Question about Acer Aspire One AOA150-1983 Notebook PC
My system won't boot because the windows\system32\config\system
File is missing or corrupt and my computer didn't come with disks
    Problem Solver:
  • 5 Answers
If i am from Singnet technical Helpdesk, we are advised to direct you to Acer Service centre if you owned an Acer computer with a serial number and if it is still under the warranty period on Operating system missing, Another option is to contact Microsoft service centre for CD replacement or oprating system advise since they are the suppliers and vendors for fathering the operating system, To troubleshoot your missing files,you need to know pecifically which files are missing and are they registered in your O/S and are they active and running or are they deactivated, takes longer time to solve missing files problems because you did not list what files are missing and you need to tell microsoft what files are missing in our operating system as there are thousand of files in the WIndows operating system
Posted on Jul 23, 2009
  • 201 Answers
Today laptops do not come with disks
but if you hold down control and f10 or f11
the backup on acer is on the hard drive,
you will see system recovery, then just follow through , and it will be like new
HAL.DLL is missing or corrupted, xp doesn't boot
if it was running for more than 30 hours, it wasn't doing much. You can try copying hal.dll off of a known, good-working XP pc, and replace it with the one on your broken PC. It's better if you extract it from i386 folder but grabbing it from another pc should work fine.
Aug 09, 2012 | Microsoft Windows XP Professional
Tip
How To Fixed Corrupted or Missing \WINDOWS\SYSTEM32\CONFIG
If you get the error:
Windows could not start because the following files is missing or corrupt
\WINDOWS\SYSTEM32\CONFIG\SYSTEM or \WINDOWS\SYSTEM32\CONFIG\SOFTWARE
  1. Insert and boot from your WindowsXP CD.
  2. At the first R=Repair option, press the R key
  3. Press the number that corresponds to the correct location for the installation of Windows you want to repair.
    Typically this will be #1
  4. Enter in the administrator password when requested
  5. cd \windows\system32\config
  6. Depending on which section was corrupted:
    ren software software.bad or ren system system.bad
  7. Depending on which section was corrupted
    copy \windows\repair\system
    copy \windows\repair\software
  8. Take out the CD ROM and type exit
on Sep 20, 2010 | Computers & Internet
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
I have an hp mini 210-1041nr running win xp and when I start it, the computer tells me Windows\System32\Config\System missing. I tried service pack 3 but it didn't work. Can u please help?
You need to get a Windows XP from someone and follow these instructions:
1. Insert and boot from your Windows XP CD.
If that doesn't work or you can't get into the repair console then With the XP disk you choose to install Windows XP and when you choose to install over the current XP installation you will be given the option to repair the current Windows installation and you won't lose all of your data.
Mar 01, 2011 | Computers & Internet
All I am getting on a aspire one net-book is windows\system32\config\system error please help as I tried the alt F10 couldn't get it to work
The first step in recovering from this problem is to boot into the Recovery Console and replace the missing or damaged system file with a backup copy. To do this, you will need an original Windows XP CD, or a recovery CD from your computer's manufacturer, or a set of 6 Windows XP boot disks. If you do not have any of these, please visit our tutorial on creating Windows XP boot disks at www.schrockinnovations.com/makeboot1.php.
Once you have booted from your Windows XP CD or floppy disks, press the letter "R" at the first screen asking you for input. The computer will now ask you "Which Windows installation would you like to log onto." Each profile is represented with a number. Press the number associated with your profile (usually the number 1) and press enter. Now you will be prompted to 'Type in the Administrator Password." Enter your password and press enter (if you do not have a password to log into Windows, simply press enter).
After you enter your password (or simply press enter) you should be at a prompt that reads "C:/windows". Type the commands below to navigate to your Windows/System32/Config directory and replace the appropriate file:
  1. cd system32
  2. cd config
  3. ren system system.old
  4. cd .. (note the space after cd it is important)
  5. cd .. (note the space after cd it is important)
  6. cd repair
  7. copy system c:\windows\system32\config
If you were not able to log into your Windows profile in the recovery console, or if you were not able to navigate to the windows/system32/config directory, this likely means that the directory is gone. We have seen multiple reports of this occurring, and there is no discernible pattern that would indicate what is causing this problem at this time. This directory contains information required by Windows to boot, as well as information about your installed programs and saved passwords. If you currently are receiving the error "Windows/System32/Config/System file missing or corrupt," there is nothing you can do to remedy this problem.
Dec 10, 2010 | Acer Aspire One PC Notebook
Problem with OS. How can I fix? Net book states - Windows XP could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM Can you help? Thanks Philip
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:\windows\system32\config\system c:\windows\tmp\system.bak
    copy c:\windows\system32\config\software c:\windows\tmp\software.bak
    copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
    copy c:\windows\system32\config\security c:\windows\tmp\security.bak
    copy c:\windows\system32\config\default c:\windows\tmp\default.bak
    delete c:\windows\system32\config\system
    delete c:\windows\system32\config\software
    delete c:\windows\system32\config\sam
    delete c:\windows\system32\config\security
    delete c:\windows\system32\config\default
    copy c:\windows\repair\system c:\windows\system32\config\system
    copy c:\windows\repair\software c:\windows\system32\config\software
    copy c:\windows\repair\sam c:\windows\system32\config\sam
    copy c:\windows\repair\security c:\windows\system32\config\security
    copy c:\windows\repair\default c:\windows\system32\config\default
  6. Type exit to quit Recovery Console. Your computer will restart.
Note This procedure assumes that Windows XP is installed to the C:\Windows folder. Make sure to change C:\Windows to the appropriate windows_folder if it is a different location.
If you need more help come back.Post / thumbs / testimonial are welcome!
Dec 03, 2010 | ASUS Eee PC 1005HAB Netbook - Intel Atom...
File:\windows\system32\config\system file is missing or corrupt laptop : sony vaio
boot you computer using OS CD and at first screen use recovery console command prompt
at command prompt
wait for 10 second and the enter your administrator password
then go to c:\windows\system32\repair
the type copy system c:\windows\system32\config
press y to overright file
and restart your computer
Nov 23, 2010 | Computers & Internet
My desktop shut down and is asking me to re install a 32 windows file. What is this and how do I fix it?
Hi, This normally means that a windows file from the system32 folder is missing or corrupt. You will have repair that by using your operating system cd and go to repair when prompted. If this does not work you may have to install a clean copy of your operating system.
Apr 10, 2010 | HP Pavilion a1220n (A1220NED904AA) PC...
I have toshiba L300 pc laptop, i tried to formati
kindly follow these steps:
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 20, 2010 | Toshiba Satellite Pro L300 Notebook
Having problems with my compaq Persario 2500
this problem occurs when you try to update drivers in the computer..sometimes windows XP cannot update the driver and that corrupts system.ini file as it has a lot of bad entries..Due to this you will get this error mesage..No its not due to virus.its due to an attempt to change system.ini file
Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM
That means the System Registry Hive has become corrupted.
There are two ways to get back up and running. The easy way which doesn't always work, and then there is the hard way.
Easy Way --- Note that this doesn't always work.
When you are booting your system, press the F8 key during the start of the bootup sequence, meaning after it does the Power On Self Test.
Once you press the F8 key, you will be taken to a Menu. Select "Boot Using Last Known Good Configuration".
It will now attempt to load Windows XP using a past set of configuration files.
If that doesn't work, there is the next step....the hard way.
Hard Way
Boot your system with the Windows XP Install CD, let the system boot into the Setup. Once in the Setup, choose to run the Recovery Console.
You will now be presented with a screen similar to good old DOS.
First, we will recover the System Hive.
Now, type in the following commands with pressing Enter after each line.
md tmp
copy C:\windows\system32\config\system C:\windows\tmp\system.bak
delete C:\windows\system32\config\system
copy C:\windows\repair\system C:\windows\system32\config\system
Be very careful when you are typing in these commands, one wrong move, and you have, broken Windows XP.
Also, change the C in the commands to whatever your Windows XP drive letter is.
Attempt to boot the system, if it doesn't boot, get back into the Recovery Console and do the following commands.
md tmp
copy C:\windows\system32\config\software C:\windows\tmp\software.bak
delete C:\windows\system32\config\software
copy C:\windows\repair\software C:\windows\system32\config\software
Oct 11, 2007 | HP Compaq Presario 2500 HP Pavilion ZE...
Acer Aspire One AOA150-1983 Notebook PC Logo
450 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
