panel Monitor
Westinghouse 22" Monitor requires me to press side power button
This is inconsistent, and the Monitor behavior after several times I press the power button on the right side of the screen, a "good" screen appears wirh the word D-Sub. The Monitor is then fine, until I either shut off the computer, or it goes on standby. Bringing up the screen then only gives me a white screen, until I go thrru the process of pessing the button on the lower right of the screen frame. I had this Monitor problem on my older HP Computer. And it followed me in my use of my new computer. I can live with it, but it is annoying. Does the D Sub message mean I need a new D-Sub cable, or is it a short in the Monitor?
  • ljwellerjr Jul 23, 2009
    You ask for a Westinghouse 22" Monitor Model Number. It is Model LCM-22w2, from the Monitor's back. Anything more?
  • ljwellerjr Jul 24, 2009
    I will follow your suggestion on the use of the Menu. What Menu, and how do I get to it? LeGrand
    Brigadier General:
  • 7,191 Answers
Please provide us with the model number and other relevant information which would help us to solve your problem. Thanks.
Posted on Jul 23, 2009
  • AliTech110
    AliTech110 Jul 23, 2009
    Firstly check all the connecting cables, remove and reconnect the monitor cables securely to the PC.
    The "D-Sub" word is indicatind that the monitor is connected through the D-Sub input. If this On-screen display(OSD) appears for a long time, you can reduce the duration of OSD by opening Menu, then scroll down to Miscellaneous Menu, then select OSD Time-out, and set the duration according to your preferrence.
    Also, regarding the white screen, it seems the monitor power supply is faulty and needs to be serviced or your monitor needs to be replaced. You can try and reset the monitor to factory settings by selecting Reset in the Miscellaneous menu.
    Hope this solves your problem. Thanks
  • AliTech110
    AliTech110 Jul 25, 2009
    Hi LeGrande,
    Thanks for the feedback and apologies for the delayed response.
    To enter the MENU option, press and hold the button number 5 shown in the image and follow the instructions in the attached images below:
    When the Menu opens, scroll down to Miscellaneous Menu option, to change the duration of the OSD menu. Also you can Activate the Auto Setting and Reset to Factory settings as shown in the images below:
    Thanks you once again,
    Regards..
Starts inconsistently. When pressed the start button flames and the the power button needs to be turned off. It often takes several tries to get it started.
Richard, it could be a unresponsive control to reboot the unit unplug power cord from wall a couple of min's and plug back in. I would ask if you are gently holding start button in until you here a click then release the button. as the start button is depressed it is a time process to enable to processor to think... let us know.
Apr 19, 2014 | Whirlpool Duet GHW9150P Front Load Washer
My westinghouse monitor won't align on the screen. i have tried auto adjust already and it is still missaligned.
Ok, with the Auto adjust, but have you actually tried the buttons that actually manually adjust the screen, size, placement, width, height etc, This will allow you complete control over all aspects of your monitor. You usually select, menu, then step through with one button, and change up, down, side to side, with the left & right buttons.
Mar 02, 2010 | Westinghouse 22" Widescreen LCD Flat Panel...
Monitor Brightness
most user manuals for these moniters you can get on line (free downloads)
it will explain how to use the buttons on your monitor
Feb 02, 2010 | Westinghouse LCM-19v1 Monitor
L2210nw volume display on screen won't go away
Upgrade to Windows 7. It will take care of this problem immediately
Sep 15, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
Get rid of volume bar in middle of screen
I had this same problem a while ago. It was because the top "touch" button on the side was being triggered at a rapid rate. I took mine back to the retailer because it was within the Westinghouse 1 yr warranty. After getting a replacement display (same Westinghouse 22 in), I have had to take it apart because of a bad video processing board. In doing so I have seen that the side buttons are very easy to get to and fiddle with. If you are out of your warranty period, perhaps try taking off the case of the display and fiddling with the button board and connections
Jul 02, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
I think I also have a bad power board.
Could be a bad fuse in the powerboard,ore look for bad caps...
Jun 09, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
Buttons no longer work--power and OSD menu buttons don't work
I had the same problem. In frustration after trying everything else as I couldn't shut the monitor off, I shut the computer down, unplugged the power to all, and left it until this morning (12 hours). Now it works, so it must reset itself. I am waiting for feedback from their support as well but imagine they will tell me the same, good luck.
Jan 18, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
Monitor shuts off after inactivity
Hi maggieis,
I wouldn't worry about your monitor powering off after 30 min. It's just responding to the power management settings that are configured from within Windows.
These settings can be changed so that your monitor always stays on (if you want) but the current setting is set to help save energy by turning off the monitor when no one is using the computer.
So, no worries...that's just normal Windows behavior.
Hope that helps,
Michael
Nov 19, 2008 | Westinghouse LCM-19v1 Monitor
Westinghouse LCM-19W4
I had the same problem with my two LCM-19W4 monitors. Both failed within two months of each other. Radio Shack stocks 220uF 35V capacitors that work fine for this. You have to pay $1.49 ea though.
Nov 02, 2008 | Westinghouse LCM-19v1 Monitor
Westinghouse 22" Widescreen LCD Flat Panel Monitor Logo
133 people viewed this question
Top Westinghouse Computers & Internet Experts
Matthew Spark
Matthew Spark
Iqbal Husain
Iqbal Husain
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
