Question about HP G60-235DX Notebook
My displace screen got broke. I replaced it and everything works but screen is black. What to do now??????
    President:
  • 2,976 Answers
Take it apart and check every connection. If even one isn't as tight fitting as it should be, you will have failure.
Posted on Jul 23, 2009
Toshiba Satellite C655D-S5518 show black screen
Most probably one of two problems causing this:
1. Replacement screen has bad LED diode (not likely the problem).
2. Either you didn't get cable securely attached to replacement screen or (more likely) the other end of the cable detached from the motherboard when the computer fell and the original screen broke. I recommend carefully rechecking both ends of the cable connection.
Dec 30, 2012 | Computers & Internet
I have a motorola razr v2m, and both the outer screen and inner screen are blacked out. I can still make calls, if I know what number to put in, and I can still receive calls, but with out knowing who is...
Basically only your display is damaged/broke.So all your functions are working well.Please replace the display with the new one so that everything will be fine.
To replace please go to nearest motorola authorized service centre.They will replace the screen for you.
thank you
Aug 07, 2010 | Motorola Mobility RAZR2 V9m
Broke screen on a lg shine model cu720 how do i transfer contacts to simcard
HI...
unless and untill you replace your displace you will not be able to trnsfer the contacts to sim.
If you have same mobile with you can check and do by press keys according to this mobile in your broken screen mobile...but you can do by trail and error method only and it may be risky too. but you cannot be sure that you have coped all the contacts to sim
thanx
Jul 18, 2010 | LG Shine CU720 Cellular Phone
Dent in screen with black spot oin screen and
looks like u broke the colour crystals in ur ds screen. soz to say that dat cant b fixed.
Mar 05, 2010 | Nintendo DS Lite Console
Left hinge broke and no screen.
Its possible that there is a cable loose causing a short, which could have happened when the hinge broke.
This would explain why you are not seeing any display. To test if the display is bad, or if the computer is just not working, you can plug in an external monitor. It will help you to see if you nicked the cable, or if the system board is going.
Jul 23, 2009 | HP Pavilion DV9650US Notebook
Lcd screen broke external monitor wont work
Sounds like you resolution is too high or vista doesn't recognise your driver.
Try starting in Safe Mode by powering up your PC and tapping the F8 key until you see a menu. Select Safe Mode from the menu. Once in safe mode change the resolution to 800x600 then restart in normal mode.
If that doesn't work then download and install the correct drivers for your display card here;
ftp://ftp.work.acer-euro.com/notebook/aspire_3680/
Once downloaded, you may need to install it in safe made once again.
Thanks
C
Mar 28, 2009 | Acer Aspire 3680 Laptop
Altec Lansing Vs3151 Control Pod
The green connector on the control pod broke. Where can I get a replacement? The orange and black connectors still work and everything else work.
Jan 12, 2009 | Altec Lansing VS3151 Computer Speakers
I have an alpine IVA-W203/P1 but someone broke the screen but it still works and and everything and changes channel but the screen touch screen does not work.. is there any way to fix it so the touch...
If the head unit has a reset button try to reset it. if that doesn't work it will need to be sent to the manufacture to be repaired or replaced. But if someone broke it warranty doesn't cover that. Niether do most insurance companies without special coverage. Sorry.
Dec 03, 2008 | Car Audio & Video
Black Screen after sitting for awhile
Might be that the graphics card is overheating.
Nov 08, 2007 | Acer Aspire 5100 Notebook
HP G60-235DX Notebook Logo
89 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
