Question about Sony KP-51WS520 51" Rear Projection HDTV-Ready Television
TV standby flashes 10 times first, then 9 times
My Sony KP-51WS520 standby light flashes 10 times when it's turned on, then keeps flashing 9 times after that. Does anyone have the same problem and how did it get it fixed?
Thanks for your help in advance!
  • 668 Answers
I believe you have a "G" Board failure. If I am thinking correctly, when you open the lower cabinet back, you will see a smaller Board that the AC Cord plugs onto. Their is not a lot of components on it but it will cause this same symptom. This Board according to Sony at last inquiring is not available but they will refurbish it if you send it to them. The best way to do it is to work with a Sony Service Facility, have them come out and confirm it is bad, then they could send it in and reinstall it when it gets returned. ETA on something like this is 3-4 weeks.
I hope this helps,
Skyassoc
Posted on Jul 25, 2009
I have sony wega sony wega tv kp 51ws520 no turn on just standby light blinking and i lost remot plz help me
Is the light blinking 9 times? If so thats a very common problem caused by failed diodes on the G board which will need to be replaced.
Jul 19, 2011 | Sony KP-51WS520 51" Rear Projection...
My Sony KP 51W520 won't come on. The standby light flashes 10 times. I read through the other people's problems listed here and everyone else has had either 3 blinks or 9. Any thoughts?
Hi.
it seems that your power supply or high voltage section is failing. Look for PWM IC genarator. MCZ 3001D on Power supply and near high voltage section. Try to replace these IC's.
Jan 05, 2011 | Sony KP-51WS520 51" Rear Projection...
No picture ,standby flash 10 times and tv turns off
10 times standby flashing indicates problem of High Voltage Protection and need to check following parts in Sony KP-51WS520 rear projection tv.
Q8014 or Q8013 have shorted replace along with R8051 on D Board
IC8005 is damaged (D Board)
Hope these info will help you. If you have no experience of electronics stuff repair then local tv repairman is an option to get help.
Thanks.
Nov 27, 2010 | Sony KP-51WS520 51" Rear Projection...
Standby/light flashes 9 times, what does this means.
call pts electronics replace power board in you tv dont try to fix just replace board
Aug 10, 2010 | Sony KP-51WS520 51" Rear Projection...
Sony kp-51ws520 when turned on just has standby light flashing . the rest is all dead, no picture or voice.
Standby flashing light shows that tv got some internal problem. How many times standby light is flashing is info that provide info about what section of tv got problem.
Count standby light blinks and let me know, there would be 3 seconds long pause in blinks so count pause to pause.
Jul 21, 2010 | Sony KP-51WS520 51" Rear Projection...
Tv wont turn on
You have a zero crossing failure.
Replace diodes D6301 and D6116 on the G board with 1n4002 diodes.
May 17, 2009 | Sony KP-51WS520 51" Rear Projection...
TV will not come on. TV standby light blinks nine times continuously. TV is Sony KP-51WS520
Nine Blinks- Replace D6116 and D6301 on the "G" board, do not solder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative).
Mike
Apr 16, 2009 | Sony KP-51WS500 51" Rear Projection...
10 flashing lights then 9
make sure it is 9 blinking it may be 10
Aug 15, 2008 | Sony KP-46WT520 46" Rear Projection...
Standby flashes 9 times
the 9 flashes means your Diode D6116 or D6301 is open on G board and needs to be replaced ...and your chassis is Ax-1x
Apr 13, 2008 | Sony KP-51WS520 51" Rear Projection...
Sony KP-51WS520 51" Rear Projection HDTV-Ready Television Logo
588 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
