Question about Mitsubishi WS-65315 65" Rear Projection HDTV-Ready Television
Have picture and sound then intermittently drops the signal
The t.v. works fine, sometimes for hours at a time, then the input signal cuts out. Cycling the power off and on brings the signal back and may work again for awhile or cut out again in a couple of minutes.
Do get the occasional blinking green light, but unit resets itself after about a minute and all is well.
Ideas?
  • 668 Answers
The DM is in the process of failing.depending on the age of the unit it may not be available.
Here is Mitsubishi's Parts Department Phone Number. 1800-553-7278.
I hope this helps,
Skyassoc
Posted on Jul 25, 2009
The turn signals on my 2003 Impala intermittently stop working. They will work fine one minute and then the next time you use the signal they don't work. Sometimes if you leave the signal (left or right...
sounds like your blinker relays are going out. Im not sure where they are located on your vehicle. but typically they are located in the interior fuse compartment of the vehicle
Nov 15, 2009 | 2003 Chevrolet Impala
Motorola DCH3200 cable box: sound and sometimes video cutting out
Sounds like your SNR is getting too high and causing the signal to overload. A few things can cause this a bad splitter that causes the signal to bleed and introduces noise, or a more common issue is having a weak signal coming from the cable provider and once it goes through a splitter it causes the signal to become to weak to be stable.
Since it sounds like your cable has been working up until recently, you may have had a cable or splitter go bad.
Call comcast and have a technician come out and test the line.
Sep 11, 2009 | Motorola Televison & Video
Intermittant disruption of Picture and Sound on View TV/HDMI only
If i am not mistaken you can select the HDMI signal going out on the 663, this means you should select to have only pictures to go out as sound will have to be reproduced by the 663.
So HDMI output setup on the 663 should indicate image only, no sound.
Jan 23, 2009 | Yamaha RX-V663 Receiver
Loss of picture and sound.
Did you check in your tv settings about which input is either cable or antenna, try doing a "autoscan" of channels based off your antenna, after seeing what your main input is
Jan 10, 2009 | Panasonic TH-50PX25U/P 50 in. HDTV Plasma...
36 inch RCA tv loses picture and sound, but power stays on
Cable Looses signal power after 20m ... Install signal amplifier
https://youtu.be/AkiKf4G4UE0
May 04, 2017 | RCA 36V430T 36" TV
Model 2780R intermittant Picture & Sound Failure
The set has loose power conections to the tuner and judging by the model it might have other loose conections in the chassis,the loose conections need to be resoldered and might not be easy to find,try taping the side of the set to see if it reacts while is doing the problem.Be safe and call a technician unless you are familiar with tv service.
Sep 20, 2006 | Sony KV-27FV16 TV
Mitsubishi WS-65315 65" Rear Projection HDTV-Ready Television Logo
79 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
