Question about Dryers
Replaced elements for the 2nd time only drys for about 2weeks kenmore model 66722690
  • 98 Answers
Replace the limit switch mounted on the coil casing
Posted on Jul 23, 2009
1995 Kenmore Dryer heating issues
Sounds like a Heating element. Most towns have a do it you self appliance repair store. Contact them to price the part. Have you tryed vacuming th ling from the inside of the unit. Sometimes they get loaded with lint and does not heat efficiently. Hope this Helps.
Jun 21, 2013 | Dryers
Kenmore Elite Gas Dryer starts/runs/drys only w PTS held on?
push to start button needs replacing,sometimes you can jump that out if you have another switch that starts the dryer when you close the door
Jan 15, 2013 | Kenmore 73952 Gas Dryer
Kenmore dryer 70 series 66722690-everything works except does not heat
It is probably either the thermostat (sensing too hot a temp) or the heating element. Either is not that difficult to change.
A word to the wise: When I replace one I like to replace both. One of the first times I replaced an element, within a month I had to open it back up and replace the thermostat. And it has happened more than once, so now I replace both.
May 15, 2012 | Kenmore Dryers
Kenmore dryer 70 series 66722690 - has power but won't start (no humming noise, no ticking noise from timer, and no light when you open door) nothing!
I would check the breaker before you go any further. Here are some things to remember when you do this. 1) The breaker for the dryer is generally located outside on the side of the house somewhere near the electric meter. Most 220vac breakers are, which include any electric range, cooktop, wall oven, etc. 2) When your checking the breaker, actually physically touch it. Sometimes breakers can trip a but the spring that actually pulls the breaker to off position is weak and by visual inspection would appear on. Just simply reach in and tap the bar lightly in the off direction. If it pops over to the off position, turn it back on then go check your dryer. If the breaker passes inspection, I would unplug the machine because there migfht be a short at the terminal block where the plug connects to the dryer. After you've unplugged it, remove the back and check to see if everything is ok. I have a strong feeling that you won't need to get to this point cause I'm betting on breaker.
Apr 30, 2012 | Kenmore Dryers
Dryer takes a long time to warm up. It drys in 2 hours and does not shut off automatically. Maytag series 200
To make things properly, voltages to heating element should be tested, but that is a job that must be done by a technician.
Test first the heating fan. If it is not working replace the fan assembly.
Replace the heating element if that does not solve the problem replace the control board.
You can find schematics and diagrams by entering model number here.
Feb 18, 2009 | Maytag PYE2300AY Electric Dryer
We must wait one hour to dry 2nd load
you have a bad motor the internal overload is cutting it off when the motor gets hot and that is why it takes about a hour for it to cool down before it will come back on the fix is replace the motor which is very expensive or buy a new dryer
Dec 28, 2008 | Whirlpool LGV4634JQ Gas Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Drying
Could be the high safety limiter its on the outer housing in whice the heating element is housed in the back of kenmore dryers. email back if its not a kenmore I will tell you where to look on other brands
Aug 27, 2007 | Frigidaire FEQ1442ES Electric Dryer
Dryers Logo
46 people viewed this question
Top Dryers Experts
