SOURCE: burner will not turn off
I will need the complete model #. There should be a sticker near the bottom front behind the drawer. Can't use the # that is on the owners manual.
SOURCE: Burner won't light
is gas comeing out of the hole? sometimes by cleaning the orfice hole (food and debrie will get in there and plug the hole not letting the gas come through) i get a needle and poke it.
when you say it is sparking...When you turn the dial for that specific one you want ignited... That one is sparking? If so Great. This means you either have a plug or the valve is bad and not letting the gas flow through.
SOURCE: Replacement Range element not heating
red light means power is on in the wires. maybe the plug is very dirty, wire disconnected. if you mesured power at the connector, there is no reason a good burner would not work unless that when plugged in its not getting a good contact
SOURCE: kenmore electric stove with glass/cermanic top.
Tony, this sounds like you may need to have a new burner switch installed, it is called an infinite switch. If it is for the dual burner, make sure you tell the appliance parts store this so they can order you a dual infinite switch.
SOURCE: the light for the right
heatman101
Here
is a tip that I wrote about the problem of the cooktop light staying
on.
Oven
Hot Surface Indicator Light stays on
