Question about Radio Communications
My uniden uh-040xr is not picking up anything on all the channels
  • 43 Answers
Make sure the cellcall or any of the code settings are correct.
Posted on Oct 24, 2009
How do i program my uh-040xr so i can listen to the police
It's ******* in most counties to listen to the Police and most of them use radios that operate a Frequency Hopping System which jumps over a select amount of frequencies at a fast rate.
Dec 24, 2016 | Radio Communications
What scanner can pick up nexedge
Go to :
http://info.uniden.com/twiki/bin/view/UnidenMan4/UnidenScannersUsersGuides.
Dec 26, 2013 | Uniden Bc346xt Handheld Trunktracker Iii...
Scanner is not picking up anything
it should have a squelch knob . Turn it all the way up and try your scan again. Also turn your volume up a little.
Jan 13, 2013 | Uniden Bc125at Handheld 500 Ch. Special...
I have a pair of UH-040XR .Despite sharing the same channell & the send/receive icons showing correctly when I transmit/receive, I cannot hear anything at all except static . They used to work fine...
Hi afrench, my name is John. Welcome to FixYa. After units set up for a period of time like that, the capacitors discharge. Make sure you have the batteries in correct and turn them on and leave them on 12 to 24 hours in order for them to charge up. Could be some corrosion built up from the batteries leaking. Let me know how it goes, we are always ready to help you. Thanks for choosing FixYa.....John
Nov 26, 2010 | Radio Communications
Channel selector switch for the UH 011 Uniden
Call uniden 1.800.297.1023
You can order the part through them.
Dec 04, 2009 | Radio Communications
UNIDEN UH-011 UHF CB RADIO
i have just printed off a hard copy of this manual it was on Http//.www.uniden.com.au/ RESOUCES main/pdf/uh011.pdf If that isnt helpfull i could post it out to you.
Jun 09, 2009 | Uniden Radio Communications
I can't pick up anything...
Hello even though everything is connected properly, have you checked for standing waves on the antenna to radio connection? Also you may have to perform a sensitivity test on the unit. The problem is you need a RF generator for that. Set you RF generator to the frequency that is equal to the CBs middle frequency and modulate the CW with 1KHz at 50% modulation, tune to the middle of the CB band on the radio and set the output of the RF generator to .1uv and loosely couple the signal to the CB antenna with a loop of wire. Your CB should be picking up a 1KHz tone gradually turn the power level down and when the tone cuts off that level is cutoff level, then increase the level until you can hear the tone again when the tone cuts on that value is the sensitivity of the unit. Compare the measured value to the value in the owners documentation. if the sensitivity is low this could denot a problem in the RF/IF section of the CB.
Oct 04, 2007 | Uniden Bearcat Pro PC68LTW 40-Channels...
Radio Communications Logo
245 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
