SOURCE: Technics SL-23 belt driven turntable (NOT SL-1210 but I had to enter something)
Howdy Ivy:
An Adobe PDF format service manual for the Technics SL-23 turntable can be downloaded from
http://www.servicemanuals.net/
for about $16.
Paul H.
SOURCE: technics sl-ql 15 linear tracking T/Table
Parts are discontinued for these models. You need what's called a P-Mount cartridge screw. Try the following company:
www.lpgear.com
- DAVIS
DIGITAL ANALOG THERAPY
www.repairnyc.com
www.1200s.com
SOURCE: TECHNICS SL 1910 TURNTABLE SERVICE
The grease and lube in the mechanism will
need cleaned out and replaced due to the
"age" of table! The "lifter" may be bound
up due to grease drying out...
SOURCE: i have a technic sl 1200 m3d with a broken tone
Use the mk-5 , is the same and most peoplescsay the 1210mk2 will fit also , but mk-5 has the same arm 80 euro second hand and leave the origin live for what it is ..... Don't try to rebuild the technics to a real hifi unit.... I can help you by saying what and how to do, but
origin live sucks at this pricepoint and it ain't scratching anymore and the rewire is not cheap, but fun since i use silver and they are against it since only conducts a bit better, but they let you pay amazing prices for copper, only the difference between normal cable is max 1% compared to ofc and the real clean copper doesn't do a thing and is aimed for liquid oxygen containers and embryo's around -200 degrees celsius.....Bye a new mk-5 arm since there's more available and a nice pair of rca cables, no oyaide nonsence, i tried them for the denon distribitor, hear nothing.
Same for the digital one.
Try the weight adjustment. If it slid all the way back, that's likely your problem
