Monitor inconsistently comes up white, I press the side (bottom) power button several times until D-Sub message appears on the screen, on a normal screen. Then it is ok until I shut it off, or it goes on stand-by. Monitor otherwise is fine. Do I need to replace the cable?, if so, where do I get a proper, compatible cable, and how much $?
  • 601 Answers
HI...
This seems issue with the cable or ports.
If you have different computer try to connect to this monitor to avoid the chance of video card being faulty.
Check for any broken or bent pins in the port.
Slightly tap on the cable if you get the white screen back.
Also let me know the model and make of the monitor
Let me know
Thanks
Smith
Posted on Jul 23, 2009
At times I have to push the start button several times before it turns on. What's wrong?
your start button might stick or it just wont work I suggest taking it to the place called ( i think peach mac) they fix stuff like that and getting them to look at it
Jul 10, 2014 | Apple iPhone4 4G iPhone 4
What causes a dirty background?
Copied
1) - Power ON printer while holding both the + & - buttons until "OKIUSER" message appears in LCD.
2) - Press + or - button until "ENGINE DIAG MODE" is displayed.
3) Press "ENTER", displayed will be "DIAGNOSTIC MODE XX.XX.XX S-MODE"
4) Press + or - button until "NV-RAM INITIAL" is displayed.
Half way, dont stop too long it will time out....
5) Press "ENTER" again.
6) Will appear "TABLE 1" message.
7) Press "ENTER" until "EXECUTING RESET" message appear. ...............the "NV-RAM INITIAL" message will BLINK.
Tada....This procedure reset TONER, DRUM, FUSER and BELT...life counts
8) power OFF printer, wait 10 sec, and power ON again..
To access Service Mode in C9300 power ON printer with 0, 1, 6, 7 at same time...you can do some good damage in there!! (I warned ya!)
Resetting consumables for OKI C7300,C7500,C9300 printer I think!
1. Hold buttons 0 + 1 + 6 + 7 on startup.
2. Press button 0 several times until "DIAGNOSTIC MODE xx.xx.xx" shows.
3. Hold buttons 2 + 3 until "ENGINE DIAG LEVEL 4" shows.
4. Press button 1 to scroll to "COUNTER SET".
5. Press button 2 to scroll through menu items (button 6 scrolls backwards)
6. To alter the value of an item, first press button 3 to select the digit to be altered. The selected digit will slowly flash. (Button 3 moves to the right through the digits. Button 7 takes you to the left.)
7. Then press button 2 to increase the value of the selected digit. Press button 6 to decrease the value.
8. When the changes have been made hold buttons 1 + 3 + 5. The screen will flash three times and then an * will appear on the right of the screen. The new value is set.
9. To leave the counter set menus, turn the printer off.
IMPORTANT
Each colour toner counter shows life as percentage used. So a toner showing 30% has used up 30% of its toner. 100% would indicate a near empty toner. This is the reverse of the toner life shown from the "usage menu" when the printer is in normal operation, which shows the toners as a percentage life remaining. You will want toner showing 00%. note:this is oposite of what you see in user mode
Some models exhange these steps
3) HOLD 0 + 4 "ENGINE DIAG LEVEL 2" shows
4) Press 1 to cycle to "fuser unit"
5) 2 to scroll to TONER
REST IS SAME WE WANT TO SET WHAT i GUESS IS AT 100% TO 0%.
Jun 10, 2014 | OKI C9600hdn Laser Printer
Black screen when turned onno display
There are several reasons that your Toshiba laptop screen may not come on, even if the laptop appears to be running, and several options you may try to get your screen back up and running without an expensive service call.
Common causes for a blank screen include a backlight that is turned off, a display toggled to an external monitor and improper shutdown errors.
To avoid blank screen errors after your current error is fixed, make sure to follow all instructions in your user's guide to care for your Toshiba computer.
Shine a flashlight directly at your screen and look for an image.
If you see one, this means the backlight on your laptop is off but the screen is still working. This backlight normally turns off only when your screen is closed.
Look for a small metal or plastic pin near one of the screen hinges.
The screen pushes this pin in when it is closed, so if the pin is stuck in the screen closed position, the backlight will remain off.
Tap the pin several times to release it.
You may need to use a small object, such as a pencil tip or straightened paper clip, to reach it on some models.
Monitor Toggle
Press and hold down the "Fn" key if you do not see an image when you use the flashlight.
Tap the "F5" key several times while the "Fn" key is pressed.
This will cycle your screen through the various options that toggle the display to an external monitor.
Attach an external monitor, restart the computer and try this method again if no image appears on the laptop screen.
Click "Start," "Control panel," "Hardware and sound," then "Device manager "using the external monitor if you get an image there but cannot toggle the image back to your LCD.
Select the "Monitor" option to expand your selection and select your LCD monitor from the device list.
Click the "Driver" tab and select "Update" to update the driver, as this error is likely caused by a software driver error.
Force Restart
Press and hold the power button until the computer shuts down completely.
Check the indicator lights at the edge of your laptop to see if the computer is truly off or if it has simply gone into hibernation mode.
If it is off, all lights will be off except the battery-related lights if you have a charger plugged in. In hibernation mode, the power light will blink slowly.
Press the power button to restart the computer again after leaving it off for 15 to 20 seconds. This may fix the problem.
If the blank screen returns or you get a flash of images and then a blank screen, move on to the next step.
Force Power Down
Unplug your laptop from the power source.
Remove the battery by pressing outward on the battery latch and pulling the battery unit completely out of the computer.
Press the power button several times to completely discharge the computer.
Replace the battery and plug the computer back in after about 30 seconds.
Press the power button to turn on the computer.
If you get an error screen upon startup, choose to restart Windows normally.
This error is caused by improper shutdown procedures.
Hope this helps
Nov 14, 2012 | Toshiba Computers & Internet
My toshiba l355d black screen all fans and lights are working
Monitor Toggle
Click "Start," "Control panel," "Hardware and sound," then "Device manager" using the external monitor if you get an image there but cannot toggle the image back to your LCD.
Force Restart
Force Power Down
Hope this helps
Nov 03, 2012 | Toshiba Satellite L355D-S7901 Series...
Laptop is run and start but no display
Monitor Toggle
Force Restart
Force Power Down
Hope this helps
Oct 22, 2012 | Toshiba Satellite A500-ST5608 Laptop DC...
I have a new DELLS2209W Monitor. On occasion my
I want you to try something next time this happens, instead of rebooting the computer, just cut power to the monitor. Then switch it back on.
Does the screen come back up?
Comment back and let me know
Mike
Dec 19, 2009 | Dell Computers & Internet
Error code f35 konica 7022
Turn on the main and sub power switches.
Keep pressing the
* button until the message
“Please enter service password.” appears.
Input 9272 as the password and press the
[Start] key. (The password is fixed and cannot
be changed.)
[Mode Select Menu Screen]
Press the key of the mode to be selected on the
screen. To return to the Mode Change Menu
Screen, keep pressing the
* button until the
screen appears.
When the adjustment ends, press
[1. Normal Mode] key and the basic screen will appear
Jul 14, 2008 | Office Equipment & Supplies
Flash on Cyber-shot DSC-W50 not working properly
hi there
you can try doing this and it should work and solve the problem for you
  1. Press Menu button
  2. togle across from REC Mode to setup
  3. togle down three times from camera to setup 1
  4. togle across into sub menu
  5. togle down from four times to Initialize
  6. togle across again to the sub-menu
  7. togle up from cancel to OK
  8. press center button to accept the OK choice
  9. Screen changes and so press okay again
  10. It should restart the camera
  11. Opening on the 'Clock Set' screen
  12. togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
  13. If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and
Dec 27, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Screen Adjustment
On your monitor at the bottom there is 3 buttons. The one all the way to the left is the "menu" button. The next one (going right) is the "NEGATIVE" button. The next one (going right) is the "POSITIVE" button.
You can move your screen around. First, start by pressing the menu button.Then, a menu in blue, with a bunch of little white icons will appear. Next, go over two icons by pressing the positive button twice. Then, proceed to push in the "menu" button again. A bar will appear. By pressing your negative button, your screen will move left. Pressing your positive button will make your screen move right. Adjust your screen until the black on both sides are of even proportion. Then, press the menu button to return to the orginal menu you started at. Proceed to press your positive button two more times. Then, press your menu button. Then, once again, use your positive button, and your negative button to adjust your screen to even out the black on the top and bottom.
Dec 24, 2006 | HP Compaq FS 7550 17" CRT Monitor
15 people viewed this question
k24674
jasbo
jasbo
