Question about Whirlpool Dishwashers
Whirlpool Dishwasher Quite Partner II, 6 years old, Manual shows Models DU620, DU943, DU950, DU951, DU 960 and DUL200. Burning smell, clicking sound, Wash light blinks. Machine full of water.
SOURCE: Whirlpool Quiet Partner II not washing or sensing.
I have a whirlpool quiet partner II and for some reason it does not drain the water out any more and I cannot figure out why....people say that it is the filter but that is unbelievably hard to get to and I cannot find any instructions online or paper work that tells how to break it down. If anyone has any insight please let me know
Posted on Nov 23, 2008
  • 423 Answers
SOURCE: Whirlpool DU1055XTP dishwasher fills with water but won't wash.
Can you be more specific? Does the dishwasher fill and then overflow?
Posted on Apr 11, 2009
rylee_smith
  • 8619 Answers
SOURCE: Clean light is blinking. Services manual says:
Hi
Thanks for using FixYa. That means the control sensed that the heater in the D/W did not operate 3 times in a row. So the unit locks out. First remove the kick plate and you may have to pull the unit out from under the cab, but check your heater. Use a meter to see if it reads open; if so orders a heater assay it will come with a new control replace it too. If heater checks good then press in sequence normal wash, heat dry, normal wash, heat dry, normal wash, heat dry three times within 6 sec and all the lights will come on then hit cancel. What that did is reset the control and clear that fault. Keep in mind that D/W does not heat its own water and incoming water temp should be 120. The D/W will maintain that temp. When starting your D/W first turn on your hot water till it gets hot then start your D/W this ensures your unit fills with hot water and not cold
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Nov 22, 2009
kingbrizzle
  • 407 Answers
SOURCE: Where is the food trap located in my dishwasher?
They are usually located on the bottom of the dishwasher on the inside, towards the back. Some of them require you to unscrew the screws to access it. It will look like a small grid, and under that is where it gets nasty. Hope this helps.
Posted on Dec 28, 2009
SOURCE: whirlpool quiet partner III clean light blinking green
When I did heated dry, normal, heated dry, normal, cancel, it did not work for me. So I did the same sequence without hitting cancel and it reset itself. Try this if the other way fails.
Posted on Apr 19, 2010
How old are the quiet partner II models, I have a 8575637. I would like to find a manual.
Try This you will need the model number.
http://www.whirlpool.com/manuals/
Jul 28, 2016 | Dishwashers
Whirlpool quiet partner 1 is suddenly loud
Dear Sir : please see the diagram attached.
May 08, 2012 | Whirlpool Dishwashers
Whirlpool quiet partner ii dishwasher has quit working. Power is getting to the dishwasher but it is not coming on at all. There is water standing in the bottom of it and a very foul smell is present.
This dishwasher has a thermal fuse that attaches to the main control board that may have failed, it can be tested with a meter for continuity if it does not have continuity then it is your problem.
Apr 21, 2012 | Whirlpool Dishwashers
Have a Whirlpool Quite Partner II DU1145XTPBA 1 1/2 old just stop working no lights will come on at all. There is standing water in the bottom. We have replaced the thermal fuse and still nothing. What...
Re-verify the thermal fuse.
If the new wire that came with the fuse was not used the fuse will blow again.
Check the door switch for continuity.
The power to all parts goes through the door switch first.
Open the wire terminal box and check the incoming power wires for good contact.
The drain pump may have a blockage in it as well.
Jul 31, 2010 | Dishwashers
My 6 year old Whirlpool dishwasher is loud
This is a bad wash pump. Looking at about $175 for just the sump assembly. You could do it yourself, but unit would need to be uninstalled.
May 28, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
I have a Whirlpool dishwasher, model DU943 that's under 7 years old. I went to use it last night and it won't power on. I tried selecting all of the cycles, but the dishwasher never came on. I looked...
Hello- This unit has a thermal fuse inside the door panel on the control. This part is replaceable. If it is bad, replace.- and would suggest not using heated dry as this is most common cause of fuse failure. Let me know if this info helps- have more if needed.- Thanks- ED
Mar 03, 2010 | Whirlpool Dishwashers
Whirlpool 24" built-in GU1200XTLBO dishwasher electrical smell
This may be the smell of Varnish used in motor winding. When we turn on the machine it gets heated a little bit resulting in a burning electrical smell.
Mar 11, 2009 | Whirlpool GU1200XTLS Stainless Steel...
Whirpool washer burning smell
i would consider getting aanother washer.if it keeps doing this the machine will cost you more than its worth. time to call a repairman in again id guess..
Jan 11, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool quiet partner II dishwasher is leaving chunky residue on dishes
I H AWHIRLPOOL DASHWASHER MODEL # DUII45XTPB6 quite partner ll I lost my manual , Im trying to acess the error codes . or Im trying to get the diagnostic codes to start . Hope some one can Help""""""
Oct 19, 2008 | Whirlpool Dishwashers
Dishwashers Logo
162 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
