Question about Sunforce 11260 Pure Sine Wave Inverter
I'm considering buying a Sunforce 11260 2500W sine inverter. Any reason I shouldn't?
    Sergeant:
  • 384 Answers
Numbe one reason ...you can not afford it.
Posted on Jul 23, 2009
Are there internal fuses in the Sunforce 11260 Inverter.
The inverter may not be suitable for use with an inductive load such as a vacuum cleaner.
May 28, 2018 | Sunforce 2500 Watt Pure Sine Wave Inverter...
4500 sun force inverter internal fans are always on. When I first set it up it use to come on to cool and then go off.
Likely the thermistor used as a thermal sensor shorted out. Either internally, or to the heat siink.
Dec 21, 2011 | Sunforce 4500W Pure Sine Inverter Watt...
My inverter keep blowing 40 amp fuses without load
Hi Trevor,
A 1000W can barely supply 5A at 220V, less than 10A at 110V. So if a 40A fuse blows, there is a serious problem and you should not attempt to use this unit after it has been checked by a qualified person. Please be careful!
Nov 20, 2011 | Sunforce 1000 Watt Pure Sine Wave Inverter...
Hi I have the Sunforce 1000W Pure Sine Inverter and everything was working fine until yesterday the remote stopped working. The inverter is about a month old and the remote has healthy batteries, I tried...
Have you tried removing the batteries for a minute and unplugging the main unit for the same amount of time together. The idea is to fully clear any settings that might have gotten hung up.
Oct 11, 2017 | Sunforce 1000W Pure Sine Inverter Watt...
Can this model be used on the grid? If not, is there a sunforce inverter that can be used on the grid?
If you meant for the mains supply then it must be connected in series to the load so that in absence of power the invertor takes over and when there is power the supply takes over as it charges the battery.
So have this wiring done with the connection routed from the fuse box or main board.
Sep 30, 2010 | Sunforce 1000 Watt Pure Sine Wave Inverter...
Hi i have a 400w black and decker inverter as soon as i plug my lap top in to it the power light on the inverter flashs and it wont power my laptop
The output of this inverter (and most others) is a modified sine wave, which isn't quite the same as a true sine wave - like you get from a wall outlet. Unfortunately, most transformers (which is essentially what your laptop power-supply is) require a true sine-wave. Your inverter will work fine for many other 110V applications. You can buy an inverter with a true sine-wave output, but they are more expensive.
Aug 19, 2010 | Black & Decker Power Inverter PI400AB
Have recently purchased a Sunforce 11264 4500W true sine inverter, shipment pending. trying to find a view of the back side of it to determine the 12V service connections needed, PDF of manual indicates a...
Hi , i'm sorry but i dont really understand your question , assuming the current draw is around 45 amps then 2 /0 GA is fine , just keep your leads from your panel nice and short , the connection kits are sold by sunforce and there plenty of suitable connectors on the market
example link below
http://www.globalepower.com/Datasheets/BatteryConnectors/BatteryGlobal.pdf
Aug 17, 2010 | Sunforce 11264 4500 W Pure Sine Wave...
SunForce 2500w pure sine wave converter add on
Mixing different AH rated batteries, different ages of even the same type battery is a bad idea. The new batteries will be effectively reduced to the equivalent of your worst battery.
Jun 24, 2010 | Sunforce 11260 Pure Sine Wave Inverter
Sunforce 11260 Pure Sine Wave Inverter Logo
283 people viewed this question
Top Sunforce Electronics - Others Experts
Robert Hunt
Tom Chichester
Are you a Sunforce Electronics - Other Expert? Answer questions, earn points and help others
