how do you prime an electric fuel pump thats buried inside a fuel tank ---are you getting fuel to the throttle body --is pump turning on --retest pump new doesnt mean free from defects if this is the first replacement pump for vehicle was the connection to pump upgraded /changed out [problem with connection corrosion and damage would incur causing pump failure or non operation of pump ]also check lines are not kinked and pump installed correctly
? 5:57
https://www.youtube.com/watch?v=8dj0Voh3TTM
Jan 21, 2014 - Uploaded by RepairClinic.com
The most common reason for replacing the oil pump is ... ...Chainsaw Oil Pump Replacement - Homelite Chainsaw Repair (part #309514001) ... spark plug wrench, cord, clutch removaltool, adjustable wrench, needle-nose pliers ... The chainsaw guy shop talk Repair Homelite 150 chainsaw Auto Oiler ...
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
The Homelite XL chain saw is designed to use one tank of oil per each tank of fuel. Fill the oil ... Push the guide bar toward the saw, and remove it and the chain. Clean the ... Automatic Oiler and Oil Line Replacement ..... My Ridevisit'Cars-My
Chainsaw fuel lines are specialized hoses that either need to be replaced with TEFLON hoses of the same diameter, or the specialized rubber hoses that are resistant to gasoline and other chemicals. You should ask at a hardware store and make sure you get a hose that fits TIGHTLY into any holes on the gas tank, and also snugly fits over ant incoming metal or brass lines going into the carburetor.
Your fuel pump is in the tank. Turn on the ignition, and listen if you can hear the pump run in the tank. It will only run a few seconds if the engine is not running. You can repeat this several times to prime the fuel injection.
Cracked fuel line. You can find an IPL (exploded parts list) containing fuel components and some illustrations here:
"P3314 Gas Saw Type #" (Type is the - number of your serial number) Poulan.com http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
Fuel components are on the "Engine Assembly" & "Handle, Chassis, & Bar Assembly" detail pages. Replacement fuel lines can be found at your local chainsaw seller/mechanic. They are different diameters. Fuel Line Replacement by SmallEng.com http://www.youtube.com/watch?v=JrXpU70Hmi0
The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as it inflates).
The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs will help with reassembly. HTH Lou
I have a Homelite Super 2 chainsaw that has a hole in the primer bulb on the fuel cap...will not prime. Where can I find a replacement primer bulb fuel cap?
