Question about Apple iPod touch Second Gen (8 GB, MB528LL/A) Digital Media Player
Forgot ipod passcode
I forgot my ipod touch passcode, is there any way i can unlock it again without restoring it?
  • 30 Answers
Simply plug your ipod into itunes to unlock the code
Posted on Jul 23, 2009
Forgot my ipod pascode lock
If you own an iPod touch, you have the option to set a password, which Apple calls a passcode, to protect your data. Anyone who attempts to access your iPod, after unlocking it or turning it on, will require the passcode to do so. However, if you forget your passcode or incorrectly enter it, you will eventually see an alert that your iPod touch has become disabled. To unlock your iPod touch after forgetting the passcode, and still access your content, you must connect it to the computer with which you last synced it.
Connect your iPod touch to the computer with which you last synced the music player. Launch iTunes if it does not automatically open. Select your iPod touch under the devices list, and click the "Summary" tab in iTunes. Click "Restore" and, when prompted, click the "Back Up" button to save a back up of your iPod touch in iTunes. Click "Restore" when prompted, after the back up saves. After restoring, click "Ok." Choose the most recent back up from the drop down list on the "Set Up Your iPod" screen. Click the "Continue" button to restore your iPod touch.
iOS: Forgotten passcode or device disabled after entering wrong passcode
http://support.apple.com/kb/ht1212 iTunes: Restoring iOS software http://support.apple.com/kb/HT1414
Apr 08, 2013 | Apple iPod touch
How can i unlock my ipod touch? i forgot my passcode.
The only thing that could make your iPod touch work again is to put it to DFU mode and restore. I have a full instruction about that to guide you step by step, making sure that you're doing the right thing.
However, that process will wipe out all the data from your iPod, you won't even be able to sync or create a back-up because iTunes does not recognize any iPod that is passcode-locked.
That is also why you need to put your iPod to DFU mode first, so that iTunes can recognize it, to by-pass the fact that it is passcode-locked. And, once its in DFU mode, the only thing that you'll be able to do is to restore, nothing else. And you have no other choice.
Click here for instruction on how to put your iPod touch to DFU mode and restore.
For more iPod touch / iPhone tips, click here.
Feb 11, 2010 | Apple iPod touch
Forgot passcode and wont unlock how do I unlock it?
Try to remember your passcode because the solution that I'm going to recommend to you will wipe out all the data from your iPod touch.
If you totaly forgot, the only thing you can do is to put your iPod touch to DFU mode and then restore.
Click here for step by step instruction on how to do that.
Feb 06, 2010 | Apple iPod touch
I forgot my passcode to the ipod touch is there anyway to get in
The only way is to restore the iPod with iTunes and that will restore your latest backup, assuming one was made. You may lose some data depending on what was backed up and when it was made. There is no way to unlock without passcode apart from restoring.
Jan 08, 2010 | Apple iPod touch
Forgot passcode
If you forgot your iPod Touch password the only solution is to wipe and restore your last backup.
Apple Knowledge Base Regarding lost passwords
Instructions from Apple Support Document (Page 110)
Restore iPod touch from a backup:
  1. Connect iPod touch to the computer you normally sync with.
  2. In iTunes, select iPod touch in the sidebar and click the Summary tab.
  3. Click Restore to reinstall the iPod touch software, restore its default settings, and delete data stored on iPod touch. In iTunes, you can also restore from a backup without deleting data stored on iPod touch.
Aug 15, 2009 | Apple iPod touch
Ipod touch disabled
If you repeatedly enter the wrong passcode, iPhone or iPod touch will be disabled for longer intervals, before you can try again. After too many unsuccessful attempts, you won't be able to try again until you connect to the computer you normally sync with. Note that starting with iPhone 2.1 software, there is a setting to cause the device to erase itself after 10 consecutive incorrect password attempts. This setting is off by default. It can be turned on by tapping Settings > General > Passcode Lock after you enter a correct passcode.
If you cannot remember the passcode, you will need to restore your device on the computer that was used to originally sync the iPhone or iPod touch so that you can reset your passcode and resync the data from the device (or restore from a backup). If you restore on a different computer that was never synced to the iPhone or iPod touch, you will be able to unlock the device for use and remove the passcode but your data will not be present.
Jul 29, 2009 | Apple iPod touch Second Gen (8 GB,...
I have forgotten my pass code that unlocks my IPod, so right now i can not use it at all
If you cannot remember the passcode, restore your device on the computer that was used to originally sync the iPod touch so that you can reset your passcode. Good luck!
See info from Apple
Backing Up, updating, and restoring your iPhone and iPod touch software
Jun 01, 2009 | Apple iPod touch
FORGOT PASSCODE
If you can't remember your passcode, you will have to use iTunes to restore you Touch. Remember that restoring will erase eveything on the Touch, make sure you have made a backup of your data first.
Here is detailed steps on restoring:
Mar 25, 2009 | Apple iPod touch
Unlock code from ipod
It depends on the severity and the settings you have given the iPod... Here's the full explanation. I would recommend reading the second paragraph first, but the solution if you really forgot your password is in the first paragraph.
If you cannot remember the passcode, you will need to restore your device on the computer that was used to originally sync the iPhone or iPod touch so that you can reset your passcode and resync the data from the device (or restore from a backup). If you restore on a different computer that was never synced to the iPhone or iPod touch, you will be able to unlock the device for use and remove the passcode but your data will not be present. Refer to "Updating and restoring iPhone and iPod touch software."
"If you enter the wrong passcode too many times, you'll see a message that says "iPhone is disabled" and to try again later. If you repeatedly enter the wrong passcode, iPhone or iPod touch will be disabled for longer intervals, before you can try again. After too many unsuccessful attempts, you won't be able to try again until you connect to the computer you normally sync with. Note that starting with iPhone 2.1 software, there is a setting to cause the device to erase itself after 10 consecutive incorrect password attempts. This setting is off by default. It  can be turned on by tapping Settings > General > Passcode Lock after you enter a correct passcode."
The full article can be found here: http://support.apple.com/kb/HT1212
Feb 12, 2009 | Apple iPod touch
How to reset password on itouch
how can i reset my ipod touch when its disabled
Oct 12, 2008 | Apple iPod touch
Apple iPod touch Second Gen (8 GB, MB528LL/A) Digital Media Player Logo
400 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
