Question about Panasonic NV-GS35 Mini DV Digital Camcorder
LCD Monitor The LCD monitor is not working due to the cable strap is broken pls. advise on how to rectify this problem.
    Sergeant:
    Novelist:
  • 198 Answers
Here's a list of Panasonic's repair centers:
http://web1.panasonic.com/food_service/cmo/customer_service/service_repair.html
if you want to repair it yourself, here's a good reference:
You can order them email them the part discription they can send u one if u go to panasonic they will ask for a price of new cam
link for order or try ebay for this it iwll help
http://www.partmaster.co.uk/cgi-bin/search.pl?query=Panasonic%20NVGS35&pg=3&path=98821,112403:98828&brand=Panasonic&model=NVGS35&part=
you first need to strip both the camcorder and the lcd door to get the actual cable out. It might just push into a terminal connector at either end or it might be soldered to the circuit board at either end. Once you find that out then you could probably get a piece of ribbon cable to replace it from an electronic parts supplier. You also have the option (if you have a decent soldering iron) to just use standard multicore cable and solder a colour-coded set to replace the ribbon. If the board uses connectors you would have to unsolder that too and then make up your own cable loom using very thin cable.
It's a delicate operation requiring patience and a BIG magnifying glass
Posted on Jul 25, 2009
I have a Sony 1410 LCD monitor, when it is powered up the screen displays vertical coloured lines on the left hand side for about 60 ml wide and the remainder of the the screen displays grey and black...
In most cases, this could be due to two factors. One - Your video card is losing life. Two - Your Sony monitor is almost dead. Simple way to trace the root cause is - borrow a monitor from your friend or someone and check. If the borrowed monitor works fine - it is the video card, that should be changed. Else, go for a new monitor.
Lastly, often people forget to check the cables. Sometimes broken pins or bent pin at the connectors could cause the problem too.
Mar 04, 2011 | Sony LMD-1410 14" LCD Monitor
My screen is black nothing shows up 3 months old
-check the cables on the monitor and disconnect and reconnect it
-if issue still persist you can check the cable of the monitor for broken pins (vga cable the one with blue connector)
-if there are broken pins then the cable could be the problem
-if not you can try to connect the monitor to another computer or connect the computer to another monitor
-if you connect another monitor to the computer and it works fine then the first monitor you have is broken
-but if you connected the monitor to another computer and it works then it could be the video card of the computer.
Nov 25, 2010 | HP w19 19" LCD Monitor
Hi, I have hp pavilion dv2500 laptop. I have display problem.pls help how to rectify it. If i connect exteranl CRT monitor Display is coming . Pls tell me how to disassemble the laptop.
You might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
In this service manual, you will find an illustration of how to disassemble the laptop & replace either the LCD cable or screen inverter board:
http://h10032.www1.hp.com/ctg/Manual/c01295820.pdf
Sep 17, 2010 | HP Pavilion dv2500t Notebook
Monitor display message : = No Video input. Pls
if cables are ok; Take your computer down to the repair shop.
Jun 20, 2010 | Philips 170S4FB 17" LCD Monitor
Brightness menu keeps popping up
This problem is usually caused due to a faulty microswitch in the brightness button. To rectify this, you'll have to change this switch.
Get your monitor serviced by a qualified service personnel.
Hope this solves your problem. For more help or clarifications, please reply. Thanks.
Aug 09, 2009 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Cpu turns on but monitor not
PLS CHECK THE POWER CABLE ATTACHED TO THE MONITOR AND THE CPU..IF CPU IS WORKING PROPERLY THE PLS CONSULT YOUR VENDOR.THER MIGHT BE PROBLEM IN YOUR MONITOR
Jul 22, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
My gateway monitor FPD1975W 19inch LCD won't turn on.pls help me.
I have repaired similar FPD models. I have one of them on this very desk.
The GatewayFPDmodels develop problems after a couple or more years of use. Therepairsare fairly easy for the savvy technician. The power inverterboard inthe back of the monitor contains some capacitors, they may be470 and220 mfd or 680 mfd depending on when they were made, @ 10 16 or25volts, with a 105 deg. C temp rating. They go bad due to heatissuesand the currents they have to filter. Replacement of thecapacitorsusually restores operation. Use capacitorss of the sameratings as original for replacement.
Be advised, turning the monitor off when you are not using it will extend the life between these repairs.
Hope you find this helpful.
Apr 08, 2009 | Gateway FPD1975W 19" LCD Monitor
HP 19 IN. LCD MONITOR
its so simple problem on screen what come no signal rigt
so u have to do this just chek ur monitor cable its not pulg in cpu
so reconnet ur monitor cable in your cpu
thnx using fixya
Mar 30, 2008 | HP f1905 19" Flat Panel LCD Monitor
Panasonic NV-GS35 Mini DV Digital Camcorder Logo
93 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
