Question about Xerox Office Equipment & Supplies
Wokcentre pro 35 has a fuser module under temperature fault code 10-545.00, powered down multiple times and changed fuser but wont start printing or coping again.
  • 601 Answers
How do iremove error of code sc542(ricoh aficio 1515mf)
542 Fusing temperature warm-up error (center)
The fusing temperature rises less than 7 degrees in 2 seconds, and this continues 5 times consecutively. The fusing temperature is not detected in 25 or 35 seconds. • Fusing thermistor defective or out of position • Fusing lamp open • Power supply board defective
This is the reason for the error code according to (printcopy.info) Might help you in some way, but not my area of expertise.
Jan 20, 2015 | Ricoh Aficio 1515MF All-In-One Laser...
Kyocera error 6000:0032718
6000 Broken fuser heater lamp wire
The temperature does not reach 100/
212 after the fuser heater lamp has
been turned on continuously for 30 s.
35/37 ppm printer (EUR/USA model):
The temperature does not rise by 1
1.8 after the fuser heater lamp has
been turned on continuously for 5 s during
printing.
Apr 15, 2014 | Kyocera FS-2020D Laser Printer -...
Fan under the hood wont shut off
The fan on that model has an electronic control module that is interfaced with the engine control module. Without a scan tool it will be difficult to ascertain which module is indeed at fault. Most likely the fan module has gone bad. Check the temperature gauge in the cluster to insure the engine is NOT overheating....that will keep the fan on. But from what I can surmise....it runs even when it is cold. The scan tool is going to be used to pull the trouble code stored in the ECU for the engine....this is still the best way and cheapest to diagnose.
Scott, Porsche Master Tech 35 years
Jan 12, 2014 | 2011 GMC Terrain
The errore code of my konica 7040 is F-35-2
f 35-i thru f35-6 low temtemperature or open thermistor
simulations
note : 9272 is the standered password to enter simullation press9,2,7,2,start , to use these with power already on press and hold the"*"key util the display says "please enter service password"note:factory manual says"keep pressing" this might mean hold down or it might mean press repeatedly.press9272 start "mode selectmenu screen" will appear.press the mode you want[p ,25, 35, 36 , or 47] when finished press "normal mode"to return to standard screen use the number keys to change values press print key to check item press "stop/clear"when finished
"25 mode" to enter this mode turn power off, press the 2and 5 keys and hold them down while they are held down turn on power menu screen will list choices
1 software switches
2pm count
3collectng
select your choice enter value press"return"to see that your new value has been entered turn power off new in formation will not take effect util power is off and back on again
1 software sw ....use up/downarrows keys to select dip switch use up/down arrow keys to select to select bit number"on"is 1 "off" is "0" on will set bit off will clear bit press "return"to return to menu listing dipswitches and all their bits cannot be done in a short publication such as this one
dipswitch 3 bit 1 is the fuser reset command {for error cdes f34,f35and f36}0 is no 1 is yes to reseta fuser fault you enter this mode select dipswitch 3, select bit 1and change "1"to "0"by pressing"off"
dipswitch 23 bit 7 is fuser web count-over stop machine will stop operating when fuser web life is reached if this is set to"1"
Aug 30, 2011 | Computers & Internet
Xerox Phaser 4500 printer has a U4 fuser code.
From the Xerox Phaser 4500 Service Manual (here), the main problems could be one of:
  • Warm-up failure - Fuser warm-up not complete within 110 seconds after
  • starting.
  • Cool-down error - Cool-down process not complete within 200 seconds.
  • Low trouble temperature - The fuser temperature drops to the low trouble
  • temperature (approximately current control temperature, minus
  • approximately 25°C).
  • High trouble temperature - The fuser temperature rises to the high trouble
  • temperature (approximately current control temperature, plus
  • approximately 35°C).
  • STS circuit open
  • STS failure - The heat rod remains on for at least 10 seconds after warm-
  • up has completed
It could be that your fuser needs to be replaced, but as you can see that code relates to a couple of problems, so even replacing the Fuser might not fix the problem.
If it doesn't even do the warm up checks it is likely to be the fuser because the other components such as STS failure and cooldown won't have had a chance to run..
May 03, 2011 | Office Equipment & Supplies
What mean code f35-3 on konica 7020.
simulations note : 9272 is the standered password to enter simullation press9,2,7,2,start , to use these with power already on press and hold the"*"key util the display says "please enter service password"note:factory manual says"keep pressing" this might mean hold down or it might mean press repeatedly.press9272 start "mode selectmenu screen" will appear.press the mode you want[p ,25, 35, 36 , or 47] when finished press "normal mode"to return to standard screen use the number keys to change values press print key to check item press "stop/clear"when finished
"25 mode" to enter this mode turn power off, press the 2and 5 keys and hold them down while they are held down turn on power menu screen will list choices 1 software switches 2pm count 3collectng 4 5 select your choice enter value press"return"to see that your new value has been entered turn power off new in formation will not take effect util power is off and back on again 1 software sw ....use up/downarrows keys to select dip switch use up/down arrow keys to select to select bit number"on"is 1 "off" is "0" on will set bit off will clear bit press "return"to return to menu listing dipswitches and all their bits cannot be done in a short publication such as this one dipswitch 3 bit 1 is the fuser reset command {for error cdes f34,f35and f36}0 is no 1 is yes to reseta fuser fault you enter this mode select dipswitch 3, select bit 1and change "1"to "0"by pressing"off" dipswitch 23 bit 7 is fuser web count-over stop machine will stop operating when fuser web life is reached if this is set to"1"
Feb 24, 2011 | Office Equipment & Supplies
I have a Xerox XC1020 copier with a code H3. What does this mean?
The H3 code is a fuser high temperature code.. First fix is to power down and let the machine cool down..
Failing that, I couldn't find a clearance method for that particular machine but most of the machines in this category had the same control panels for years so it might work.
This is for an XC811 machine, same family, so it might work. If any of the controls mentioned are not on your machine then you need to contact the helpdesk if it still exists or a local copier repair place who should know how to clear the codes.
"To enter diagnostics: Turn on the power and within 4 seconds press the following sequence: ‘Clear’, ‘Exposure Mode’, ‘Clear’, ‘Exposure Mode’ (Exposure Mode is the button on the far left). The console will go completely blank.
To enter a code: Select the first part of the code using the copy quantity buttons, followed by the ‘Print’ button, then the second part of the code followed by the ‘Print’ button again.
To exit diagnostics: Press ‘Clear’ repeatedly or turn the power off.
*To clear a fuser code:(14) Enter diagnostics, select ‘14’ followed by ‘Print’… exit diagnostics.
H3 stands for high temperature at the fuser."
If it persists then you have a fuser fault that will probably need to be replaced.
And as I said, this is not specifically for your machine but the clearance codes for Xerox machines tend to be similar.
Good Luck!!
Oct 09, 2009 | Xerox Office Equipment & Supplies
XEROX WORKCENTRE 5222/5225/5230 A FAULT OR ERROR FAULT CODE 010-327
010-150, 155 Too much or not enough paper in duplex tray 10-300 Fuser thermistor 10-302 Low fuser temperature 010-304 Bad fuser temp 10-308 High fuser temperature or open thermistor 010-310 High fuser temperature 010-312 Fuser not up to temperature after energy save 010-314 Fuser problem 010-320 Fuser web finished 010-330,327 335, 340 Exit switch, vertical sensor switch actuated when power is turned on
Sep 03, 2009 | Office Equipment & Supplies
57 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
