Cranking noise when is turn on
My xerox docucolor 12 copy printer do's cranking nois when is turn on
and it turn off, I have notice that a big black flywheel on the back don't
move.
I got a xerox dc 12 and i have small thin lines formed in most prints from end to end of paper.
Posted on Oct 01, 2008
Have you print/copy many b/w pages from your color printer? you should have an error code on display...e?your copier need service to work again...
Posted on Mar 17, 2008
We had this same problem.
A tech had to come in and replace a cog in the back.
Posted on Jan 10, 2008
Free solution of black bars on paper while printing on xerox dc 12 printer
Most likely this indicates a drum cleaning blade failure. This is especially true if the black Bars run up and down the page and get worse on multiple copy runs. So if you run 10 copies the last one out will be worse than the first one out. If this is the case, cleaner blades are pretty in-expensive at around $40.00.
Good Luck and Thank You for using Fixya.
Sep 10, 2010 | Xerox DocuColor 12 Color Copier
What is the solution of black bars on paper while printing on xerox dc 12 printer
Most likely a drum cleaning blade. If the streaks are verticle, up and down the page and if they get worse as you run multiple copies. So on a 10 page copy run the last copy out will be worse than the first. Cleaner blades are cheap at around $40.00
My xerox dc12 is getting a black line through when i have printed over 5 copies what do i need to do
check that stell rod beside of fuser unit has any black toner just clean that toner
Jul 09, 2010 | Xerox DocuColor 12 Printer
Xerox dc12 printer
You will need a technician to replace a clutch.
May 18, 2010 | Xerox DocuColor 12 Printer
DOTS pattern and WHITE LINE along the page
The Problem is your Copy Print Module it has a scracht on it if you replace the module it will desapear the dots and lines.
Nov 26, 2009 | Xerox DocuColor 12 Printer
Xerox DC12 printing black but copy works fine
Yor probles is caused for a pour conection from the fiery with the printer. Check disconecting and conecting again both conectors printer and scanner
Oct 26, 2009 | Xerox DocuColor 12 Printer
XEROX Docucolor 12 Color Developer PN needed HELP
DEVELOPERS:black 5R616 ; yellow 5R 619 ;magenta 5R 618;cyan 5R617
TONER : magenta 6R1051 ; cyan 6R1050 ;yellow 6R1052
Sep 14, 2009 | Xerox DocuColor 12 Color Copier
Xerox docucolor 12 copy/print printing all black
If you moved the printer, make sure the conections from the printer to the Fiery are secure. If loose the prints will be black but when copying will be fine.
Jul 19, 2008 | Xerox DocuColor 12 Printer
Docucolor 12 error code HELP
9-357.
Black toner problem.Probably You have low toner sensor defect.
But try first to vacuum and clean black toner dispenser.You must vacuum whole path wich is used to transport black toner to developer unit.Then if printing B/W print only, you must print 10 full color sheets every 100 copies.
Sep 13, 2007 | Xerox DocuColor 12 Color Copier
63 people viewed this question
k24674
jasbo
jasbo
