Device either has been muted by the console, or the input/connector could be loose. If either is not the case check the cord being used, and attempt all updates possible via both devices. If still have any issues see warranty for return assistance or contact store's for return assistance.
I’m happy to assist further over the phone at https://www.6ya.com/expert/aaron_42c23349a2d26c28
SOURCE: tv not reading the play station3 , both switch on
This is most probably due to the cable you are using, try unplugging the AV / HD-MI lead and blowing it to remove any built up dust. If that fails you will need to replace the cable you are using.
Any further questions feel free to ask.
SOURCE: I hooked up my play
If you had it hooked up in HDMI you have to go back to that TV and switch it into composit otherwise the PS3 doesn't know that you have switched like it does when you go from compsit to HDMI. If that doesn't work I recommend trying it in safe mode.
