Question about GE (PSS26MSRSS) Side by Side Refrigerator
Water and ice in bottom of freezer, occasional water on floor
There appears to be a rubber lined hole in the bottom back area of our side by side GE refrigerator.
Occasionaly there will be water on the floor in front of the freezer side.
I checked the floor of the freezer, and found water puddled up around the rubber grommet (drain hole?).
Please let me know what you think.
Thanks
Mike
  • GE Master
  • 4,654 Answers
I believe your defrost condensate pan below the evaporator is blocked with ice and now when defrost happens the water pours over the tray and to the bottom of the freezer. You will need to defrost the ice in the collector tray and the pour a solution of hot water and clorox to make sure the water ends up in the condensate pan below your refrigerator. So unplug the refrigerator remove the panel and let me know what you find. I have some more solutions depending on what you see is happening. Thanks, Sea Breeze
Posted on Jul 23, 2009
Frost and Ice Buildup
If everything is cooling fine and the frost is not on the back wall but just the floor at the bottom then your defrost drain is stopped up. Remove the bottom basket and clean up the ice on the floor of the freezer. Look on the back wall and you will see some more ice up a littler higher at the back. This is where the drain is. Clean all the ice out from this area too using hot water or a hair dryer. Once you find the drain hole make sure you get all this ice out of it as well. You can take a screw driver once you have melted the ice and gently push it through the drain hole. Once the hole is cleared you should be able to pour hot water freely through the hole. (It is best to turn the refrigerator off while you do this)
Jul 01, 2010 | GE Profile PSS26NGS Side by Side...
Why does water occasionally leak from bottom of
There is a pan at the bottom of the unit. It catches the defrost cycle water and the heat from the comp. and condensor helps it evaporate. But, it's plastic. Mice have probably chewed holes in it trying to get at the water...They must have water to survive, right? Remove it and you'll see the holes....Then, replace it or epoxy the holes in it with plastic layering from old butter containers etc.
Aug 04, 2009 | GE Profile PCF25PGW Side by Side...
Water appears on the floor infront of the freezer side occasionally and ice is forming at the bottom of the freezer? Everything else works fine. Someone told me I need to put a vinegar mixture down that...
Hello, I'm going to assume this is a side by side, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking down the vent instead of the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks! Mike
Jul 23, 2009 | GE Refrigerators
Water frozen in bottom of freezer. after frozen over bottom will come out into floor in front of freezer door help!!! will get ice out of bottom of freezer and no water in floor . there is a hole in back...
follow the floor to back and you will find a trough with a hole in the center..it's clogged..a semi stiff wire or I use flexible tubing and run it down the hole to clear blockage..run hot water down it to check it is clear.
Jun 12, 2009 | GE GSH25JFR Side by Side Refrigerator
Water on floor
Check for a blocked defrost drain. Take the panel off at the back of the freezer section and find the small hole at the very bottom center below the cooling coils. Use hot (but not boiling) water and a turkey baster to flush it out until water runs through it.
May 11, 2009 | GE GSS20IEP Side by Side Refrigerator
GE Freezer Leaking
Open the freezer door, remove the bottom tray, smash the ice on the floor with your fist to remove it. Now get a glass of hot water and pour it into the trough which is at the bottom of the back wall of the freezer. Allow a few minutes for the ice to melt then remove it with an ice pick or scrrewdriver. Once the ice is out, pour more hot water into the trough. Now take a long tube ( an old washer fill hose works perfectly) and stick one end in the hole in the trough. Now fill your mouth with warm water and blow it very hard through the tube. Once the drain is clear, pour some hot water and a very little amount of bleach through the hole.
Apr 06, 2009 | GE Refrigerators
Water accumulating in bottom of freezer and leaking onto floor
Yes the drain is clogged and the water that supouse to go through became ice so it make it worse.Put hot water in the drain hole until it runs through,it'll go to an evaporative pan on top of the compresor to keep it warm and vaporize the water.
Apr 04, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Water on floor probably from cloged line leading to evaperation p
Look under the freezer bottom drawer for ice.
If ice is there your defrost drain line is frozen closed.
It is located on the back wall of the freezer down low.
Turn off the fridge. Use a hair dryer to melt the ice at the drain hole.
The ice under the drawer can be broken with a hammer and removed.
Mar 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice build up on the bottom floor of the freezer
Sounds llik a defrost heater is open if you
have a VOM you can test it for continuity
Its probably behind a panel in the rear bottom
of the refrilgerator Should have a pan under
there to
Nov 21, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking onto floor
Angels, sounds like your defrost drain is frozen over. When the refrigerator is going into defrost it's draining through the front instead of the drain pan. You can remove the shelves and peel off the back cover and clear the drain by pouring hot water on the frozen drain hole. If you have a baster of some sort you could try to squirt the hot water through the venting on the bottom of the panel. Another way to to point a hair dryer on the drain hole. The best method is to remove the shelves and panel and make sure the drain is clear. Catriver..post back.
Dec 22, 2006 | Maytag MZD2766GES Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
407 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
