Question about Watts Onan Portable Generator - 4000 , Model# 5500
5500 marquie gold startes run for a few nim thin
5500 marquie gold startes run for a few min thin stop will not prime for short time thin it will restarts
Shut fuel off at tank, pull fuel line off carb ,slowly turn on fuel if fuel flows freely(real good stream)your carb needs replacement(cant buy parts to rebuild EPA) if fuel just barely trickles out . there is a screen in the fuel tank that is probably clogged
Posted on Jul 23, 2009
I have an Onan 5500 Marquis Gold LPG generator that runs but backfires and spitfires. Need troubleshooting assistance!
have a gas shop inspect the gas converter / regulator
next check the ignition circuit for shorting / loose connections causing a spark at the wrong time
check the low oil sensor unit as it is known that they fail and cause indications of your problem
check oil level in the sump as it may be making/ breaking the circuit if too low
Sep 10, 2017 | Electrical Supplies
The generator surges and stops while rv is in motion.
Did you get this fixed? this is an old post. If not visit www,advanced-power-technologies.com (Cert Cummins Dealers) They can answer your questions.
Oct 05, 2014 | Onan Marquis Gold Quiet Gas Generator 5500...
WHAT IS ERROR/FAULT CODE 37 ON A ONAN 5500 MARQUE GOLD GENERATOR ?
Code 37 is a bad set configuration, that means engine cranking speed and generator output aren't happy with each other..
Sep 30, 2014 | Onan Marquis Gold RV Generator 5500 Gas
Where is the fuse on the onan 5500 built in generator?
Try under the bench seats around the table, near the heater.
Jul 14, 2014 | Onan Marquis Gold Quiet Gas Generator 5500...
My onan marquis gold generator runs no problem, when I put a load on it, it doesnt ramp up, the fault code is 14, this is a marguis gold 5500 spec d
Does it bog down? if so have engine checked for ability to deliver HP. Cylinder compression, leakdown test. When was it tuned?
Jun 23, 2014 | Onan Marquis Gold Quiet Gas Generator 5500...
Onan marquis gold gas generator 5500 stops running after 5 minutes
Check fuel pump pressure, how long has it sat. What load is on after it stops?
Jun 10, 2014 | Onan Marquis Gold Quiet Gas Generator 5500...
Onan 5500 RV generator starting issue
Sound like a dead battery, or poor battery volatge getting to the unit. The clicking is fuel pump and or solenoid trying to pull in.
Sep 12, 2012 | Onan Cummins 5.5 HGJAB-901 RV QG 5500...
Watts Onan Portable Generator - 4000 , Model# 5500 Logo
452 people viewed this question
Top Watts Electrical Supplies Experts
rlev_7
Level 1 Expert
Steve
Jim London
Jim London
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
