RAD 9p shutting off Have checked all capacitors
RAD 9p shutting off Have checked all capacitors closely and see no damage to any whats next
  • 1_bad_kitty Jul 24, 2009
    this is the monitor I sent photos of cord on. Where is your business?
  • 748 Answers
Hi
The capacitors need to checked with an ESR meter. Althought capacitors sometimes bulge when they go bad this is not always true. Capacitors change value internally very easily when the conditions are right. High heat.
You can send this to my company for repair or if you need more help go ahead and email me.
Thanks
Posted on Jul 24, 2009
97mitsubishi..3000gt overheating
Have you had a chance or have your mechanic check the thermostat (control) and/or the coolant pump ? If any of them is not working, the coolant will not circulate (properly) and hence, it overheats.
May 20, 2014 | 1997 Mitsubishi 3000GT
I let my car heat up to get frost of window for about fifteen minutes. When I went out the frost was still on window and no heat coming from dash and car was overheating. I shut it off, let it cool down...
Start with engine cool, remove rad cap, start engine and turn heater on. Top up rad level and Let engine run until it get's up to normal operating temperature with cap off and add coolant as you see it go down. Watch in rad for coolant to start moving quicker, once gauge gets close to normal temperature, indicating that thermostat has opened. Wait until you see that 2 or 3 times, then top up and install rad cap. Top up coolant return bottle to proper level . You'll want to keep a close eye on coolant return bottle level for next little while. If coolant got that low in the first place, you have a leak somewhere that will have to be found.
Mar 31, 2011 | 2002 Chevrolet Impala
Hotpoint WMA 9P Door locked indicator light flashing will not allow machine to run
If the door lock indicator light is flashing it means the door is not closed .......or the machine thinks it's not closed. Give the door an extra push just in case, the areas to check would be the switch, the wiring connections and the tracks on the module. If you find any tracks on the module have blown also check the motor for lose or broken wires because the module does not blow for no reason.
Mar 19, 2010 | Hotpoint Washing Machines
Samsung HT-X40 also shuts off after displaying Protection
You probably have the same problem that myself and several others have had, and let me guess, its outside of the warranty? How good are you with a soldering iron? If you are not afraid to do some soldering you can fix it, check out these instructions that i found:
http://lemurt.wordpress.com/2008/08/18/defenition-of-waranty-void/
you will need 474k or .47uf 100v capacitors and a soldering iron, but you can fix it, worked for me.
Aug 08, 2009 | Samsung HT-X40 System
Fan motor
have u checked the capacitor for the fan if might be damaged, is the fan getting power i.e 120 vac or 220vac
Aug 02, 2009 | Comfort-Aire RAD-81 Air Conditioner
RAD-9p shuts off for no reason
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 23, 2009 | KDS Radius RAD-9p 19" Flat Panel LCD...
Protection and shut down.ht-tx35
protection error message means that your unit's fan is not working
it is a feature to keep your unit from overheating
check if there is anything blocking the fan of your unit from rotation
Jun 09, 2009 | Samsung HT-X40 System
Water leak from radiator bottom right hand corner or pipe in area
Please the radiator has been damaged. Ensure you change it before it turns your engine off totally leading to engine change.
Be careful next time.
Good luck.
rate this fixya!
Apr 07, 2009 | 1998 Volkswagen Golf
M140 laptop wont work
here's possible problems.
Processor is overheating. fan might not be spinning properly or laptop could be too dusty inside. or some small capacitors are causing shorts.
Video cards fan isn't spinning or doing the same as the other.
check those if that isn't the problems. then the os is infected with a virus. that is attacking the computer causing it to shut down to prevent data loss. check into these solutions.
Sep 08, 2008 | Dell Inspiron XPS M140 Notebook
KDS Rad-9p wont stay on
my monitor will not work it will come on when the pc is cut on but it will not display
Aug 24, 2008 | KDS Radius RAD-9p 19" Flat Panel LCD...
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
