Need to clean coils
I just need to spray/clean out the coils on our RUDD unit. Can I use a power washer, or will that just pack dirt into coils? Thank you
    President:
  • 1,273 Answers
A power (pressure) washer generates too much pressure. It will bend the fins on the tubes.
Always isolate the power from the unit prior to opening the unit to perform any work. Remember that there can be both 220 and 110 volts present (main and thermostat), so be sure that you have it off.
For the outside unit, appliance parts supply stores sell a chemical that you can spray on with a garden sprayer, and then hose with a garden hose and spray nozzle from the inside.
For the inside coils, you can get good results with coil cleaner from one of the "home hardware" stores, or from an appliance parts supply store. It is in an aerosol can. This is sprayed on the coils and also hosed off.
One must be very cautious when using these chemicals, taking precautions to protect your eyes and exposed skin, as these chemicals are caustic or acid in nature and can easily burn your eyes. They also foam up in between the tubes/fins and on the surface, displacing the dirt.
For inside coils, you can remove the outside layer of debris with a medium brush and then spray. Fin brushes and combs are also made for this purpose. I usually follow this with another brushing and spray again, then wash down from the inside. Here again you need to be careful. The aim is to remove the build up, and flush off the chemical residue, without damaging your coils. It usually takes me at least two cans of cleaner for an inside coil. I drag a garden hose in the house and wash the coil down in bursts, to avoid running the collection tray over onto the floor. Outside coils are usually clean enough after one mixed container in the garden sprayer. Some aerosol sprays are deemed OK for both the inside and outside coils, and I have used them satisfactorily. Again, about two cans is what I usually need. The key, in my mind, is to apply and flush thoroughly from the inside towards the outside.
Hope that this was helpful,
--W/D--
Posted on Jul 23, 2009
Whats with norpole 12000 btu window air conditioners w/FO CODE,now all i have is a expensive fan!
they eventually do need serviced by a good repairman .freon leaks out .control boards fail etc .
Jul 18, 2016 | Filter Heating & Cooling
Air unit is freezing over
Check air filter, see if fan is running, check condenser coil for dirt build up. If its dirty shut power off and take top off unit so you can spray it with a garden hose. Use an up and down motion to clean the coil. Don't use too much pressure or you will damage the fins. If that doesn't work it may need charged.
May 11, 2014 | Intertherm Heating Cooling System 15kw...
Getting excessive condensation causing water problems at base of unit. Bought new pump but problem returned. Cleaned lines to outside by using wet/dry vac. How do I get to evaporator coil to spray it and...
Hello, in order to get to the evaporator coil you must cut into the plenum above the Furnace. This will require sheet metal tools and being very careful not to puncture the coil. Many times a cracked condensate pan under the evapoartor coil can cause water to leak down to the base of the unit.
Sep 15, 2011 | Ruud UBHC Air Conditioner
If my pipes freeze would difty filter cause it
Hello
Yes a dirty filter or a dirty coil can cause your pipes to freeze up.Dirt will stop the air from flowing through the coil.Causing it to freeze.
Replace your filter.Then clean out the coil.Simple green spray cleaner and water do a good job of getting rid of dirt on a/c coils.Turn unit off while cleaning.
If ice continues after filter and cleaning then you may be low on freon and have a leak.
Apr 27, 2011 | Heating & Cooling
My home air conditioning unit only blows cold air
You have an air flow problems. Clean the outside condenser coil I use on half baking soda and one half joy soadp squirt this on the coil take a coil brush that you can buy at any hardware store. and go up and down on the coil. then take the water hose and squirt it down to clean the soap and dirt off, It this doesn't solve it you will need to clean the fan blower motor the squrrel cage but don't get the motor wet. Next you will need to clean the evaporator coil just take the coil brush and go up and down to clean. This should solve your problem, What kind of readings did you get on the low side and high side. You should have a 40 degree drop across the evapartor. And the high side should be the out side temp and 30 degrees. If you have any questions you can email me at crislsparks@gmail .com. What kind of freon does it the unit take. It will tell you on the nameplate on the outside unit.
Jun 25, 2010 | Ruud UAKA042 Air Conditioner
A/c unit not cooling house weatherking model #12AJA3601
I use a spray nozzel on my water hose to clean out the oustide coil. You can go to a local Hvac parts store and get a cleaning gun and foam to clean the coil. I just use my water hose and sprayer with arm and hammer baking soda.
Jun 03, 2010 | Weather King 12AJA4201AH Air Conditioner
Flashing E1 -cleaned filter still have msg
clean the coil remove the filter and use a spray bottle with a little cleaner diluted bleach/water mix or a cleaner like widex and spray the coils from top to bottom dont wipe the coils will cause other problems just spray a few times to get the dirt/dust clogging the coils free than rinse with water not a lot use a spray bottle turn on fan and let run for a few than turn off and replace filter and try unit
Oct 01, 2009 | Danby DAC6003D Air Conditioner
RUDD MODEL# UAMB-048JAZ AIR CONDITIONER
service once a year clean dirt and hose the coil out make sure power to outdoor unit is off also make sure you keep a new air filter change about every 2 months you should also have a tech test you pressures this could cause poor cooling also need to clean inside coil also a service tech will probaly need to do this good luck
Aug 30, 2009 | Ruud UAMB Air Conditioner
I have a 3.5 ton Ruud UBHC-Series Heat Pump, with fan coil unit UBHC-17J11SFA. It was installed in 2004. It has not been cooling well this summer, nd my bills were high last winter. I did not properly...
What? To clean the coils should be $75-$150 tops. Never exchange r22 it lasts decades unless it leaks out. The data suggests that your Indoor coils are blocked(dirty) or your unit has a small leak. Wish I were there.Good Luck
Jul 09, 2009 | Heating & Cooling
How to Clean 1984 TRANE Cooling VENTS inside house No Manuals
The Outdoor unit will be easy 1st diconeect power at panel, or disconnect box near unit. Remove top of unit, be careful not to damage fan blades. Spray coils (fins) with a light degreaser let is soak for 5 mins. wash out coils from inside the unit out. Spray straight on so you push the dirt out the other side.
Re assemble and start up.
Indoor coil will be accessed by removing front cover and you may have another cover to expose the inside of the coil fins. That is where you need to clean. Spray degreaser on coils and rinse off. If its gunked up then use a wire brush 1st. Carefull not to bend the fins over.
Check the drain pan at bottom of the coil to be sure it's not full of stuff. Blow out if needed.
You should be clean and ready for the season
Jul 02, 2009 | Ruud Central System Air Conditioner
Heating & Cooling Logo
54 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
