Question about Water Sport
I have a 2003 yamaha 700 waverunner. It starts
I have a 2003 yamaha 700 waverunner. It starts and will take off like normal but them will lose power after a minute of riding and make a funny noise & kind of shake when you try to accelerate. Could it overheat? What could be the probleM?
Sounds like the impeller is knackered, check the impeller housing and the impeller itself, impeller should look like its nearly touching the housing, check the housing to see if it has created a grove, if they both look worn, replace with new
Posted on Oct 07, 2011
    Problem Solver:
  • 16 Answers
If u did any modifactions to the air intake than that could be a reason.
Posted on Jul 23, 2009
99 yamaha waverunner 1200 xlt starter stays engaged and powered on even after stop is pressed and kill switch is pulled.
The start stays engaged the entire time? I would guess it's a bad ignition switch -- it would be sending power to the starter (through the solenoid) regardless of if you switched it off.
Maybe it could be a bad starter, too. I'd start with the switch.
Mar 10, 2016 | Yamaha Jet Ski Pwc Watercraft Cover...
Yamaha xl1200 waverunner losses power after it is warmed up.
Hi, most likely cause and the easiest to check is exhaust leaking in the engine compartment. Run it without the seat fitted for the same time frame and if it fixes your problem you are looking for an exhaust leak. Regards Phil.
Aug 23, 2012 | Yamaha Boating
Yamaha waverunner won't idle and losing power
L stands for limp mode
it is a mode that the ECM selects to prevent serious damage to the engine ( from you lack of oil )
have the fault codes read then reset with the scan tool
Mar 31, 2017 | Water Sport
YAMAHA WAVERUNNER 2000 XL 800, WILL NOT RUN PAST 12 MPH
Have you done a compression test on all cylinders? My guess is you have a dead cylinder (no oil to one or more cylinders causing loss of power). If the compression test passes (all cylinders equal and higher than 100-110 psi) you have a restricted exhaust from a failed catalytic converter that has broken apart.
Apr 05, 2010 | 2003 Yamaha YZ 250
1994 Yamaha Waverunner 3 will idle but wont take throttle
1994 700 cc waverunner when it has run for 15 min engine bucks at full throttle at 3/4 ok i have changer plugs antreated fuel
Aug 01, 2009 | Yamaha 12V Air Pump
2006 yamaha waverunner wont idle
what is it idle at? how much? remove your seat check air filter if is black oily remove it and see if that fixes your problem you may want to change your spark plugs as well # one cylinder may be starting to foul the new yamahas are the worst for fouling plugs use a cr8eb instead of the cr9eb the 8s are hotter and work better try those and let me know thank you
May 15, 2009 | Yamaha 12V Air Pump
Water Sport Logo
599 people viewed this question
Top Water Sport Experts
Bill Boyd
Tom Chichester
Are you a Water Sport Expert? Answer questions, earn points and help others
