When I pressed the button on the tower to turn it on, nothing happens. What could be wrong?
  • 30 Answers
Im assuming the pc is plugged in and if there is a switch in the back of the computer by the plug it is set to on.
assuming the above is correct try moving your computer to another wall outlet. also leave the computer unplugged for about 10 minutes and try again.
Posted on Jul 23, 2009
Press tower button and nothing happens
press power button and nathing happens, u need to check your power supply
Nov 27, 2011 | E-Machines eMachines Desktop PC
After a power outage my tower wil not turn on. when I press the button nothing happens...is it locked? how do I fix this. I unplugged and re pugged.
just remove the power plug from the back of your comter and press the powerswitch few time then plugin the power cable and press the power switch
Sep 01, 2011 | HP Computers & Internet
Desktop: Gateway LX6810-01 PC will not power on. When I hit the Power button on the tower, a long continuous BEEP comes on and nothing appears on the monitor. After the BEEP, the On light (on tower)...
Thank you for using FixYa
I would try shutting down the computer in the normal way, and turning off the monitor.
Boot up and turn the monitor back on.
If it still doesn't work, then I would check the cables and power plugs and wall plugs.
Check the mouse and keyboard cable and any other cables plugged into the computer.
The next step requires a seperate monitor or laptop.
Try unplugging the monitor and pluging in another monitor. Most laptops have a common
VGA adaptor jack or even an Svideo jack.
If the other monitor does not work, Then take to a qualified technician for repair.
It could be your power supply in the computer or video controller.
I hope this was useful and please comment if this was helpful to you.
Mar 24, 2011 | Computers & Internet
My emachine tower won't turn on . I try un plugging it and plugging back and it doesn't work. Could it be that there something wrong with the motherboard or the hardrive?
> won't turn on
Remove the side-panel, and then press the ON button.
Do any fans start to turn? Feel any air coming out of the back of the power-supply?
Does pressing the button open/close the CD/DVD tray?
If not, then your power-supply has "blown", and must be replaced.
If the fans do turn, and the tray opens, but nothing happens on the screen,
e.g., no "splash" screen, nor any brief white-text "hardware-summary" appears,
then it's either the CPU or the motherboard which is the problem.
If you see the "splash" screen, or that "summary" screen, but Windows does not start to load, then the disk-drive either is not getting any power, or its "data" cable is not connected, or the disk-drive itself has "died".
It's time to take it to a qualified technician, for professional trouble-shooting.
Feb 01, 2011 | Computers & Internet
There is a green blinking LED on my motherboard, and my computer is not turning on. What is wrong? Someone told me to ... Hi, i have a dell Optiplex 780 running windows xp, the computer button is just...
If you are referring to the green light on the system tower and is blinking the problem could be the system is in stand by mode.
Turn off the computer by pressing on the power button on the system tower for 10 seconds.
Disconnect the black power cord at the back of the system tower and then again press the power button on the tower for 10 seconds. There would be no activity on the tower when you do this.
Reconnect the power cord and then power on the computer to see if the issue is resolved.
Thanks for using Fixya
Proton
Aug 30, 2010 | Dell XPS 200 PC Desktop
Pc won't boot ...
it seems to be an issue of a loose Hard drive connection.. you can open up a tower and re-connect the cable.
Feb 25, 2010 | HP Compaq Presario SR2150NX PC Desktop
Okay im having a probblem with my lcd monitor and when i press the button on the tower to turn everything on and then press the on button on the lcd monitor it says minitor is going to sleeep and ive tried...
Sounds like the monitor is not getting a signal from the tower.
Do you have another monitor/LCD screen that you plug into your tower? That will tell you if the LCD is the issue or the tower.
If it is the tower that is at fault, then you need to try and figure out if your video is separate from your motherboard. Hopefully it is separate, that way you can get that replaced. If not, then it means that your video card is integrated onto your motherboard which is much expensive to get fixed.
Hope this helps.
Dec 08, 2009 | HP W2007 LCD Monitor
VAIO Will Not Power Up
It is possible that the power box is dead.
Or try this open your box and disconnect the power supply from the mother board and put in beck. And try and boot up.
Aug 10, 2009 | Computers & Internet
My tower won't turn on. I checked and it is plugeged in to a working outlet... the screen light is on and even one light on the tower is on -- but when I press the on button NOTHING happens.
hi ,
you can try this solution
unplug all cables , powerflee the system by pressing the start button for 30 sec , release it then replugg all the cables and check wheather it is working or not , secondly check wheather the powers supply fan on the back of tower is working or not, still it doesnt work turn off the tower and unplugg the tower and then openthe tower , check all cables and reset the RAM on the mother board ...you can try this basic troubleshooting , it will help u... waiting for response
May 20, 2008 | Computers & Internet
WON'T TURN ON
I am having same problem as you. When i press power button, prada logo shows and nothing else. :(
Jan 20, 2008 | LG Prada KE850 Cellular Phone
Computers & Internet Logo
114 people viewed this question
David Payne
David Payne
