SOURCE: Need a workshop manual or diagrams
most all your major auto parts stores have web sites, you may find what your looking for on there.
SOURCE: Torque setting on Opel kadett gsi back wheel bearings
Not even sure who makes those cars but this should hopefully help you
http://vsmus-origin.skf.com/Files/Brochures_in_PDF/457377.pdf
Please take a moment to rate this solution.. thanks
SOURCE: Opel oOmputer Box
it should be located inside the car, on the driver side to the left close to your pedals, if not, send me ur vin number and ill check on my manual
SOURCE: cant turn my w202 head lamps on from the switch
Check out your main lights relay and the associated fuse. If you have someone switch the lights on whilst your under the hood you should be able to hear the relay 'click' as the contacts are brought together. If the relay is dead check that when the switch is turned on that power is getting through to the relay. If the relay is clicking check that power is coming out of the Switched circuit. Now check the fuse, note this will only carry power if the dashboard switch is on and the relay is functioning. Check your bulbs
