Question about Trendware TEW-432BRP Wireless Router (TEW432BRP)
Connecting two routers to extend network
I have a TrendNet TEW-432BRP and a Linksys WRT54g v5 and I wanted to connect these via ethernet wire and set one of them up as a repeater. Is this possible? How would I do this? Do I need to add third party firmware to one? I see the WRT can accept DD-WRT-micro
    Scholar:
  • 122 Answers
Router A is connected to the modem. Setup router B to run as access point only. assign an un-used IP address to router B. Turn off the DHCP server on router B. connect a LAN port of router B with a LAN port of router A .do not use the Internet port of router B. do not configure WAN settings in router B. both routers must have the same wireless settings except for the wireless channel which should be different. Set the same SSID and the same wireless security settings on both routers. Good Luck
Posted on Jul 23, 2009
Were do i find the pin number
If by pin you mean the KEY for wireless SSID then you have
Log in to the AP by connecting a PC with AP via wired cable.
Point to web address: http://192.168.1.1 and input user and pass (IP may change due to config)
Go to wireless->Security
Change the key in Passphrase and you are good to go..
Mar 12, 2011 | Trendware TRENDnet TEW-432BRP 54Mbps...
I HAVE AN IPOD TOUCH, BUT I CANNOT CONNECT throughh my trendnet. IT READS UNABLE TO JOIN THE NETWORK "TREDnet what can i do to get wifi connection. thanks
Depending on the version of your router (you can determine the version from the Trendnet support web site), there may be a firmware update for your router that will resolve the issue that prevents your iPod Touch from connecting to it.
There has also been discussions that simply reseting the router by disconnecting the power cord for a minute or so can allow an iPod Touch to successfully associate with a flakey router.
Dec 27, 2010 | Trendware TRENDnet TEW-432BRP 54Mbps...
How properly to connect TRENDnet TEW-432BRP to laptop
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Nov 26, 2010 | Trendware TRENDnet TEW-432BRP 54Mbps...
Can't assess password to set up a new computer
Here is the PDF file that shows how to reset the router if the password is forgotten.
http://downloads.trendnet.com/TEW-432BRP/FAQ/FAQ_TEW-432BRP.pdf
Oct 14, 2010 | Trendware TRENDnet TEW-432BRP 54Mbps...
Security key
Use an Ethernet cable to connect your desktop/laptop to one of the LAN ports on the router. Launch Internet Explorer, and connect to the web-server "inside" the router. Run the "Wireless Networking Setup Wizard", to enter an SSID, enable 'WPA' encryption, and to set a security-key or password or pass-phrase.
Aug 22, 2010 | Trendware TRENDnet TEW-432BRP 54Mbps...
Wish to setup hp k550dtn printer with ethernet support to a wireless trendnet router..432BRP. Two laptops will share this printer
You can use a print server to connect your printer to your computers over the ethernet/wifi connection, All printers will be using a network printer..
OR..
You can Attach the printer onto 1 of your computers, set the properties to share the printer, and then set up a new printer on the other computers (network printer)
Make sure all the computers on your home network are on the same WORKGROUP
Jul 17, 2010 | Trendware TRENDnet TEW-432BRP 54Mbps...
How to connect tew-432 brp to MT800 modem for a wireless connection
you can connect your Ethernet cable from tew-432brp to MT800.
if serial ethernet cable not work you can check with cross cable of ehetrnet also.
Mar 30, 2010 | Trendware TRENDnet TEW-432BRP 54Mbps...
I have a trendnet wireless router tew 432brp, a new hp windows 7 laptop, and old xp laptop and i want to share the connection with my verizon um175 aircard. this has worked for several years with the old...
The router connects computers together . You are using a windows 7 p.c and connecting it to an internet connection via a usb verizon um175 aircard.
I think you need to share the internet connection with the rest of the network and may need to feed the ethernet cable into the feed port of the router. I have not done this before but logically the windows 7 computer would have to act as a gateway to the internet.
http://www.dummies.com/computers/operating-systems/windows-7/how-to-share-an-internet-connection-in-windows-7/
https://www.ibvpn.com/billing/knowledgebase/53/Internet-Connection-Sharing-on-Windows-7.html
Note the default gateway is going to have to be the windows 7 ip address on the other computers
You may need to set the ip address on windows 7 to a static address and then change the dhcp server settings default gateway and also increase the first address to not include the windows 7 ip address or the routers ip address in the lease range for shcp.
Mar 17, 2017 | Trendware TEW-432BRP 54Mbps Wireless...
Problem using Wa1003A and Tew 432 brp to share my internet
lan wires are the same. lan wires used to connect your computer to your modem can also be used to connect your Wa1003A adsl router and TEW 432 brp.
you just got some things mixed up.
1. you should set your Wa1003A adsl router to bridge mode. At this point, it will just be "pass through" device and will not be the one who will ask for IP adds from your ISP.
2. configure your TEW 432 brp with your pppoe username and password. Your TEW 432 brp will now ask the network for the IP address to that it can connect to your ISP.
3. leave your lan wires the same.
Apr 24, 2009 | Trendware TRENDnet TEW-432BRP 54Mbps...
Trendnet router
i found out that since i have an older version of winxp 2000, i need to get a network adapter, to get this router going.
Mar 25, 2008 | Trendware TEW-432BRP Wireless Router...
Trendware TEW-432BRP Wireless Router (TEW432BRP) Logo
629 people viewed this question
Top Trendware Computers & Internet Experts
Prashant M
Prashant M
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
