Richmond hotwater heater/ natural gas/ 5vp40e-1 a
SOURCE: richmond water heater, goes into lock out
flame sensor error remove and clean with steel wool or replace but becareful because most of them have the ignitor and flame sensor on one bracket and the ignitor is fragile and most important don't touch it the oils from your skin will cause it to burn out
SOURCE: whirlpool energy smart gas hotwater heater with
If the water heater shuts off again unplug the white the sensor plug underneath the thermostat (The black plastic box). Then plug it back in. This sensor plug has a black and white wire going to it and it's possible the plug could have been loose going into the thermostat..
If the problem persists you will need to contact the manufacturer at 1-877-817-6750 and they can assist you.
SOURCE: recently i got a hotwater heater installed in my
Those dirty crooks, Only kidding. They did the same thing to me a while back, except it was a natural gas heater with lp tank out in the yard, bought it from the gas co who services the tank, found out they ordered a dozen heaters, all of them natural gas. I said to the guy, do these need to be switched over or jetted or something? He says why, I said because it says natural gas only. It worked fine, just smudged black smoke out. He brought out another heater and swapped it out, seems you can't change the burner? Don't make sense. Anyway, I would take it back to the place you got it and say get up the coins, It cost $400 to get the plumber back to hook this thing up!! And we have no hot water. And my shotgun has a hair trigger. I would say it is dangerous enough to get his attention on the matter without going to court. Hope this helps.
SOURCE: My rinnai 26 infity gas hotwater heater keeps
Bosch has a 'fluctuating temperatures' pdf
It may apply or not
http://waterheatertimer.org/pdf/Bosch_Overcoming_fluctuating_temps.pdf
Absolutely feel obligated to upvote the help.
Or take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
SOURCE: I have a Reliance 606
Can be gas control valve. Or possibly the burner parts and air intake need yearly cleaning.
Open following links for example illustrations and useful troubleshoot resources:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/pdf/Flame-Arrestor-Screen-Cleaning.pdf
http://waterheatertimer.org/pdf/How-to-clean-combustion-chamber.pdf
Your manual will have additional information:
http://www.reliancewaterheaters.com/lit/om/g606.html
http://www.reliancewaterheaters.com/lit/om/manuals/186486-002.pdf
